A call to arms, to ARM or not to ARM — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2014-10-08 10:32 in Propeller 1
Here's a bit of a call to arms for anyone for all those who have an interest not just in Forth, or an SDFS and/or network empowered Prop without having to have memory expansion "cards" or an RPi etc with all that minimal hardware implies for general embedded use.
As you know I have been steadily adding functionality to the Prop even though it seems underpowered from the ARM world or even from a C standpoint. At this particular point I have pretty much everything that would make it a stand-alone development system as well as an embedded target, I even have an assembler that with a tweak could do multi-pass assembly from file so it's possible to assemble and run objects at runtime even, a different slant on my "embedded runtime OBEX". Perhaps I could compile the kernel this way too (yes). The system doesn't just rely on SD cards either as this works with tiny SPI Flash too so a bare minimum Prop system only needs a cheap SPI Flash to be empowered. It doesn't matter what language an OS is written in does it? Or does it? Does it do the job I thought was a far more pertinent question and for which I do know the answer.
Of course the 32K memory limitation affects video display but I even have a VGA text object that only requires 2K RAM for the image which is reused as the video buffer after the cog is loaded. So with a PS/2 or serial keyboard/mouse, VGA display, SDFS FAT32, Ethernet servers and clients we have an embedded system that is also a development system in what is essentially an unexpanded Prop.
But there are lots of little things needed to tie this all together now but I don't know if it is worth it. Putting aside the promise of "P2" I wonder if there is any real further interest in P1 itself, it seems as if the Prop community has fallen flat, there does not seem to have been any real developments and the forum seems to be much ado about nothing in particular. Like the Constantinople charioteers the focus is on the "colors" while the empire crumbles and decays around them, any seeming victory is illusory and actually a symptom of the decay.
I can see busy bees off in their little corners trying to make honey but for the lack of a hive it won't thrive. Even in the fragmented Forth community it's just bits and pieces without any general direction or application, and yet there is so much talent here. So I've been battling my own problems that one or two of you forumistas may know a tiny bit about but all the while I keep trying to contribute and document as much as possible if not practically all, back to the community, which then takes up even more time and effort. I don't even hear crickets somtimes. Is it worth it? Is anyone really interested? If we are then can we work in together more openly?
The alluring tug at my arm as been ARM itself but this is the call to arms I'm talking about, work together and thrive or limp along under our own colors. The Propeller chip needs focus now for both P1 and eventually P2 to grow into more than just hobby projects for Parallax to have a future as a chip company for us to have a future with the Propeller. We, that is meaning "us" as the Prop's ardent ambassadors need to be contributing in a meaningful way and if we all bring something yummy to the picnic we are all going to be sure and certain that we come away full and satisfied and that is something I am very much looking forward to!
«1345
  • LeonLeon Posts: 7,620
    edited 2014-10-05 03:30
    Just include an ARM on the chip, as XMOS has done with their XA family:
    http://www.xmos.com/products/silicon/xa-series
    You then get the best of both worlds.
    edited 2014-10-05 04:00
    Peter,
    You have presented a lot of thoughts there to digest. Can I distil the main point down to:
    "Anyone interested in a stand alone, self hosting, Propeller development system?"
    and hence:
    "Anyone actually interested in helping with that?"
    With that as the focus a few comments:
    You have made super human efforts in that direction. Believe it or not, despite my views of your chosen language, I do follow you developments with admiration.
    As an interesting exercise and challenge, creating a self hosting system is a great idea. It's certainly one that Chip himself has expressed a desire to achieve on occasion. That was sort of part of the motivation behind us getting Z80 emulations and CP/M running on the Prop all those years ago. With a simple OS and file system one could imagine creating assemblers or even higher level language compilers for the Propeller itself.
    Over in Germany the guys building the Hive project have done it already. They don't get much coverage here, perhaps because all their web pages and documentation are in German.
    But what about practicalities?
    The Prop is small and slow. So any such self hosting system is necessarily limited.
    To use such a self hosting Propeller you will need at least a keyboard and a screen. At that point you may as well hook it up to your PC, laptop, pad whatever. If you do that you have no need for the Prop to be self hosting, you already have a machine that will run any tools you need.
    As such the whole concept has limited appeal to the general user. It's just adding complication.
    I really don't want to go there:) I agree however that it should not matter as long as it works AND as long as it does not dictate language choice to the user.
    ...is any real further interest in P1 itself, it seems as if the Prop community has fallen flat
    Seems to me a lot of the high fliers have flown off into hacking on the P1 verilog code for their FPGA's
    Us others are still very much into the P1 itself. In recent months we have seen a web based IDE for the P1 created. We have seen Props being programmed from cheap off the shelf WIFI routers. Etc. Perhaps these are "fluff" around the edges rather than actual projects running on the Prop but still they are Prop at heart.
    The alluring tug at my arm as been ARM itself...
    For me it's not the ARM itself that is the tug. Rather it's that I can run Linux on something very small and cheap. Be it an ARM based board like a Raspberry Pi or a tiny $20 MIPS based WIFI router.
    edited 2014-10-05 04:55
    I think you're correct that the language in which an OS is implemented does not matter as long as it doesn't force me to use the same language for writing programs that run under the OS. You mentioned that you have an assembler that runs under your self-hosted environment. Do you have any other languages? Is it possible to add Spin? I suspect C or C++ is probably out of the question. In any case, I guess all this depends on whether there is really a demand for self-hosted environments on the Propeller. While I find it intriguing to think that would be possible, I don't really see any practical use for it. I would like to be able to use an on-target interpretive language to poke at the hardware interactively, I don't think I'd want to develop a program of any significant size on the target hardware. Also, you ask for help in finishing this self-hosted environment. I assume anyone who offers to help would be required to use Forth. After all, the environment itself is written in Forth, right? So, in that case, I don't think I'd be able to contribute much since in my limited time I've only been able to learn a little Forth and certainly not enough to be very productive on a real project.
    On a more general note, I also am worried that activity on the forums seems to have slowed significantly. One of the reasons I have stuck with the Propeller for so long is the active community I found on these forums. I would hate to see that go away.
  • MJBMJB Posts: 1,235
    edited 2014-10-05 05:21
    Heater. wrote: »
    What I like in Peter's approach is that I have complete access to the whole 'Operating System'.
    I can read all the source code, I can step through interactively and experiment with the part to gain understanding.
    And if I spend enough effort I can understand and then even change the thing to my liking.
    Of course this is true in general for a linux insider as well.
    You can read all the source code, you can study the compiler and you can change it.
    But this seems a quite complex endeavour -
    while with Tachyon-FORTH by the very nature of the system this is quite easy -
    or how could you have all the functionality in Tachyon running with just a 64k EEPROM in 32k RAM.
    Regarding the 'Standalone Development System' ...
    I do not see a need for it. Even if it could be done, I would in general prefer to just plug a Prop-Plug in from my
    Laptop - or use a cheap Bluetooth module wit the tablet, or dial in via Telnet ...
    Having a KBD & mouse & display might be interresting for application purposes in it's own right -
    but not because I need a standalone development system.
    The COMPILER thing is an other area. I think this is mostly useful, because there is no
    PC-based compiler for the full tachyon system available. And this makes it a little tricky to use different tools
    to create the PASM modules to be loaded into the Tachyon system to make even more effektive use of the
    multiple COGs.
    The idea of having a kind of OBEX on SD card with modules that can be loaded at runtime is a great way to expand the system.
    imo this should be acompanied by a Tachyon OBEX on the web, where the community members can share their code pieces and modules.
    A few minutes ago I was looking how to interface Tachyon to a Nokia 5110 LCD display - I had a faint memory of it having been discussed - and searching the Forums I found a few discussion fragments - even for Tachyon -
    but there is no place to look for the results of those exchanges.
    Should we put Tachyon pieces on the regular OBEX ?? or somewhere else?
    so much for today ...
    edited 2014-10-05 05:42
    MJB wrote: »
    Unfortunately, with my limited knowledge of Forth and Tachyon, it would probably take me longer to understand one page of Forth than 100 pages of C/C++. :-)
    I know I could spend more time with Forth and get more proficient but I can't see that knowledge being transferable to any other system. I admire what Peter has done with Tacyhon but I don't want to adopt it as my primary development language.
    edited 2014-10-05 05:49
    Leon wrote: »
    That looks like what I was hoping Parallax might do instead of P2. Use COGs as "intelligent peripherals" and an ARM or some other more traditional core as the "application processor". Unfortunately, it doesn't look like the XA series is actually available yet. I get "contact marketing" if I try to buy it.
    edited 2014-10-05 06:10
    MJB,
    What I like in Peter's approach is that I have complete access to the whole 'Operating System'. I can read all the source code...
    I do agree. It's great to have systems like that. Something you can study and learn from in a reasonable time. Something you can tweak and hack on to your hearts content.
    For sure this is not possible with Linux. Nobody has the time or capacity to understand all of it. That's just the kernel never mind the user land programs never mind the compilers etc. Although it is possible to write simple Linux drivers without a life time of experience and study.
    Thinking about it, when I said "Rather it's that I can run Linux" even that is not quite correct. Linux is not the main point here. Could probably as well be BSD or Minix or whatever else. Point is it has all the facilities for running familiar tools like editors, IDEs, git etc. It has all the netwoking and file system facilities you need. And so on.
    David Betz,
    I have noticed that as well. What is going on? It cannot be that everything a Prop can do has been done!
    edited 2014-10-05 06:22
    Re: XMOS with ARM.
    Be aware that the XMOS device linked to is not actually an 8 core device.
    It is an 8 "logical core" device. That is to say a single core that can run 8 hardware scheduled threads. It's built such that the speed of each thread is constant as you use from 1 to 4 threads, after that thread performance drops with the addition of each new thread. Mind you, given the speed of the thing for a lot of the time, up to a point, that is indistinguishable from 8 cores.
    Also note that the XMOS cores only have access to 64K RAM. That's for all of them.
    Also note that chip comes in a 256 pin BGA package! Do you really want to deal with that?
    I'm hoping that the P2 will stack up quite well against the XMOS devices of similar price.
    Having a little ARM core on chip is fine and all but if its not got the chops to run a full up Linux then there is little point from my point of view.
    Real time cores plus and ARM may well be the "best of both worlds" but I think many would see it as just stacking up the complication of both.
    edited 2014-10-05 06:29
    David Betz wrote: »
    right - this is the critical point here -
    of course you COULD have a high level language compiler that compiles to Tachyon codes ...
    but practically I think you are right
    to work with Peter's Tachyon you have to adopt this as your development language.
    This also means you are based on the very small Tachyon community for new device drivers and code snippets ...
    or you have to do it yourself - as Peter is doing it.
    This will propably not be the approach that very many will take - what a pitty for them ...
    it took me quite some time to adapt to Tachyon - I still read BASIC and even C faster ...
    You know LISP, so you can value the flexibility that a FORTH gives, to change everything,
    that you do not get in any classic procedural language.
    Tachyon + PASM:
    I think this is a great combination with Peter's new Tachyon embedded Assembler.
    Where you can assemble new PASM code modules INSIDE a running Tachyon system.
    Save them and load them to a COG.
    A flavor of STANDALONE - which can easily be used with a device, that provides Display and Keyboard -
    whatever this will be - connected via serial / LAN / WLAN / Bluetooth ... whaever you like.
    I rather have a Laptop or Tablet with me than a spare Keyboard and a VGA-Display ...
    e
    edited 2014-10-05 06:36
    Heater. wrote: »
    Re: XMOS with ARM.
    Is that worse than the P1 where 8 cores share 32K of RAM? I think that the XCore can directly access all 64k rather than being limited to only 2K.
    I would certainly need a development board or at least some sort of breakout board to make use of a BGA chip.
    I hope so. I'm still a bit worried about the code density issue. We "solved" that to some extent in PropGCC by Eric's CMM mode but that will be far less appealing on the P2 where hub execution allows fast execution of native PASM from hub memory. The difference between the speed of code executed directly from the hub and a CMM interpreteter will be far greater than the difference between the current LMM and CMM modes. I keep thinking in the back of my mind about whether it would be possible to implement CMM or something like it in hardware. Now that we have P1V, it would be possible to experiment with doing that although I'm far from sure I have enough HW knowledge to pull it off on my own. At least a CMM-in-HW would provide better code density and make better use of 512K of hub memory. We all get excited about that much hub memory but we have to keep in mind that other processors have far more on-chip memory.
    I'm not sure Linux is really required for all applications. I get quite annoyed that most of my devices (dvd players, tvs, etc) take so long to "boot" these days. This is a direct result of running Linux. While I like Linux a lot, I'm not sure it is really needed in all embedded applications.
    edited 2014-10-05 06:38
    In my opinion, a stand-alone development system on a Prop is a novelty, and not really of much practical use. Of course, that doesn't prevent many of us from spending time adding new widgets to our own OSes. There are some practical aspects to these OSes, where portions of them can be used for a specific application. As Leon said you could just add an ARM chip along with the Prop, which would allow running a real OS. However, it's fun and challenging to try to create a stand-alone system in a minimal amount of hardware.
  • ozpropdevozpropdev Posts: 2,793
    edited 2014-10-05 06:45
    I'm confident that the P2 will open the "flood gates" of forum activity in both FPGA test form and eventually real silicon.
    Like many others I've been caught up in the P1 verilog stuff.
    While it's been a "BIG" distraction it has reinforced my appreciation of Propeller 1 :)
    Starting a new project tomorrow and Propeller will be specification #1.
    I like Propeller's because they make me appear smarter than I actually am! :lol:
    edited 2014-10-05 06:51
    David,
    Quite so. The P1 is not really comparable to the XMOS. Much slower, less memory and so on.
    I'm hoping the PII is a lot more of an XMOS peer.
    Linux on embedded systems running from FLASH, like WIFI routers, should not be taking an age to boot.
    I agree that Linux is not required on all embedded systems. Especially when handling real-time events. But given that it now runs on things the sized of an SD card or an ethernet socket it is finding it's way into all sorts of places.
    edited 2014-10-05 06:59
    Small ARM cores like the Cortex-M3 used on the XA won't run Linux, of course, but there are many real-time kernels that are available. ARM is even developing an OS themselves:
    http://mbed.org/
    edited 2014-10-05 07:31
    mbed is another attempt to grab the IoT future. Designed to use with servers run by ARM. No thanks.
    It can be used with your own servers apparently but if you are going to do that why use mbed in the first place?
    edited 2014-10-05 07:33
    Getting back to Peter's original post, I'm wondering if he could describe in a little more detail the system he's proposing. In particular, I'd like to know what languages he plans to support for self-hosted development. As I said earlier, I don't really care what language the OS is written in but I do care if I'm forced to use that same language for my own application development.
    Peter: What are the languages you plan to support for developers using your system?
    edited 2014-10-05 08:00
    David Betz wrote: »
    while Peter is asleep, let's think about it:
    - the OS is TACHYON.
    - there is an embedded PASM like assembler with some syntax tweeks to make it easy for Tachyon to parse it.
    - the assembler can be used to convert PASM source from file to loadable modules to be loaded to free COGs.
    - the main COG is running TACHYON
    - other COGs might be running Tachyon as well to execute parallel tasks, handle drivers ...
    - some COGs can be dynamically loaded with prepared PASM modules to run timecritical / driver etc. code
    the HUB RAM is basically managed by TACHYON, some sections can be allocated to be used by the PASM COGs.
    so how would other languages fit in here?
    could they coexist in this framework - and if so how?
    would it make sense to do so?
    for having a really self contained system you would need a compiler for the other Language, that would need to run in
    Tachyon - hmmm
    so write a C-Compiler in Tachyon ?
    would it compile to Tachyon byte codes?
    or directly to PASM ?
    ---- I don't think you would get this from Peter ...
    how would other highlevel languages coexist with Tachyon?
    would they be able to 'call' the OS-functions provided in Tachyon ?
    actually I can't see a practical model for another high level language on top of TACHYON.
    Memory is practically full now with SDFS/FTP/TELNET/WebServer/Email
    of course if you had a PASM COG module, created from any language, that will accept the
    conventions of the Tachyon system, I see no reason why they should not be loadable to a COG.
    ... and still ... would this make any sense ??
    just my thinking ...
    edited 2014-10-05 08:12
    Well, if this is the case then I think Peter's original question about "does it matter what language the OS is written in" is pretty much irrelevant. The question really is "does it matter what language users are forced to use to write software for the platform". In that case, I say that it does matter. Having only the options of Tachyon Forth or PASM seems to limiting to me. Neither is a mainstream language.
  • WurlitzerWurlitzer Posts: 237
    edited 2014-10-05 08:16
    While my preferred choice of a programming language has not, nor probably will never be implemented for the Prop, I just used what was avail in Spin, and PASM (hard to get any faster than that in a Prop) and devoted my time to actual projects and not chasing the elusive perfect OS, App, programming language because everyone has their favorite and everyone hates something else.
    When the prop is running, the average user could care less if the program was written in C, TACHYON, or Klingon!
    I for one have no desire to create something which can be ported into an inferior, IMO, chip like the R-Dweeb-No, or some other Microcontroller.
    edited 2014-10-05 08:32
    Wurlitzer wrote: »
    I agree that Spin/PASM is a good choice if you don't care to port your code to other platforms or make use of code that others have written for other platforms. I've written a fair amount of PASM code and also some Spin and I can get things done in those languages. If the Tachyon Forth OS could support Spin/PASM programming then I would be happy with that.
    If I'm just running a program that someone else developed then I agree. I don't want to have to write a program in Klingon though. :-)
    The ATmega328p used on the Arduino is a little underpowered for my tastes as well but there are other processors available on the Arduino platform these days that compete better with the P1. Also, you can use the ASC+ and get the best of both worlds.
    edited 2014-10-05 09:00
    Wurlitzer,
    While my preferred choice of a programming language has not, nor probably will never be implemented for the Prop...
    Oooo...that is so frustrating. Please do tell us, what is your preferred programming language?
    It is speculated that Klingons program in a language called "Var'aq". You can read about it and check out a Var'aq language system here http://www.reocities.com/connorbd/varaq/. From what I have read so far it seems to use Klingon keywords although I'm not sure it has the right attitude:)
    I would not say other MCU's are inferior. It all depends what problem you are trying to solve. Often having portable code is actually part of the solution for various reasons above and beyond running on the target device. For example, ease of development on a host machine, testing, simulation etc.
    Except for the Arduinos of course, that goes without saying :)
    All in all I agree with you. The Prop, it's architecture, it's instruction set, it's assembler language, Spin and the PropTool IDE are a coherent whole. All designed together by one guy with a clear vision of what he wants in a system. Nice and simple to use, and works very well. With the simplicity and speed of turn around of a tool like the PropTool I feel no need for an interactive environment on the Prop itself.
    edited 2014-10-05 09:40
    Heater. wrote: »
    Is the Klingon user input error message: "I should kill you where you stand! "?
    Its a little wordy for a 32k byte system, but puts a whole new spin on "user friendly".
    What was the topic again?
    edited 2014-10-05 09:49
    Braino,
    Yes, "I should kill you where you stand! " is a bit wordy. I have no idea about Klingon but supposedly they say such things quite a lot. So we might guess they have condensed these error messages down to single words that summarize how you are going to die and perhaps why.
    The topic? I'm not sure. We are still waiting on Peter to come back to us on that.
    edited 2014-10-05 16:00
    As for activity, I've had two job changes in the last few months. Quite the challenge. This lined right up with the P2 back into serious development and it just didn't allow for deep diving into P1 VERILOG, though I do follow with interest.
    I'm waiting a bit to see if Chip gets an FPGA image. I'm very eager to jam on P2.
    The small amount of P1 activity I've got going on is in tandem with an Apple ][ computer. Nothing I want to share yet, though I may soon as I may have some questions.
    Put simply, now is a good time to take a little break, get my head wrapped around a new, and pretty great job. When Chip is ready, I'm ready.
    As for an ARM + P1 kind of system. Maybe! Really depends on if there is a development board I find appealing. For those people wanting to do bigger things, doing this makes sense. Go for it. Maybe a lot of us see the appeal and jump in.
    I know Chip is deep into it, maximizing what we all learned so far. I'm feeling good about it all and am perfectly willing to wait it out. No worries here.
    edited 2014-10-05 16:10
    Just to clarify a small point first, the emphasis is not on a stand-alone system, it's just that we have that capability even in a very minimal configuration. So therefore an embedded target could have all or some of the elements of a stand-alone system if that's what it required. Most of the time this is not so and neither is it necessary to develop on the Prop when perfectly good PCs are everywhere. As for interactivity, well that's put to good use as a command interpreter for the network server and for running "scripts" from SDFS.
    However the capability to load in runtime objects helps overcome some of the memory limitations of what is otherwise a "microcontroller", albeit a very powerful and unique one at that. Be that as it may, neither is the implementation of software or hardware the focus here either although it has been demonstrated that essentially "we have the technology".
    I suppose my lament which is what it is in effect is about the P1 ending up a bit like a much loved but "deprecated" 6502/Z80 etc. Even to this day there are groups writing code for these devices and designing hardware but they are just a hobbyist's pet and who would really use them? The P1 is being used to essentially "blink LEDs" in many projects, mundane things that any micro could do and no real reason to use the Prop. Given that other micros are cheaper and self-contained with oscillators and Flash etc you might rightly wonder why anyone would use a Prop chip.
    So then, why use a Prop? What is it good for?
    To which I might reply:
    1. I love the "soft peripherals" that you can route to any port pin
    2. The multi-core non-interrupt nature with predictable execution flow.
    3. Simple and clean assembly language and CPU architecture
    Why might I not use a Prop, especially the P1?
    1. Lack of memory, both machine code (496 longs) and data.
    2. Lack of I/O
    3. Lack of speed both in CPU cycles and peripherals, especially SPI
    Okay, some of these points can be argued back and forth but if I had to blurt it out on the spot then that is basically what I would say.
    Now however I am inclined to use the P1 with the further hope that someday P2 will alleviate many of these restrictions to some extent but by that time it will have to compete for attention with even more advances in technology. So back to P1, if there is a nexus where a vast plethora of embedded skills can come together and focus on polishing the rough edges, in filling in the gaps, and testing and documenting, then I think that the Prop would hold a lot more appeal to many many more who at present rely greatly on libraries and examples as with other unmentionable chips. More appeal, more zeal, more zeal, more appeal and so on.
    Though not my original intent such a nexus could be the Tachyon VM itself, the cog that executes fast bytecodes rather than Spin or CMM or LMM. Why? because it works and it works well even if I say so myself. The Forth that is built upon this Tachyon VM can be viewed as an OS if you like but the reality is that any compiler can be written to eventually compile down to these bytecodes. LMM sounds great but it takes four memory hogging bytes for each simple machine instruction and can only run at hub speed at best (if not cached). Contrast this with the Tachyon bytecodes which are mostly one byte, take from 400ns to execute but also include more powerful instructions as well as efficient operations for SPI etc.
    Where's this heading? Exactly, let's choose a direction and head in that direction with a purpose, each doing our little bit, contributing in a meaningful and useful way and have a lot of fun while we are at it.
    @David Betz: If some source code is compiled to Tachyon VM bytecodes then C, or D or E but what does it matter as long as it can all be integrated seamlessly if possible. I would think that an FFT might just compile to PASM to run in it's own cog but applications themselves as well as many drivers would be better off as more compact bytecode. BTW, it takes only a couple of milliseconds to read in sectors from an SD card (or SPI Flash) straight into a cog so cogs could even be preloaded with a "loader" which may even stay resident, just pass the sector number to it and it's up and running almost immediately so this lends itself to overlays. This is something I may play with a bit more now that I mention it.
    edited 2014-10-05 16:52
    2. Lack of I/O
    Sounds interesting. Do you have a description of the Tachyon VM and its bytecodes? Is it a good match for the code generators of other languages? GCC, for instance, works best with a register machine not a stack machine. You can see this in the inefficiency of the code generator for the ZPU. Where can I find a description of the Tachyon VM separate from the Tachyon Forth documentation? In fact, what you are suggesting is similar to my idea for P1V of implementing the CMM instruction set in hardware. The same could be done for the Tachyon VM bytecodes if they are indeed a good target for modern high-level language compilers.
    edited 2014-10-05 18:23
    I think that the VM needs to have the balance between being a "good target" for HLL and also an efficient runtime engine. The purist or academic may desire certain things but what's the point if it doesn't perform. Remember that Tachyon was born out of making the Prop perform since I was getting such abysmal performance from various approaches and the only other alternative was code everything in PASM, but surely there must be a better way. So some of the first programs I wrote in Tachyon after I worked out how to implement it both in the Prop tool with it's restrictions, and in it's runtime and compile time behaviour, were VGA graphics drivers. Although it was just fairly basic stuff I could see that it had the potential to do what I needed in HLL rather than PASM and without devoting cogs to specialized functions or running out of memory.
    Tachyon VM bytecodes are not fixed and could change because each code is actually the 8-bit address of the first 256 longs in the VM cog. So there is no lookup as such, it is simply a matter of reading in a bytecode and jumping to that address, simple and fast. The return is a vector that normally points right back to the doNEXT bytecode loader which uses an IP instruction pointer that is directly analogous to the cog's PC.
    [COLOR=#000000][FONT=Courier New][B]doNEXT[/B][/FONT][/COLOR][COLOR=#000000][FONT=Courier New]      rdbyte  instr,IP  'read byte code instruction[/FONT][/COLOR]
    [COLOR=#000000][FONT=Courier New]            add     IP,#1 wc  'advance IP to next byte token (clears the carry too!)[/FONT][/COLOR]
    [COLOR=#000000][FONT=Courier New]            jmp     instr     'execute the code by directly indexing the first 256 long in cog[/FONT][/COLOR]
    To access some less used codes in the second "page" there is the XOP which will read in the next bytecode as the 8-bit address offset by $100 and this is useful for some less used and slower but necessary instructions such as CMOVE and EMIT for instance.
    Now you mention register based rather than stack based addressing but really the VM uses a hybrid approach as it always expects operands to be in a fixed position simply because the Prop's architecture can't efficiently address base+offset and we need it efficient and compact. So originally there was only a 12 operand data stack which was fixed in cog memory but later on I introduced the hybrid stack where I kept the top four operands in fixed cog memory and the overflow in hub if necessary. So therefore an ADD operation reads in two registers in fixed positions and writes the result to the second register while "dropping" or discarding the first.
    [COLOR=#000000][FONT=Courier New]' [/FONT][/COLOR][COLOR=#000000][FONT=Courier New][B]-[/B][/FONT][/COLOR][COLOR=#000000][FONT=Courier New] ( n1 n2 -- n3 ) Subtract n2 from n1[/FONT][/COLOR]
    [COLOR=#000000][FONT=Courier New][B]MINUS[/B][/FONT][/COLOR][COLOR=#000000][FONT=Courier New]       neg   tos,tos   ' (note: save one long by negating and adding)[/FONT][/COLOR]
    [COLOR=#000000][FONT=Courier New]' [/FONT][/COLOR][COLOR=#000000][FONT=Courier New][B]+[/B][/FONT][/COLOR][COLOR=#000000][FONT=Courier New] ( n1 n2 -- n3 ) Add top two stack items together and replace with result[/FONT][/COLOR]
    [COLOR=#000000][FONT=Courier New][B]PLUS[/B][/FONT][/COLOR][COLOR=#000000][FONT=Courier New]        add   tos+1,tos[/FONT][/COLOR]
    [COLOR=#000000][FONT=Courier New]            jmp   #DROP[/FONT][/COLOR]
    As you can see just from doNEXT and PLUS itself that this is both fast and efficient but the stack pushing and popping takes time too which is why I try to avoid this in some repetitive operations and simply use other fixed registers referred to as COGREGs.
    12 34 LAP + LAP . .LAP 46 1.000us ok ( just time the PLUS operation which includes a DROP)
    LAP 12 34 + LAP . .LAP 46 4.200us ok ( both 12 and 34 compile as 2 bytes each so we are timing 5 bytecodes)
    LAP 4 16 + LAP . .LAP 20 3.600us ok ( use some fast constants of 1 byte each for 3 bytecodes total)
    LAP 16 2/ LAP . .LAP 8 1.800us ok ( push a fast constant and shift right)
    16 LAP 2/ LAP . .LAP 8 400ns ok ( a single non-stacking operation takes 8 cycles or 400ns)
    Anyway, all the information is online in various Google docs and Dropbox folders as well as the voluminous Tachyon thread from which anyone can more than just glean from. I'm just throwing this idea out there although as I stated previously that was not my original intention. I tell you, the countless times I see "problems" on the forum that aren't problems at all, but the problem is in the insistence on a certain approach such as I want to do this in Spin and it's not fast enough :)
    Now, I know when to shut my mouth up, at least most of the time I hope, but I feel like waving my hand in the air so many times and saying "come over here and I will show you how easy it really is". Instead the forum becomes clogged in "problems" that seem to go on unresolved. Imagine what that looks like to newcomers, a forum full of unresolved problems over rather trivial things? Doesn't paint a pretty picture for the Prop.
    My way might not be the perceived norm but it really works and it's fun but I'm only one person, imagine what can happen if we choose a direction and work together?!
    edited 2014-10-05 18:33
    I guess there are plenty of Tachyon users out there who are willing to help. You may be correct that this approach is the only one that will work on the P1 and produce efficient code. I can't help but wonder whether it would be possible to define a VM using similar techniques that would be a better target for other high level languages. Actually, the Spin VM is stack based already. Have you tried to map Spin onto your VM? I'm sure you'd have lots of people interested if you could speed up Spin to the same level of performance and code compactness that you've achieved with Tachyon. If you don't need to run the compiler on the target hardware, then the higher complexity of compiling an infix language shouldn't really be an issue. Rather than trying to win people over to the Forth way, why not see if you can achieve similar performance gains with a more widely accepted language. In this forum, that would be Spin as much as I'd like to say otherwise.
    edited 2014-10-05 19:14
    Quite a few of us have written versions of OSes for the Prop. Mine uses spin and pasm and looks like DOS. Davids looks like *nix.
    The underlying language for this is totally irrelevant unless you want to add OS features.
    Many times a few of us have tried unsuccessfully to get collaboration on a standard propeller OS.
    IMHO, a propeller OS that could also compile would be a great feature to have for the hobbyists. Would we really compile on the prop? Well mostly no. But being possible makes the OS much more usable for the hobbyists. This is not going to help commercial prop uses, but it might get more using the prop and make it more noticeable to the wide world where that could result in more commercial users. Besides, a large hobby group could use the prop in decent quantities.
    There is absolutely nothing to lose in joining forces and creating a propeller OS with Peter. It could just be the turning point to get all the various languages running under the same propeller OS. From a hobbyist point of view, imagine an OS with the ability to run C, C++, Forth, Tachyon, Basic, Spin, PASM, Spin+, etc, etc.
    edited 2014-10-05 19:15
    David Betz wrote: »
    Here are the reins and the saddle, I've come this far but surely you are not asking me to do it by myself all over again too? Putting aside "language" we should always consider Forth both a language and an environment or O/S even and just like I can make Forth look like an assembler I can also make it look like a Spin/Basic/C compiler if I wished. But Forth code maps one for one essentially so I have tight control over the code and for me it's a fun interactive and fast language to develop in. Spin/Basic/C are just languages with their very strict syntax and typing without the flexibility I myself need to have to stay creative. Yes, I can write in any language and like many of us we have had to code in many but I prefer the non-swearing kind that sweet talks back to me interactively and one that I can teach new tricks. I would like to think we have gone far beyond submitting our code in one great big "punch-card" blob and crossing our fingers.
