5V Limefuel to Parallax Board
Hey Guys,
Question for you guys, I bought a nice limefuel battery pack that's got quite a bit of charge but it only has two outs each with 5V. My board requires 6V. Aside from running the power output from the source through a circuit and combining then dividing out the voltage is there any easy work around to get my board to use a 5V source? The amperage is good for the outputs.
Seeker
Seeker
http://www.ebay.com/itm/New-Arrive-LM2587-Volume-DC-DC-Booster-Converter-Step-up-Voltage-Regulator-/290912280790
Of course the limefuel power pack has its own internal regulator or booster with its own inefficiencies, compounded by adding another voltage booster module. If you can hack into the pack to connect the above booster module directly to the internal (Li-Ion or LiPO) battery, your overall efficiency may improve.
