elev-8 rotates (yaws) on ground, then flips
My elev-8 quad spins(yaws) when under part (less than half throttle) no concrete surface. As soon as throttle is increased to take off, the quad flips. I have checked every motor direction and verified the prop placement and tripled checked the servo leads. I think one of the motors is spinning at a different speed thatn the others, creating a differential torque. Any help would be really appreciated.
First question, is this an ELEV8 version 1 or 2?
Have you done the ESC Calibaration? That is Max Throttle and Min Throttle Calibration ?
I have to log off for the night, but will check back in the morning.
- correct rotation direction
- correct CW/CCW propellers installed in a way they provide lift when they're rotating the right direction
- post a picture here on the forums so we can look at the propeller orientation
- double check your ESC wiring to the OPEN board (I know you've done this, but please check it again - I've seen this problem many times)
- confirm that you configured the board with the Hoverfly firmware update as an "X" configuration
After you reply to these points, I'll give some thought to the next step of troubleshooting.
Hang in there - we'll get you in the air and keep you there.
