uOLED 128 G2 - Having Troubles Displaying Bitmap Data — Parallax Forums
MahonroyMahonroy Posts: 175
edited 2014-12-03 20:18 in Propeller 1
Hi guys,
I have the uOLED 128 G2 from the parallax website, here is the link:
http://www.parallax.com/product/28081
I currently have it connected to a propeller microcontroller, and I am using the "oLED-128-G2_v2.1" library to communicate with it. So far everything is working fine, I can write text, draw lines, etc.
I am having problems displaying bitmaps. I am wanting to define a bitmap in the "dat" section of a .spin file, similarly to the "ParallaxIncLOGO" and the "ChipGracey" found in the "oLED-128-G2_DEMO_v2.1b" library. I cannot figure out the format, and how to convert a .bmp file to the hex array. I started small, and was attempting just a 4x4 bitmap file, but I can't seem to get it right... the 4x4 area on the screen is all jumbled and looks like I don't have my format right. I attached a sample image that I'm trying to get to display on the screen "blocks.bmp". I tried using some converter programs, and I get this as the output of the bitmap file:
{0xff0000, 0xffffff, 0xffffff, 0xffffff, 0x00ff00, 0xffffff, 0xffffff, 0xff0000, 0x0000ff, 0xffffff, 0xffffff, 0x00ff00, 0xffffff,
0xffffff, 0xffffff, 0x0000ff};
So I manually converted it to SPIN like so:
dat
TestChar
'------------------------ 256 color BMP Image Data below ---------------------------
byte $ff, $00, $00
byte $ff, $ff, $ff
byte $ff, $ff, $ff
byte $ff, $ff, $ff
byte $00, $ff, $00
byte $ff, $ff, $ff
byte $ff, $ff, $ff
byte $ff, $00, $00
byte $00, $00, $ff
byte $ff, $ff, $ff
byte $ff, $ff, $ff
byte $00, $ff, $00
byte $ff, $ff, $ff
byte $ff, $ff, $ff
byte $ff, $ff, $ff
byte $00, $00, $ff
I then use this code to write to the display:
LED.image(0,0,4,4,0,@TestChar)
However, this just looks like a bunch of random pixels on the display.
Any help is greatly appreciated, thanks!
4 x 4 - 104B
    edited 2014-10-03 18:10
    Looking at the demo, the bitmap file is included as is (i.e. header and everything). So assuming your BMP is the right format I would simply use
    TestChar file "blocks.bmp"
    and go from there.
  • MahonroyMahonroy Posts: 175
    edited 2014-10-03 19:24
    Ah I didn't realize I could reference a bitmap file like that.
    Ok I gave that a shot, and I got similar effects to what I described before. I tried saving the bitmap file in various bitmap formats through photoshop (windows 16 bit, windows 24 bit, 16 bit X1 R5 G5 B5, 16 bit R5 G6 B5, 16 bit X4 R4 G4 B4, and 24 bit R8 G8 B8). I just placed the blocks.bmp file in the library format, then sent it to the propeller. Depending on the format I saved it as, it would look slightly different, but still jumbled.
    edited 2014-10-03 19:47
    The image method expects a 256 entry palette (so that wouldn't have worked with the attached image), not quite sure ATM which of the formats covers that. OTOH you could write your own display function based on said method (send command, header and pixel data).
    Or use the BlitCom2Display method instead which can send raw data (565 formatted).
    edited 2014-10-03 22:16
    I searched around this forum, as well as google on the "BlitCom2Display" method, and couldn't find a thing on it. Is it misspelled, or is this in some library somewhere?
    edited 2014-10-03 23:10
    Mahonroy wrote: »
    In oLED-128-G2_v2.1 it's the method before the image method (around line 1238).
    edited 2014-10-04 08:26
    Ok I found it thanks, I must have missed it somehow.
    I tried this line in place of the image method:
    LED.BlitCom2Display(0,0,4,4,@TestChar)
    I tried it with all of the different bitmap formats I made, and the images are still jumbled, and is different shades of blue this time. It also locked up the display... no further code executed after this line. I experienced this same thing with the display locking up when I tried getting the bmpchar method to work.
    edited 2014-10-04 15:24
    Mahonroy wrote: »
    I tried it with all of the different bitmap formats I made, ...
    This method doesn't take a plain bitmap file. It expects w*h words (5-6-5) at the data location. IOW no header this time.
    I don't have the h/w so I have to assume the driver is working as shown (source).
    edited 2014-10-06 09:57
    Ok I swapped it back to this:
    [COLOR=#333333][FONT=Parallax]TestChar[/FONT][/COLOR]
    '------------------------ 256 color BMP Image Data below ---------------------------byte $ff, $00, $00byte $ff, $ff, $ff byte $ff, $ff, $ff byte $ff, $ff, $ff byte $00, $ff, $00 byte $ff, $ff, $ff byte $ff, $ff, $ff byte $ff, $00, $00 byte $00, $00, $ff byte $ff, $ff, $ff byte $ff, $ff, $ff byte $00, $ff, $00 byte $ff, $ff, $ff byte $ff, $ff, $ff byte $ff, $ff, $ff  [COLOR=#333333][FONT=Parallax]byte $00, $00, $ff[/FONT][/COLOR]
    And gave the BlitCom2Display another shot... this time it displays a jumbled black and white image (4x4 pixels) and the screen locks up (e.g. no further commands take without turning the power off and back on).
    edited 2014-10-08 09:59
    How do I flag this topic as "unsolved"?
    Is there anyone out there who has successfully output their own image to this display? And if so, could you please chime in?
    edited 2014-10-14 15:04
    I'm giving this another shot... this is the last thing left to do for my project to be complete. I've posted over at 4D systems forums as well, but still have not had any luck.
    Can anyone identify what is going on with the data that is used for the demo? I think if I could have an understanding on how that data is organized, I could then go about making my own image using the same process...?
    edited 2014-10-16 08:05
    I was able to get this all figured out. I'll try my best to give a simple explanation in case anyone comes across this in the future.
    The oLED-128-G2 library function "image" expects a bitmap that uses indexed colors (the file contains a color pallet in it). It also expects there to be all of the hex header data present as well (even though it is not used and skipped over). To accomplish this, I created an image in adobe photoshop, converted it to indexed colors, and saved it as a 8-bit image.
    What this does is it creates a file that starts with the header data(this is information such as the dimensions, and the direction that the data needs to be read in).
    It then creates an index table that has an index ID, and the color value (R,G,B,A - each can range from 0 - 255).
    At the bottom of the file is the actual image data, and this generally goes across and down (like how you read a book). This can be different though depending on how the header is organized... worse case scenario all this will do is result in a flipped image so you know whats going on if that's the case. This image data does not contain RGBA (0-255) color data, it just references an ID in the pallet that I mentioned earlier.
    What the image function in the oLED-128-G2 library does is it jumps ahead past the header, and reads in the pallet and stores it in a temporary array. It then converts the color data from 8bit,8bit,8bit (RGB respectively), to 5bit,6bit,5bit which is what the screen can accept. It then sends this data directly to the screen.
    So to get this image data into your spin project, you can either reference it in the DAT section as varName file "falename.ext", or you can copy and paste the hex directly into the file. I downloaded a hex editor, opened the file, and copied/pasted the entire hex contents over and it worked (you have to do some formatting though so that its compatible with SPIN).
    If you have an image that is 24bit, you cannot directly use it the same way. This is because the data is organized starting first with a header, there is no pallet section, and the image data each contains RGB (0-255) for every single pixel. (32bit image has RGBA for each pixel).
    If you want to use that instead, this is where you use the BlitComtoDisplay method.... but you have to strip out the header data first or it won't work. You will also have to convert it from 888 to 565.... but you can most likely save it in this format from the get go.
    What I quickly realized is how much space these images take up. A very simple project could maybe have 1-2 full screen (128 x 128) images MAX (and you might have to choose a small pallet color count as well). Because of this, I transitioned over to attempting to get the SD card reader to work instead (I opened a new topic for this).
    edited 2014-10-16 16:00
    Mahonroy wrote: »
    See posts [post=1296618]#2[/post] and [post=1296628]#4[/post] respectively.
  • pilot0315pilot0315 Posts: 1,007
    edited 2014-11-29 17:18
    I am looking of how to convert the bitmap to a byte array as in the demo from parallax. Or am I missing something with this display am I supposed to be able to simply load the bmp to the sd and it will be displayed??
    I am new to these displays.
    edited 2014-12-01 07:50
    pilot0315 wrote: »
    Read through this thread, I describe how I did it. You need 4d systems USB plug and software in order to load an image onto a SD card and display it... you can't just drop it on there with your windows file system. (I know it sucks)
    Thanks I will study it.
  • Not exactly as you want but another way to display an image or a bunch of them is to save them on the SD card of the oled.
    And then just make a call to this function :
    LED.DisplayVideoFrame(71,77,5)                     ' display 5th images at x=71 y=77
    Just follow this tutorial from 4D systems and then apply this code.
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5000000
      rxpin = 0
      txpin = 1
      reset = 2
      OLEDBaud  = 115200
    obj
    LED : "OLED-128-G2_v2.1"
    pub mainDEMO   | i
    LED.start(rxpin, txpin, reset, OLEDBaud)                ''Starts uOLED display
    '--------------------------------------------------------------------------------------------- Slide 1
    LED.MediaInit
    LED.SetByteAddress(0,0)
    LED.DisplayVideoFrame(0,0,0)
    waitcnt(clkfreq*1+cnt)
    repeat
      LED.ClearScreen
      LED.DisplayVideoFrame(71,77,i//5)                     ' display 5 images
      i++
  • sorry i couldn't modify my previous post.
    For the code above i inserted 5 images like this.
    Using the 4D IDE inside the VISI mode, just click on widget tab and add a user image
    then, in the object inspector change the images
    at last add all the images you want. the first column is the frame number to be used in the
    LED.DisplayVideoFrame(71,77, 5)
    235 x 73 - 10K
    555 x 307 - 40K
    882 x 316 - 65K
