web service call from a basic stamp?????
Dirty Howi
I dont think this is possible, but as i spend most of my time being wrong about stuff thought i would at least ask.
basically i need a usb in/usb out stamp board to interface to a scale with, that would then send a signal to a previously defined web service to shift the weight from the scale into the service, i can do the math at the service level for conversion.
or am i just better off with a windows service to talk to the scale.
*dons flame proof suit*
Defintely need more info. How about bypassing the usb and use the
Spinneret Web Server, Product ID 32203, for your purposes? This would allow
access to the web, and may let you go around communication trial & error on the
code/circuit end on the USB side. I have not worked with it, but there may be code in
OBEX for your purposes. :nerd:
the scale that has been chosen for us has a USB output, i can wire this to windows programs via a HID interface that are readily available.
basically what we wanted was to be able to call a web service from a BS device (this allows us to possibly go blue tooth?) back to the waiting web application. basically as a call to the service that says the weight is now X, then it would pick that up and send it along to our euro partner and they send us back a label to place on the box.
i'll look into the webserver to see if it will work, basically the interface would just take the weight on the scale, and transfer it to the service.
noodling things out is all, wasnt sure if it was even possible.
Is there a interface device that i could plug the scale into, that either could host a small service or communicate with an outside service via a browser based application and either USB or network cat 5 cable attached to the base computer given that everything is hosted elsewhere (either in the cloud or ??)
I think I am getting the picture. You already have an interface, (HID), to a windows program. This may be simpler,
but designs in the future always change. The windows program (I assume) must poll the scale for info. If your proprietary
program for processing weight will not accept anything but from the Windows program, you may be locked into that.
Using the spinneret may solve problems in the future. Convert the USB to serial, feed it into the spinneret, and the
webserver could post the info, accessed from any device on your intranet. If you need diagnostics, that could be
programmed into the spinneret, to help with other inputs, if needed. More options are avaliable in the spinneret
for your benefit, reguardless if the windows interface program decides to die, at the busiest time. Hope you
are successful.
-Strategy is the heart of survival, and the soul of success.
as an aside, i'm writing all of it, (except the HID stuff, i just download that) but all the other services etc are pure ol howi.
Cheers,
Now, you have me hooked! I have got to go out and buy one! I did not see the
potential of the benefits of this until your problem arose. the spinnerete could be used
with a wireless device (Xbee) to be polled anywhere in the Plant(?). Cheap, simple, and
effiective, this process, when taught to other troubleshooters, and will let a problem
be fixed when you are not there. I wonder if this could be used for remote diagnostics?
The Parallax internet Netburner Kit looks interesting too. Thanks.
Also, there is a spinneret section in the forum about the instructions and projects made. The
instructions seem to be hosted by someone other than Parallax. Thanks.
Here are some projects that were winners in teh spinneret competition;
WINNING ENTRIES
First Place: Mike G - Multi-Socket Server
Second Place: Bean - Spinneret Embedded BASIC
Third Place: chillybasen - Opening a Door Via Text Message
HONORABLE MENTION
Jeffa - ePhidgetY Home Automation
bsnut - Wireless Web Based Shipping Monitoring & Control System
The wireless Shipping Monitoring & control system seems to be what you need. Might
be a good investment, in time, to review. Thanks.
use a Current carrier audio system. This would allow you to use the power wires to convey the
information you need. Power companies use this method. I do not know if any Parallax projects have
used this path. ?
