$1.30 Voltage Stepdown Modules
Just ordered five, works out to $1.30 each shipped: http://www.ebay.com/itm/5pcs-DC-DC-4-5V-28V-to-0-8V-20V-Step-Down-Module-Power-Supply-for-Arduino-Hot-/301297751206
They look nice & small, 96% efficiency claimed. 3 Amps max! Might be good for dialing down a 7.4V LiPo to power servos on a small bot. The only thing I don't cotton to is that tiny adjustment pot. I prefer multiturn worm gear trimpots for fine adjustment.
Anybody tried these yet? Curiousone, you're always one step ahead of me lately.
Model Name: Mini-360 (ultra small size DC-DC synchronous rectifier buck module)
Module Properties: non-isolated buck
Rectification: synchronous rectification
Input voltage: 4.75V-23V
Output voltage: 1.0V-17V
Output Current: lowering the value of 3A, long 1.8A
Conversion efficiency: 96% (maximum)
Switching Frequency: 340KHz
Output ripple: 30mV (no-load)
Load regulation: ± 0.5%
Voltage regulation: ± 2.5%
Working temperature: -40 ℃ to +85 ℃
External dimensions: 17 * 11 * 3.8 (L * W * H) (mm)
Features: Use integrally molded power inductor and synchronous rectifier control chip, smaller and more efficient.
Can you find the same great deal in something that steps up from 3.3v to 5.0v?
http://forums.parallax.com/showthread.php/149646-5VDC-Boost-Converter
A lot of sensors and accessories still need 5V, even if you have a 3.3V processor. Some day I'll test what happens if you power 2 CR servos off this module for a mobile bot.
Edit: I am using one of these now and I noticed a funny thing. There's a red LED power indicator on this USB booster which doesn't light up on 1.5V input, but it's still outputting 5V.
It was interesting to read the reviews on this module. It appears most reviewers liked them.
http://www.ebay.com/itm/10-pcs-DC-DC-LM2596-Step-Down-Adjustable-Converter-Power-Supply-Module1-3V-35V-/301120877446?pt=LH_DefaultDomain_0&hash=item461c33f386
Sort of an apples and quinces situation. The OP features the MP1584 and your board features the LM2596. The link Duane provided has a great comparison of the two.
BTW: The LM2596 works fine. Any hoarder probably has a bunch of them. I have at least 14 that I know of. Many are embedded in devices I built a while ago, and are still going strong today. The MP1584 is intriguing mostly for the slightly greater efficiency, which means less heat dissipated. In some applications I really do need 2A.
Dommy Like It.
Update: Hooked it up to 22VDC input and tried to adjust to 3.3V and couldn't get it right on. Thought a multi-turn pot would do it but the output range is so wide it can't get fine resolution. It's a 1.5k pot so putting a 10k in series might bring it in tighter.
http://www.eevblog.com/forum/reviews/lm2596-dc-dc-step-down-modules-load-testing/
A fine review. Objective and accurate.
Now for the subjective, hyperbolic, and annoying review:
The MP1584 is fabulous! Thanks to synchronous rectification using internal MOSFETs, conversion efficiency is way high. That, combined with the high operating frequency, makes for a truly tiny board with outstanding current-handling capability. Almost has to be seen to be believed. It garners my vote for EFOTY.
EFOTY=Erco Find Of The Year?
