Is there a Propeller hardware connection guide? — Parallax Forums
Jeff HaasJeff Haas Posts: 433
edited 2014-10-31 21:59 in Propeller 1
I have gone through all the Propeller docs and links in the sticky post at the top of the forum, and I can't seem to find a document that is a "Quick Guide To Hardware Connections for the Propeller".
What I mean is the doc would be a reference guide, organized something like this, where each topic gets a page or so:
1: Connecting Switches
- Description and schematic for hooking up a push-button switch (Does it need a pull-down resistor to GND or...?)
- Short code example for reading the switch input, plus how to debounce
2. Using a relay
3. Reading a Potentiometer
4. Displays - LED and LCD
Etc.
It would cover all the basic components, like the Basic Stamp help does. There is a bit of this on the Microcontroller Kickstarts page, but only for a few parts. Also, when I try to go a lot of the websites or docs linked in the sticky post at the top of this forum, the links are dead, including links to sections of this website. Was the Propeller Cookbook this type of reference? I can't seem to find it anywhere.
I'd like to learn to use the Propeller, but this is making setting up the basics hard. The manual is good for programming the chip itself, but after that, it's tough. Have I missed something?
  • LeonLeon Posts: 7,620
    edited 2014-10-31 02:09
  • pik33pik33 Posts: 2,417
    edited 2014-10-31 06:12
    There are application notes for the Propeller numbered from AN001 to AN019 - they can be found with Google (how to find them easy???) - they described how to make different things with this chip.
    edited 2014-10-31 06:27
    If you go to the Parallax site, choose SUPPORT then DOWNLOADS, do a search in the Download Title and use AN0 (zero). That should bring up all the Application Notes for the Propeller.
    edited 2014-10-31 07:12
    Jeff Haas wrote: »
    Jeff,
    I keep a list of links in my "index" (which isn't alphabetized). There's a link to this index in my signature. I think you'll find many of the same links in my index as are listed in the sticky thread but I try keep all the links in my index up to date. Post #3 has links to many Propeller tutorials. I'll check to make sure the Propeller Cookbook is included in the list. If it's not, I'll find it and add it the list as well as to this thread.
    edited 2014-10-31 07:25
    I used Rich's search tool (there's a link at the top of post #1 of my index) and searched for "Propeller Cookbook".
    Here's the link.
    I also added the link to post #3 of my index.
    While many of the Propeller resources aren't organized as well as some of us would like, if you can't find something after using Rich's forum search or using ctl+f to search my index, then ask on the forum. There are lots of people willing to help find the information you're looking for.
    edited 2014-10-31 07:33
    Unfortunately www.ucontroller.com is gone, but Jeff, (Oldbitcollector), may have moved the contents to some of his new sites.
    edited 2014-10-31 07:40
    This link still works for the Propeller Cookbook.
    https://sites.google.com/site/jeffledger/PPDftBv14.zip?attredirects=0
    edited 2014-10-31 09:44
    Wow, I had forgotten about the Propeller Cookbook. That is an excellent guide for same typical hardware usages with the Propeller. Also, the Hydra Manual was an unbelievable resource for me to learn more about how the Propeller hardware works for video, etc.
    edited 2014-10-31 09:53
    Wow, I have been wondering where the cookbook got to for a long time. There have been so many questions from those new to the Propeller that can be answered by pointing them to that document.
    How come it's not a download from Parallax?
    edited 2014-10-31 10:08
    Heater. wrote: »
    I'll see if I can get that back in the stickies.
  • Jeff HaasJeff Haas Posts: 433
    edited 2014-10-31 10:24
    Thanks everyone for the quick response! The cookbook is the kind of document I was looking for, although it still is a bit disorganized.
    But this is a great start, and I appreciate the effort to update links and find documents that have wandered off their original web sites.
    edited 2014-10-31 17:51
    OMG.. The Propeller Cookbook is ancient..
    A better organized update to it has been on my "todo" list for a while now. Pushing it up my list a bit..
  • edited 2014-10-31 21:59
    pik33 wrote: »
    There are application notes for the Propeller numbered from AN001 to AN019 - they can be found with Google (how to find them easy???)...
    From www.parallax.com click on Support and then click Downloads. In the search screen, enter AN0 in the Download Title text box. You'll get a list of all the application notes from AN001 thru to AN019. A couple ( 16 and 17 ) never got published for some reason.
    Sandy
