Low Volume Assembly
JonnyMac
I designed a board for a friend and he'd like to get about 100 built -- too many for me to do in my shop. Any suggestions on reasonably priced, low-volume vendors? Mostly SMD, a few T/H connectors.
Cheap Prototype PCB Comparison
and this post
Cheaper PCBs
have been helpful to me in the past.
Hope this helps,
Marcus
http://www.asktechnology.co.uk/
They are in the UK, though.
For the last 15 years my go-to small run and prototype CM has been Assembly Line, Inc. in Brookings, Oregon. They're a small company that pays attention to detail and has excellent workmanship. Here's a link:
http://www.assemblyline.net/contact.html
My contact person is Mary Coston, 541-469-0696 for quotes and status updates. Very nice person.
Here's the last board they did You can see the mod on the back I had them do at the last minute on all 50 boards.
I tested and inspected each board and they were all perfect. And the assembly cost was much less than any of the other CMs that quoted. Also, I use them for single board prototypes because they're fast and do a much better job of soldering than I could ever do. I used to do the DIP proto board hand soldering but that no longer works. I like doing proto-type boards with test points and debug aids designed in but sitting outside a silk-screened perimeter. Inside the SS is something close to the final product.
High Marks for these guys..
Dom...
Don't let the name throw you, they are very good and have good pricing. You can get an online quote for full proto OR short-run or large run production. One of the nice things is they use a paper stencil that's only good for let's say a thousand (maybe more) boards. Whereas a metal stencil will last much more than that but cost $1,000. I've got one of the metal stencils but with board changes it's no longer useful. $1,000 boat anchor.
What works well for me is getting an online quote from SC and then another from Assembly Line. For the small boards I've seen here, including any of the Propeller boards, Assembly Line gives the most bang for the buck.
Dom..
