StingRay
There is some basic problem with my Stingray that as soon as i plug in the USB cable and load any program both its motor rotate forward, also the program loaded does not work and on reset the loaded program does not work. may be i am doing some very basic mistake because it is happening with every program.
You need to use F11 to load the EEPROM so it will be there the next time you power up the device. When loading to RAM, the program is lost when you power down.
Make sense?
Did you try the motor test programs included in the docs?
