High Speed Multi-Prop to Prop Communication_v2 by Beau — Parallax Forums
BTXBTX Posts: 674
edited 2014-10-15 09:46 in Propeller 1
Hi all.
I just need to communicate many props in high speed.
Using the Beau code works fine and more, that's perfect for me !!! (Only for short distances)
But I should send the signal, from a prop to another prop, about ten meters long. I usually do that using LVDS chips fine (parallel communication), although in this case, this Beau code needs to be bidirectional, it's too much for me to modify that code, so, maybe somebody get me go by the correct way to swicth the LVDS chip in RE & DE mode easily ...Touching the code or ....??? ideas.
The LVDS chip I'm using is the DSC91C176 (is like a 75176 but faster).
Any ideas from genius :)
