BS2 File Problem
Over the years, I built many BS2 programs on my HP Pavilion laptop computer running XP. The generated files showed up in the computer directory with no problem.
However, when the HP hard drive crashed the BS editor was downloaded to a new Toshiba laptop computer running Windows 7.0
As I built and let the BS2 editor save the files...I find that the files do not show up in the computer directory. I want to copy these files every so often to a jump drive for backup but it appears that they are hidden.
In the editor, one can see the file structure under C:\ all the way down to the BS2 Editor. Opening the editor shows all the BS1, BS2 type internal device code files but there are no programs listed that I developed.
When the cursor is placed on the BS2 Editor file, the developed programs are shown in the access window below and any of them can be pulled up into the editor and worked on. They are saved back into the same location...where ever that is.
How can one get these generated files to show up in the computer directory?
Discovery
Discovery
(Replacing "$user$" with whatever name you log on as)
On Win 7 look in your "My Documents", if it's not there look in C:\Users\"YourUserName"\AppData.
Probably it's in C:\Users\"YourUserName"\AppData\Local\Parallax.
C:\users\username\AppData\local\virtual store\program files(x86)\parallax inc\stamp editor
Opening the files cannot proceed past username. There is no AppData file there to open.
There is only one user on the machine.
Could there be a setting somewhere causing the problem?
Discovery
Open up Windows Explorer. On the Menu Bar, click on "Tools" and select "Folder Options..."
Note that you may have to first enable viewing of the "Menu Bar". This is in "Organize".
Click "Organize", then "layout" and check the entry for "Menu Bar".
Okay, click "Tools" on the menu bar and select "Folder Options..." then select the "View" tab.
In the list box, look for an entry that says "Hidden files and folders".
Enable the option that says "Show hidden files, folders, and drives"
You should now be able to see your files that the idiots fine people at Microsoft were trying to keep secret from you.
