Propellor BOE USB Port
seekerofthetree
I needed some clarification on the USB port. I hook up a power source to power the board through the USB but it does not light the board up. Do you need to hook up a 9V and then have a 5V through the USB going to power it? Kind of confused about this.
Thanks!
Thanks!
Is this USB connection power only? If so, I'm not sure if the Propeller BOE can be powered this way.
I know on the QuickStart board, there's a pin which needs to be tied to ground in order to use power only USB cables. I don't think there's an easy way to do this with the PropBOE.
Generally servos draw too much current for either a 9V battery or USB.
I'm not sure I'd call this "really simple".
How are the steering and drive motors controlled? What are their voltage and current requirements?
This will depend on the voltage and current requirements of the car and how much current your "USB battery" can supply.
What is "it" and what "small chip" would you use?
