P8X32A Propeller Datasheet v1.4.0 - MULtiply instructions? — Parallax Forums
John A. ZoidbergJohn A. Zoidberg Posts: 514
edited 2014-10-09 05:37 in Propeller 1
From the datasheet dated 14/6/2011 - there are grayed out MULtiply instructions in the instruction set list, and it means that it is implemented in the future. I'm curious that is it for the FPGA variant or are these present in future batches of Prop 1?
I'm certain that back in 2011 the Verilog code for the Prop 1 does not exist yet for open-source. So I believe that it could be for the future batches of P1.
But, it's 2014 now and is there any news about these instructions? I've been longing for a Prop with at least a multiply instruction inside. :)
    edited 2014-10-08 03:00
    I'm very sure there is no multiply anywhere in the current P1. It's just one of those things that never happened, like the mythical port B. It's almost certain that if there were a multiply in the design pipeline it would have shown up in the open source Verilog code for the P1.
  • ozpropdevozpropdev Posts: 2,793
    edited 2014-10-08 03:06
    The multiply opcode was allocated but never implemented. The PropTool recognizes MUL,MULS,ENC,ONES and generates the
    correct opcodes though. In the Verilog P1 MUL/MULS have been implemented and also are being used for other experimental instructions.
  • Mark_TMark_T Posts: 1,981
    ozpropdev wrote: »
    Just had a thought - rather than being cog instructions perhaps the multiplier could have been
    invisaged as a pipelined unit in the hub, with a 2-clock overhead and 16-clock latency - then each
    cog could issue a multiply when its hub slot comes by and collect the result next time....
