ColorPAL #28380
I watch a display of colorPAL (http://m.youtube.com/watch?v=uYXXQpb29Qc).
I have Parallax of board of education(Rev C), ColorPAL#28380 and 4-pin RGB LED, I have connect ColorPAL and RGB LED on the board. ColorPAL was connected to PIN 15, and RGB LED was connected to pin 6, Anode is on PIN 6, 3-pin(cathode) on breedboard.
Anyone know how to write or add a code to let the RGB show the measure color when the ColorPAL detect the color it sees.
I use the code
I use the code
' -----[ Program Description ]---------------------------------------------
' This program drives the Parallax ColorPAL color sensor and provides
' serial RGB data to the PC-hosted TCS230_ColorPAL_match.exe color
' matching program.
' -----[ I/O Definitions ]-------------------------------------------------
sio PIN 15 ' Serial I/O com pin for ColorPAL.
' -----[ Constants ]-------------------------------------------------------
' Baudrate definitions. Serial I/O must be open-drain. The ColorPAL includes
' a pullup internally.
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
baud CON 119 + 32768
#CASE BS2SX, BS2P
baud CON 327 + 32768
#CASE BS2PX
baud CON 536 + 32768
#ENDSELECT
' -----[ Variables ]-------------------------------------------------------
red VAR Word ' Received RGB values from ColorPAL.
grn VAR Word
blu VAR Word
' -----[ Initialization ]--------------------------------------------------
GOSUB Reset ' Reset the ColorPAL and enter direct command mode.
' -----[ Program Code ]----------------------------------------------------
SEROUT sio, baud, ["= (00 $ m) !"] 'Program ColorPAL to send $ then color data.
DO
SERIN sio, baud, [WAIT("$"), HEX3 red, HEX3 grn, HEX3 blu] ' Receive RGB data back.
DEBUG "R", DEC4 red, " G", DEC4 grn, " B", DEC4 blu, CR ' Output it.
LOOP
' -----[ Subroutines ]-----------------------------------------------------
' Reset: Sends a long break to reset ColorPAL and enter direct command mode.
Reset:
LOW sio 'Pull sio low to eliminate any residual charge.
INPUT sio 'Return pin to input.
DO UNTIL sio : LOOP 'Wait for pin to be pulled high by ColorPAL.
LOW sio 'Pull pin low.
PAUSE 1000 'Keep low for 80ms to enter Direct mode.
PAUSE 1000 'Pause another 10ms
RETURN
