HX711 strain gauge amp with 24 bit serial o/p
tritonium
Hi all
Just come across this
http://www.ebay.co.uk/itm/HX711-Electronic-weighing-sensor-module-24-bit-Dual-channel-ADC-Rasp-Pi-Arduino-/141361163400?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item20e9c82c88
HX711 24 bit strain gauge amp with digital serial o/p.
It has two sets of differential inputs (selectable) which I would think could be used as a voltmeter with 24 bit accuracy with the right input conditioning.
+- 20 mV for full scale reading
There must be all sorts of uses other than the actual intended one and for this price sounds like fun.
Has its own serial protocol for the bitbangers amongst us!
Dave
Dave
To use this as a volt meter are going to want to divide everyday voltages (1v to 1000v full scale say) down to 20mV. With your typical 0.1% precision resistors you are are throwing away most of that 24 bit, or one part in 16 million precision of the ADC.
Down at microvolt levels like that noise is going to be a problem.
