Robot for BBQ smoker
landonmay13
I am trying to make a robot that covers and uncovers a vent the size of a half dollar on a BBQ smoker at a push of a button. My plan is to have something that sends wireless signals to whatever is needed, and that is connected to a servo which has the command to cover and uncover the air vent. I need a servo and an motherboard though, and I am wondering if I can use parts of my old activitybot kit, or if I need to buy new parts and make my own robot.
Thanks!
-landonmay13
Thanks!
-landonmay13
Make your vent so it can swing open and closed. Then run some kind of linkage somewhere away from heat. If the linkage moves easy enough a standard servo should work fine.
Something like this would be neat too - http://www.tlxtech.com/solenoids/high-temperature-solenoids/
Success here will depend on if area around the dampers (that's what they're called) gets very hot. If so, you'll need to get fancy with some mechanics to place everything away from the heat. Such a mechanism is commonly found in hobby stores catering to the RC biz, so there's plenty to choose from.
You need: two radio transceivers such as Xbee, at least one microcontroller and possibly two, the servo, and assorted mechanics. Pretty expensive. You might instead look around at a thrift store or garage sale for someone selling an old and cheap radio controlled transmitter and receiver. It'll have everything you need except the servo and mechanical linkage, and maybe even that if the seller is getting rid of his old junk. All this is manually (but remotely) operated, but you didn't mention needing a sensor to determine when to open or close the damper(s).
Will this radio transmitter/reciever do?
http://www.homedepot.com/p/NuTone-Hand-Held-Remote-Control-Transmitter-and-Receiver-RCK01/202851042?cm_mmc=Shopping|Base&gclid=CjwKEAjwwo2iBRCurdSQy9y8xWcSJABrrLiSk2TbIZ_7RKtDsSG7Cbwcu0FtQexmJ2X6_sjNCyo9mhoCp1jw_wcB&gclsrc=aw.ds
If that does does not work, will these transceivers and microcontrollers go together?
Microcontroller: http://www.robotshop.com/en/arduino-uno-usb-microcontroller-rev-3.html?gclid=CjwKEAjwwo2iBRCurdSQy9y8xWcSJABrrLiSHgmfp97ZbF87jTFGKsp_fYf7tAThlVtHBAui0BpirBoCNXTw_wcB
Transciever: https://www.sparkfun.com/products/11215
Lastly, I have a servo left over from my Activitybot, will that be ok to use?
