Prop Plug use — Parallax Forums
Prop Plug use
eanderso13eanderso13 Posts: 2
edited 2014-10-03 09:03 in General Discussion
Hello,
I've got a DMX lighting unit from Ethereal FX which uses a Parallax Prop Plug to reprogram the firmware to offer different functionality. I got the Prop Plug, I downloaded and installed the USB drivers, but my unit does not show up as anything like a USB drive, and double-clicking the eeprom file (as instructed by the programming instructions from Ethereal FX) just prmopts Windows to try and find a program to open that type of file.
Is there some additional Parallax SW I need to load firmware files to a unit using the Prop Plug?
Thanks.
-Eric
  • doggiedocdoggiedoc Posts: 2,245
    edited 2014-10-03 08:01
    It sounds like you need the Propeller Tool. I am not familiar enough with the DMX unit your using but if it needs a Prop Plug then I suspect the Propeller Tool is the right software. There are others too, but the Propeller Tool is the official IDE.
    Here's the page link: http://www.parallax.com/downloads/propeller-tool-software
    doc
    edited 2014-10-03 08:13
    eanderso13 wrote: »
    Hello,
    Thanks.
    -Eric
    Welcome to the forums!
    Could you link to the particular device you are trying to program? My VERY quick search could not find a Propeller driven device.
    edited 2014-10-03 08:40
    I went to http://etherealfx.com and looked at the DMX accessories, but I didn't see anything that referred to a Parallax Propeller. doggiedoc's suggestion about using the Prop Tool is probably all you need. I suspect JonnyMac may know something about the device you are using. You may want to PM him about it.
    EDIT: I found a reference to a firmware upgrade for the EH16-DMX. It mentions that you need a Prop Plug and the Propeller software. The Prop Plug link works, but the Propeller software link is no longer valid. Use the link that doggiedoc posted.
    edited 2014-10-03 08:41
    Good point Jim. Since the Prop plug is basically just a USB-Serial adaptor - it's requirement may not necessarily indicate a Propeller based board. Doh!
    Oh and I forgot to Welcome you Eric! Welcome to the Parallax Forums!!
    doc
    edited 2014-10-03 08:53
    Dave Hein wrote: »
    I didn't dig down far enough to see it was Jon's EH16-DMX Module.
  • eanderso13eanderso13 Posts: 2
    Thanks guys! Yeah, you found it. The EH16-DMX. I'll try the Propeller Tool and see what happens!
