sync cogs using the cnt register — Parallax Forums
dr hydradr hydra Posts: 212
edited 2014-11-14 14:35 in Propeller 1
Is there a simple application note or write up for syncing all cogs through the cnt register?
  • BeanBean Posts: 8,129
    edited 2014-11-14 06:13
    Basically you read the cnt register, add a constant to it (to give the other cogs time to start up), then write the value into a hub variable.
    The cogs to be sync'd read the value and do a WAITCNT for that value.
    I think cogs take several milliseconds to start up, so you need to add a large enough constant so CNT is not already past the stored value when the other cogs read it.
    Bean
    P.S. Are you using spin or pasm ?
  • JDatJDat Posts: 103
    edited 2014-11-14 06:26
  • dr hydradr hydra Posts: 212
    edited 2014-11-14 11:28
    Thanks for the reply....I am using pasm...I am looking for a very deterministic timing
    thinking though this...I have a few concerns/questions...Once the cogs are in-sync...any read to the hub will cause them to become out of sync...right? Here is my thinking
    As an example lets say I want two cogs the be in-sync and read and output data at the same time by running the same program on the two separate cogs...because only one cogs gets access to the hub at a time..each read would cause them to become out of sync...Now lets say I am using cogs 2 and 3 (or any two cogs next to each other) I could calculate the time difference as long as the cogs access to the hub starts with any cog except cog three....because a start at cog three would cause cog two's access to wait until cogs 4,5,6,7,0, and 1 have access. Any other start (hub access) cog (except 3) would cause access for cog two to come before cog three..making the timing deterministic. How could I avoid this?...Or am I missing something...it seems that there is a system clock (cnt) and a hub access clock...and can you calculate the hub access clock? That way...you would know at each cnt time what cog has access to the hub
    edited 2014-11-14 11:55
    dr hydra wrote: »
    Still not quite sure what you're after here. Anyway, cnt is never reset as such (like video frame counters and counter flip-flops), i.e. there is no fixed relationship between cnt and hub access. But it may help to know that the first instruction executed by a cog is -4 clocks relative to its hub window slot. So you'd have to run this test once and then you know where and when stuff happens.
    mov     cnt, cnt         ' first cog insn
        wrlong  cnt, par         ' broadcast timing (no penalty for this hubop)
    I posted a project a few years ago where I sync'ed 4 cogs to be precisely 1 clock apart. Each cog read all ports so that I could actually have all ports being sampled 1 clock apart.
    IIRC it was called something like DataLogger and perhaps I posted it in Obex.
    It's no longer on my dev pc but I would have it archived somewhere.
    Anyway, what I did was have all 1 cog get waitcnt and put it in hub. Then all other cogs grabed this and added a fixed amount (to cover the delay in getting it into a waitcnt value). Each of the cogs then added 0/1/2/3 to that value too, and then performed a waitcnt on the new value. They were then precisely 1 clock apart.
    Hope this helps.
