Nice Cheap Servo for Continuous Rotation Modification — Parallax Forums
ercoerco Posts: 20,261
edited 2015-03-19 19:20 in Robotics
I'm building one or two small mobile robots each week now (oh, how I love my new job!) and I've been modifying several different cheap standard-size servos for continuous rotation. Some are easier to mod than others, some have better fine motor control. This week's favorite is Hobby King's Turnigy TGY-S4505B .
1) It's cheap, $5.10-$5.65 depending on Int'l vs US warehouse and if you wait a while to order (discount offered)
2) Dual ball bearings for long life
3) Doesn't need the internal pot for support. Just snip off the plastic pot shaft and it's mechanically disconnected.
4) Snip a single post off the output gear for 360 degree rotation
5) Unsolder 3 pot wires (note color, they vary) and route thru a small hole in the case to an external 5-10K trimpot.
6) Excellent center stop stability
7) Excellent fine motor speed control
8) 1.75" diameter circular servo horn included makes a fine free instant wheel, just cut a rubber band "tire" out of an old road bike innertube.
It uses nylon gears, so don't overload it, but I was pleasantly surprised how well this one works. I hate re-nulling drifty CR servos every other day, and so far I haven't had to with these. A five-star thumbs-up from erco, I'm ordering more.
Edit: Servos driving 1.75" servo horn "wheels" at 6V (4xAA) gives maximum forward speed of ~7"/sec.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-11-10 18:02
    Are you working from home now?
    edited 2014-11-10 18:37
    Yes, consulting and inventing. Best of both worlds!
    edited 2014-11-11 08:51
    So what would they call this combination of consulting and inventing? How about ConVenting? Or there's always InSulting!
    Welcome to the world of work-at-home, pal! Just remember to change out of your jammies if you make a quick trip for hardware at the Home Depot.
  • WhitWhit Posts: 4,191
    edited 2014-11-11 19:51
    Or send a tele-presence robot out on the chores and stay in your jammies!
    edited 2014-11-11 19:57
    I'm ordering more.
    And selling more... You sir, are a menace!
    edited 2014-11-11 20:42
    Whit wrote: »
    At least I've learned to order all I want before posting. I've previously had some good parts bought right out from under me when I shared before ordering. Only after I hoard do I turn you vultures loose to feast on the leftovers. :)
    I still gotta figure a way to get my 5%.
    edited 2014-11-13 09:38
    I missed that initially. Very well crafted, good sir! I am indeed a paid professional InSultor.
    edited 2014-11-13 10:17
    This is the main reason I buy my hardware online.
    And they're not jammies; they're work clothes!
    edited 2014-11-14 14:14
    Duane Degn wrote: »
    Online? Impossible for most plumbing repair jobs from my experience. It's maddening staring at the wall of various fittings at Home Depot, trying to get all the parts, valves and NPT, street elbow parts to fit together for any particular application. Click & order will never replace brick & mortar (thank goodness) for most one-time jobs IMO.
    And no, I've never had any complaints about my PJs! I keep my drop seat firmly buttoned for the most part.
    edited 2014-11-14 20:42
    Boxers or Briefs?
    edited 2014-11-14 21:37
    NWCCTV wrote: »
    Boxers or Briefs?
    "Depends", said the old fellow.
    edited 2015-03-19 15:09
    Here are some nice ones already set up for continuous rotation, no modification required. Also comes with a 1.75" servo horn wheel. BIN two for $16, or you can win them in auction for ~$6 occasionally. I bought two and was impressed, they have nice slow speed control and when I hooked these cheap Ebay servos up to my cheap Ebay servo tester, they were PERFECTLY calibrated to stop in the center position. A very good sign!
    Spring RC SM-S4303R
    http://www.ebay.com/itm/231493244643
    edited 2015-03-19 18:46
    I have a pair of Spring RC servos and like them. They're geared down a bit, so the have 71 oz/inch of torque which I combined with higher traction wheels to give my Boe-bot some authority when it moves.
    My previous favorites were GWS CR servos that tolerated 7.2 volts. But these are a bit better.
    Martin_H wrote: »
    High praise indeed from Martin, the Master of Mechanical Mayhem! Happy to hear you concur.
