Capturing NIST signal with a Propeller? — Parallax Forums
RsadeikaRsadeika Posts: 3,877
edited 2014-11-13 05:41 in Propeller 1
Has anybody set up a Propeller to capture a signal from an NIST station? I wonder how much something like that would cost in materials, of course personal time is always for free for your own projects. Now I know that you could purchase a GPS receiver with an antenna and capture just time and date from that, but that is a ~$50.00 dollar purchase. Can it be done for less than $50.00 using a Propeller?
The reason I am interested in this is because I am experimenting with data logging that would have accurate and consistent readings. At the moment I am using an RPi to do that, which has an WiFi attachment, but the unit does not have its own internal clock so it relies on the internet connection. Well last night, in my area, we had a power outage, a couple of minutes of down time, plus the internet was out for about four hours. Those two combinations made my RPi useless in terms of providing the correct time. So I am looking for a way of providing an accurate, auto updatable time signal. Anybody have any workable ideas?
Ray
    edited 2014-11-01 04:28
    Rsadeika wrote: »
    Ray
    How about an extremely accurate TXCO RTC like the DS3231 etc + an ESP8266 WiFi for the occasional update maybe, all to be had for less than ten bucks.
  • RsadeikaRsadeika Posts: 3,877
    edited 2014-11-01 06:11
    Thanks Peter. I am still hoping for an NIST signal solution. I did an internet search and noticed that their are a lot of companies that are selling Atomic Clocks, with prices between $20 and $80, but I am not a gageteer where I could open one up and see if it is possible to solder in signal pick up lines. I have a Radio Shack Atomic Clock that I bought about twelve years ago, and it has not missed a beat. Since it needs new batteries once a year maybe, then I noticed it does take a little while to get itself updated. For my RPi I did notice that their are more RTC boards that are available, as a last resort I might have to go that route. But it would be neat if you could have a Propeller board for capturing the NIST signal and then make it available to other devices, your own personal NIST server.
    Ray
    edited 2014-11-01 06:28
    Rsadeika wrote: »
    Ray
    Those things are NOT Atomic Clocks even if they try to call them that, just because somewhere the signal is calibrated against an Atomic clock as are GPS signals etc. I'm not sure what you are needing this ultrafine precision for. Aren't the DS3231s extremely stable? They are based on trimmed and calibrated MEMS technology and the time signal is local, there, and ready all the "time".
    edited 2014-11-01 06:38
    I probably should of mentioned that "Atomic Clock" is a marketing description. My old Radio Shack clock is labeled Radio Controlled with no mention of "Atomic Clock" to be seen. Still thinking about an NIST server for the home hobby user.
    Ray
  • JDatJDat Posts: 103
    edited 2014-11-01 06:44
    Peter Jakacki! Look on this idea from different perspective. Diy NIST clock receiver and decoder. Similar thing to DCF77 receiver in Europe.
    edited 2014-11-01 07:05
    JDat wrote: »
    NIST covers a very limited area of the US and the coverage depends upon the ionosphere etc. Besides the ferrite rod is bulky and the whole idea of time signals is to get a stable and precise time, isn't it? Now if you have a extremely stable TXCO clock built in on your board then why would you ever bother with a WWVB receiver decoding NIST signals? Sure, there was a time when that was probably the best way and if you wanted to build such a clock just for the fun of it or didn't know any better then go for it. I know what I would do.
    Besides, this comes back down to the application as to what is really required. Is it accurate to the millisecond time-stamping? Or perhaps it's really to the tenth of a second or more.
  • max72max72 Posts: 1,155
    edited 2014-11-01 07:21
    If you have a reasonable GPS signal you can find a much cheaper GPS unit.
    The more expensive ones are more performing, but for clock sync this is overkill. Just don't expect the same navigation performace or time to fix.
    Another alternative with Spinneret is cited here:
    http://forums.parallax.com/showthread.php/151794-NIST-NTP-Code-for-Spinneret
    I guess a NTP solution for a serial to wify solution is reasonable too.
    Massimo
    edited 2014-11-01 07:26
    I am not looking for time-stamping to the millisecond value, I am looking for other ways of getting a time signal other than the internet or a GPS receiver. At the moment it almost looks like a Parallax GPS receiver module with an antenna might be a feasible way to go. You could have the Propeller dishing out the time via comm port, XBee, LAN port, or maybe even WiFi. From the RPi perspective, you would have to have some code to sync with your home brew Propeller Time Server. But now I am thinking that the prop1 may not be able to accomplish that, so, what, wait for the prop2, could that device even do the job?
    Ray
    edited 2014-11-01 07:38
    Rsadeika wrote: »
    Ray
    I'm implementing SNTP protocol on my Prop network servers so you don't need a P2 or RPi for this. However I would design a system that was stable in itself and when data is collected off that then the system's time would also be timestamped by the collector. It's an easy thing in software to compensate for an offset.
    edited 2014-11-01 07:40
    this might be a very cheap GPS solution...
    http://www.mouser.it/ProductDetail/Maestro-Wireless-Solutions/A2235-H/?qs=sGAEpiMZZMsjLMBIknjmkinf3subEiP4byj7tRuoHmI%3d
    Unless you are in a basement you should get the time, even with no fixing on position.
    It can be assembled also on a home made board using toner transfert (I did it with the discontinued A1035H module and it's doable).
    Massimo
    edited 2014-11-01 14:48
    SparkFun used to sell a board to pick of the clock signal.
    I imagine there are other boards like this one around.
    edited 2014-11-01 19:42
    Maybe the guy doesn't want cheap or whatever - he just wants to do his idea.
    Why can't people groove with that - or at least not be jackwagons?
    NIST covers a very limited area of the US...
    WWVB covers all of the "continental 48", Mexico, and Canada south of the Hudson Bay (excl. Newfoundland).
    http://tf.nist.gov/stations/wwvbcoverage.htm
    WWV and WWVH, on shortwave, have greater coverage areas (potentially world-wide).
    They use audible tones for top of the hour and so on, but the time of day data is coded using 100 Hz (0s and 1s corresponding to 100 Hz on-time.)
    Fundamentally, if you have a general-coverage receiver, with a decent signal and audio into a low-pass filter (or not) then you could time the length of the 100Hz occurrences and the rest is academic.
    You can get more info googling "WWV".
    Beyond this, I'm not "sharing" design info or code.
    edited 2014-11-01 20:03
    I agrtee with PJ. If the OP derives pleasure from receiving and decoding NIST time signals -- for whatever reason -- why try to steer him in other directions? It's about the journey, not the destination, after all.
  • caskazcaskaz Posts: 957
    edited 2014-11-01 20:07
    I had made radio-controled clock by LW.
    I used it for caribration of rtc.
    In Japan, there are 2-point(Fukushima:40kHz and Kyushu:60kHz) as transmitter.
    These cover all over Japan(from Okinawa to Hokkaido).
    Of course, time code is different with USA.
    edited 2014-11-01 20:08
    Now Phil you should know better than some who jump to conclusions. If the guy was building a NIST receiver then it would be about that. But the OP wants an accurate timestamp and we forumistas in general are not so blinked that we can only answer in the constrained terms of an OP's question. How many threads have gone on and on and on because they focus way too tightly instead of stepping back and asking the right question? So I am asking questions rather than assuming the old lady wanted to cross the busy road when in fact she was waiting for a cab!
    The OP may not be into hardware so presenting some options can only help.
    edited 2014-11-01 20:21
    I saw a couple boards on ebay which look like they do the same thing the SparkFun boards did.
    http://www.ebay.com/itm/High-Sensitivity-WWVB-Atomic-Clock-Receiver-Module-Fort-Collins-60KHz-Receiver-/231367674457?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item35de968a59
    http://www.ebay.com/itm/WWVB-Atomic-Clock-Receiver-Module-Fort-Collins-60KHz-Receiver-/331354144562?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item4d263eff32
    Both sellers are in the UK but it looks like they're selling the US version of the receivers.
    Edit: Apparently this site sells components for to receive these clock signals.
    edited 2014-11-02 02:45
    Thanks to everybody for the ideas and different directions one could go with this. I am still thinking about which way would be the best way to create the Propeller Time Server. The link to the kits that Duane provided look very interesting, an iron rod with copper wire wrapped around it for an antenna, interesting high tech.:-)
    I must confess, this all started with the thought of the actual Propeller chip being able to capture a signal wave. I thought I remember a post from a very long time ago where the Propeller was used in sending a signal wave or something along those waves. Actually I have not seen very many new Propeller hardware ideas, that is, actual use of the Propeller chip to do something different.
    Ray
    edited 2014-11-02 06:30
    Rsadeika wrote: »
    Phil did come up with a way to use a Propeller as a radio receiver.
    Rsadeika wrote: »
    Actually we have not seen very many new Propeller hardware ideas, that is, actual use of the Propeller chip to do something different.
    Oh, moan & groan. What's this "we" stuff? The Propeller audience?
    Here's a little something "from out of left field": You don't have to be able to play a guitar or sing to be a member of the Monkees Fan Club, but you should if you want to be recognized as a musician or part of a pop group.
    edited 2014-11-02 09:12
    PJ Allen wrote: »
    I got a WWVB reciever, I think it was like $20. The idea is to have a propforth dattalogger run off a supercapacitor charged by a solar cell. And understand that on some occasions, the rig will run flat due to clouds, snow, whatever.
    When the prop boots, it nottices that its time stampos not initialized. It listens to the WWVB unttil it gets the time, then adjusts its stamp accordingly. Since records are logged sequentially, we can always determine the time stamps for the uninitalized time records, no matter how long or how often thay occure (unless it rruns flat before it gets time). No additional RTC is needed, the prop code is accurate enough although it does drift fast and slow depending on temperature. Once it figures the offset, it get really close.
    Might be handy for data logging in an isolated location. Should be toatlly doable. Haven't actually built it yet, but no reason why it wouldn't work, all the parts are there.
    edited 2014-11-02 14:10
    I looked into this about a year ago when I was finishing up my Nixie clock. The Sparkfun WWV module had been discontinued for some time and I couldn't find anything similar. The British modules may have been around but I couldn't figure out how to order them in the US, I think their presence on eBay is new.
    If they work like the Sparkfun module the British modules would require quite a bit of lifting from the Propeller; they just output a presence-or-absence signal which would need to be error checked and interpreted. In that sense they represent about the minimum additional hardware needed to grab the 60 KHz signal out of the air and amplify it so you can work with it with a cihp like the Propeller. The instructions for reading the signal are straightforward -- it's not high speed so could probably all be done in C or Spin without difficulty. But I did read of people having "adventures" with the Sparkfun modules, such as not being operable during the day (develop at night only!) or in one case not being operable while the development PC was running nearby due to interference.
  • VIRANDVIRAND Posts: 656
    edited 2014-11-03 21:53
    I've thought about it but not done it.
    It is interesting that most Propellers (as far as I know) use 5Mhz crystals which could
    be convenient to feed a direct conversion receiver circuit because WWV is on that frequency and harmonically related ones.
    It might also be very easy to get WWVB on 60 KHz, if you can get / make a sensitive resonant antenna loop for it.
    The format is different on that frequency. (I think there are two binary codes.)
    It is my observation that all the NIST time signals seem to come in strong at night but very weak during the day, in New York.
    The formats also have changed slightly over the years but usually not enough to make radio controlled clocks obsolete.
    At my location I can also always hear CHU from Canada on 3.33 MHz, it talks, beeps, and sends 300 baud digital time.
  • tomcrawfordtomcrawford Posts: 1,129
    edited 2014-11-05 10:51
    I had wanted to use WWVB for a clock, but couldn't find a receiver. As has been pointed out, Sparkfun discontinued theirs. Now Duane goes and finds some from England, of all places. So of course I ordered one and of course, haven't got it yet. So I built a simulator in spin. I believe it transmits valid WWVB AM data. I am now working on a decoder that runs on BS-2.
    Edit: I used a prop rather than BS-2. This thread got sort of "anti-hijacked" to
    http://forums.parallax.com/showthread.php/158053-NIST-WWVB-WWV-WWVH-amp-Propeller
    edited 2014-11-05 19:29
    I'm feeling so flush with cash that I bought two.
    Since round-the-clock reception isn't likely, some sort of fairly accurate clock is still necessary, I think.
    The WWVB would be used to update/correct that clock (as most of the wall-clocks we see out there do.)
    edited 2014-11-05 19:55
    PJ Allen wrote: »
    Yeah mate, that's what I've been hinting at and in fact those wall clocks probably drifted by several seconds or more until they could get a signal again, and then that signal depends a lot upon interference and position etc. Unless there was an indication on the clock for how long it has been without synch then there is no real way to totally rely upon it other than having that warm and fuzzy psychological peace of mind that it's an "Atomic" clock :) Whereas if you have an extremely accurate TXCO RTC like the DS3231 then you might lose or gain a couple of seconds per month which tends to even out anyway. The other obvious advantage of the RTC is that it works out much cheaper and there is no need for mounting a bulky ferrite rod somewhere suitable with a good signal and away from interference.
    Don't get me wrong, I like the idea of a NIST receiver although we don't have anything like that here in Oz, and I think it would be fun to get the Prop to be the whole front end of it as well as the decoder. For me to test that out though I'd have to build my own NIST transmitter, low-power at least, which could be fun too and I think the Prop could handle that at 60kHz. But I think if I built a time server I would just use GPS time signal because it's easy to pick up GPS modules for $10 on ebay. Maybe I will, and then I can use ISM bands or those ESP8266 WiFi modules to distribute the time signals around the area.
  • KMyersKMyers Posts: 433
    edited 2014-11-06 11:22
    Dont want to hijack this thread so please excuse this post. In the old days here in the US most PBS stations carried a time signal in the VIT's portion of video. Some vcrs used this to stop everyones clock on the vcr from flashing.
    Now that the broadcasters are digital and I have been out of the loop for 10 years this might not exist today. It would take someone with a demod and delay scope to look at the signal. Could be more reliable then trying to receive distant HF signals without suitable antennas.
    Carry on and ignore this comment...:lol:
    edited 2014-11-11 15:26
    max72 wrote: »
    Since PJ Allen has a thread devoted solely to reception of NIST broadcasts, I'm taking license here to mention yet another GPS module.
    This module has a 1pps signal pin to which a wire can easily be soldered. Various comparisons to much more expensive time references has shown this inexpensive module's 1pps signal to be amazingly accurate and consistent, far more so than you'd expect from a cheap HobbyKing board.
    Meanwhile, I've never been happy with clocks that used just the NMEA serial data stream. Even clocking on the leading edge of the start bit of the first character of an RMA message, the timing is "all over the place."
    Pretty hard to beat 12 ns accuracy for anything close to $17.
    edited 2014-11-12 07:30
    User Name wrote: »
    Since PJ Allen has a thread devoted solely to reception of NIST broadcasts, .....
    While interesting solutions, none of the GPS solutions presented are capable of capturing NIST, so must be disqualified. Although I now have to buy some, and make a non-NIST project, as soon as I finish the NST project, otherwise my workshop will look like erco's without all the working robots.
    Regarding clock drift, what IMPACT will a few seconds drift have on any given project, particulary where NIST was selected in the first place? Its not a GPS project (otherwise we would have STARTED with GPS). We got by for thousands of years with "about noon" and "near sunset" level of accuracy for most things, and that hasn't turned out too bad (relatively speaking).
    I suggest that if one has an application "off by a few seconds" is fine, we can use NIST to set the clock, and the prop itself to keep time, and it will me more accurate then most folks can manually set in the first place. And it will automatically get the correct time. Now to build it and check it this is true.
    edited 2014-11-12 07:56
    To be fair the original post talked about a solution cheaper than a 50$ GPS based solution, so I guess a cheaper GPS solution is still acceptable...
    Massimo
    I am lurking my own thread, still not sure which way I will be proceeding. I am also lurking the PJ Allen NIST thread to see what they come up with; I am now starting to get the impression that the ferrous antenna attachment might be a problem as to where and how it should be placed, for my intended project.
    Ray
