Serial Repeater — Parallax Forums
Serial Repeater
Mag748Mag748 Posts: 269
edited 2014-10-10 15:34 in Propeller 1
Hello,
I made this simple propeller object that may be of some use to some of you. From the description:
Serial Repeater for use with FullDuplexSerial Object
This object runs in its own cog and passes data back and forth between two
FDS ports. The purpose of which causes the propeller to appear transparent
when communicating to peripherals from a host computer. The data from
both the host and the peripheral is buffered in a queue that can be accessed
by the propeller at any time. Since this runs in a separate cog, the Prop
can function as it normally would to send data to the host and peripheral.
See attached object and DEMO. I am currently using this to play with the ESP8266.
Marcus
Example using the Parallax Serial Terminal:
Serial Repeater Demo - Archive [Date 2014.10.10 Time 13.53].zip
  • JonnyMacJonnyMac Posts: 9,834
    edited 2014-10-10 12:17
    I did something very similar the other day. I'm doing a project with a Noritake 24x6 Serial VFD and found a program on their web site that would send serial data to demonstrate features. The program conveniently provided all the raw hex codes as it demo'd the selected feature. I was able to test all the features of the VFD and updated my driver as I did it.
    pub main
      vfd.start(13, 14, 15, 115_200)                                ' start vfd uart
      term.start(RX1, TX1, %0000, 115_200)                          ' start fds
      waitcnt(cnt + (MS_001 << 1))                                  ' let cogs start
      term.rxflush                                                  ' flush terminal buffer
      repeat
        vfd.tx(term.rx)                                             ' copy input from CUE to VFD
    Mag748 wrote: »
    Hello,
    Marcus
    I have used a simple loop method which just echos one pin to another so it's not dependant upon baud rates etc. Even in Spin this will probably work fine but in PASM it's only a few lines of code.
