Plastic enclosure ideas for DIP propeller breadboard projects?
Radioshack sells these black plastic project enclosure boxes that don't seem to fix any breadboards that I've found very well, especially the propeller educational kit.
Has anyone found an enclosure that is designed for the propeller education kit? Especially if there was room for an additional breadboard on either side of the standard educational kit breadboard ... or even another 3 interconnected with power bridges underneath of it? I guess it could be held down pretty well with some sort of elastic device like they do with toy packaging?
Maybe I'm the only one that could use this, but it would be helpful if someone hasn't found something like it already. I've been searching on the web to no avail.
A dab of hot glue holds the PCB's in place but still allows for removal.
Walter
Sorry I'm a bit late getting around to posting this, but here it is.
The white plastic cutting boards are held in place by strips of velcro. The pcb's mount to the cutting boards with plastic 4-40 screws and nuts, and the prototyping blocks are held in place with double sided tape. Power for most projects is usually provided by either the 6V 500mA wall wart (rear) or the 7.5V 1.5A one at the front of the case. Makes for a neat easily transported prototyping setup.
I got this case at a garage sale for a couple of dollars but I have also seen them at flea markets and pawn shops for not much more.
Both would work great for the PE Kit setup.
One that I keep wanting to get is actually a poker chip case: http://www.walmart.com/ip/Trademark-Global-200-Chip-Aluminum-Case-with-Clear-Cover/16673687
Will work great for a project with a 7" LCD.
If it's at all possible I would suggest mounting the connectors inside the case so they are protected when the case is closed.
