DDR3 - The quest to 128 MBytes — Parallax Forums
AleAle Posts: 2,363
edited 2014-10-27 10:45 in Propeller 1
Hei all,
I want DDR3, want it want it want it, did I say that I want it ? , no ?... well... i do.
Here I'll post my progress.
Testbench:
BeMicroCV. Cyclone V, DDR3 chip: Micron MT41J64M16JT-15E here: http://www.micron.com/parts/dram/ddr3-sdram/mt41j64m16jt-15e?source=ps
Code: my own Cog, Ale's Cog :), just because I know it and can modify it to suit this test, it runs normal cog's assembler, it has one difference, a hw-uart :).
I'll post the code to my github account as soon as I have found my github password ;-) again.... :D
The idea is to get it to work, I have compiled the core before... but didn't have a suitable environment to test it, now that the environment works well, I can go on with the DDR3 config itself.
Note on speed and bandwidth:
The board's docs don't really say much more than it "works", let's take they word for it at 300 MHz. The chip is a CL 9 chip, meaning from command to answer we have 9 clocks, plus all the overhead and so on, like 20 clocks per transfer... I'm sure it can be integrated as a HUB peripherial, the hub waits anyways up to 16 80 MHz clocks, maybe it fits somehow.
Controller setup:
- Hard external memory controller, select the chip from the list on the right and 50 MHz as base clock, and 300 MHz Memory clock, avalon at full speed.
- I'll use a 32 bit port to read and write.
- Compiling the thing takes like forever, welcome to the slow lane :(
Edit:
I got it to compile, it costs like 800 extra ALMs... but it did something strange for the dqs pins during assignment... :/
  • AleAle Posts: 2,363
    edited 2014-09-25 01:50
    Top module code
     * DDR3 Test top file
    `include "../../01_Verilog/acog_defs.v"
    module ddr3_cog(
    	input wire 			clk_50,
    	output wire [7:0] leds,
    	// DDR3
    	inout wire [15:0] 	mem_dq,
    	output wire [12:0] 	mem_a,
    	output wire [2:0] 	mem_ba,
    	output wire 			mem_cas_n,
    	output wire 			mem_ck,
    	output wire 			mem_ck_n,
    	output wire 			mem_cke,
    	output wire 			mem_cs_n,
    	output wire [1:0]		mem_dm,
    	inout wire [1:0]		mem_dqs,
    	inout wire [1:0]		mem_dqs_n,
    	inout wire 				mem_odt,
    	output wire 			mem_ras_n,
    	output wire 			mem_reset_n,
    	output wire 			mem_we_n,
    	input wire 				oct_rzqin,
    	inout wire [31:0] port_a,
    	output wire 		tx_o
    //`define TWO_COGS 1
    //`define HW_DEBUG 1
    wire [31:0] CNT;
    wire [31:0] port_a_in, mux_port_a_out;
    wire [31:0] port_a_dir;
    wire [31:0] port_a_o_0, port_a_dir_o_0;
    wire [31:0] port_a_o_1, port_a_dir_o_1;
    wire [31:0] hub_data_to_cog_0, hub_data_to_hub_0;
    wire [`HUB_MEM_WIDTH-1:0] hub_mem_addr_0;
    wire [1:0] hub_mem_size_0;
    wire hub_data_rdy_0, hub_mem_ack_0;
    wire [4:0] hub_op_0;
    wire cog_reset_0;
    wire internal_clk, main_clk;
    wire [95:0] debug_data_cog_0;
    wire debug_data_valid_0;
    wire debug_data_o;
    wire uart_tx;
    wire pll_locked;
    reg [3:0] reset_cnt;
    `ifdef HW_DEBUG
    assign tx_o = debug_data_o;
    `else
    assign tx_o = uart_tx;
    `endif
    assign port_a_in = port_a;
    assign mux_port_a_out = port_a_o_0;// | port_a_o_1;
    assign port_a_dir = port_a_dir_o_0;// | port_a_dir_o_1;
    assign port_a[ 0] = port_a_dir[ 0] ? mux_port_a_out[ 0]:1'bz;
    assign port_a[ 1] = port_a_dir[ 1] ? mux_port_a_out[ 1]:1'bz;
    assign port_a[ 2] = port_a_dir[ 2] ? mux_port_a_out[ 2]:1'bz;
    assign port_a[ 3] = port_a_dir[ 3] ? mux_port_a_out[ 3]:1'bz;
    assign port_a[ 4] = port_a_dir[ 4] ? mux_port_a_out[ 4]:1'bz;
    assign port_a[ 5] = port_a_dir[ 5] ? mux_port_a_out[ 5]:1'bz;
    assign port_a[ 6] = port_a_dir[ 6] ? mux_port_a_out[ 6]:1'bz;
    assign port_a[ 7] = port_a_dir[ 7] ? mux_port_a_out[ 7]:1'bz;
    assign port_a[ 8] = port_a_dir[ 8] ? mux_port_a_out[ 8]:1'bz;
    assign port_a[ 9] = port_a_dir[ 9] ? mux_port_a_out[ 9]:1'bz;
    assign port_a[10] = port_a_dir[10] ? mux_port_a_out[10]:1'bz;
    assign port_a[11] = port_a_dir[11] ? mux_port_a_out[11]:1'bz;
    assign port_a[12] = port_a_dir[12] ? mux_port_a_out[12]:1'bz;
    assign port_a[13] = port_a_dir[13] ? mux_port_a_out[13]:1'bz;
    assign port_a[14] = port_a_dir[14] ? mux_port_a_out[14]:1'bz;
    assign port_a[15] = port_a_dir[15] ? mux_port_a_out[15]:1'bz;
    assign port_a[16] = port_a_dir[16] ? mux_port_a_out[16]:1'bz;
    assign port_a[17] = port_a_dir[17] ? mux_port_a_out[17]:1'bz;
    assign port_a[18] = port_a_dir[18] ? mux_port_a_out[18]:1'bz;
    assign port_a[19] = port_a_dir[19] ? mux_port_a_out[19]:1'bz;
    assign port_a[20] = port_a_dir[20] ? mux_port_a_out[20]:1'bz;
    assign port_a[21] = port_a_dir[21] ? mux_port_a_out[21]:1'bz;
    assign port_a[22] = port_a_dir[22] ? mux_port_a_out[22]:1'bz;
    assign port_a[23] = port_a_dir[23] ? mux_port_a_out[23]:1'bz;
    assign port_a[24] = port_a_dir[24] ? mux_port_a_out[24]:1'bz;
    assign port_a[25] = port_a_dir[25] ? mux_port_a_out[25]:1'bz;
    assign port_a[26] = port_a_dir[26] ? mux_port_a_out[26]:1'bz;
    assign port_a[27] = port_a_dir[27] ? mux_port_a_out[27]:1'bz;
    assign port_a[28] = port_a_dir[28] ? mux_port_a_out[28]:1'bz;
    assign port_a[29] = port_a_dir[29] ? mux_port_a_out[29]:1'bz;
    assign port_a[30] = port_a_dir[30] ? mux_port_a_out[30]:1'bz;
    assign port_a[31] = port_a_dir[31] ? mux_port_a_out[31]:1'bz;
    `ifdef HW_DEBUG
    reg [15:0] baud_acc;
    reg [7:0] second_div;
    reg [95:0] debug_sr;
    reg [9:0] debug_cnt;
    assign internal_clk = debug_cnt[8]; // one tick every 512 clocks
    assign main_clk = baud_acc[15]; // 50 MHz clock and 115200 Baud
    debug debuguint(
    	.reset_in(cog_reset_0), // main tick
    	.clk_tx_in(main_clk), // uart transmitter tick, 1 MHz
    	.new_cycle_in(), // assrted when we have to send the info
    	.debug_data_in(debug_data_cog_0),
    	.uart_tx_o(debug_data_o)
    always @(posedge clk_50)
    	begin
    		baud_acc <= { 1'b0, baud_acc[14:0] } + 16'd75; // 50 MHz clock and 115200 Baud
    	end
    always @(posedge main_clk)
    	begin
    		debug_cnt <= debug_cnt + 10'd1;
    	end
    always @(posedge internal_clk)
    	begin
    		second_div <= second_div + 8'd1;
    	end
    `else
    assign internal_clk = clk_50; // clock for clock
    `endif
    assign cog_reset_0 = reset_cnt != 4'd3;
    assign leds = { pll_locked, cog_reset_0, CNT[7:1] };
    	if (reset_cnt != 4'd3)
    		reset_cnt <= reset_cnt + 4'd1;
    wire avl_rdata_valid, avl_ready;
    assign hub_mem_ack_0 = (avl_rdata_valid & (hub_op_0[4:3] == 2'b11)) | ((hub_op_0[4:3] == 2'b11) & avl_ready);
    ACog cog0(
    	.clk_in(internal_clk),
    	.CNT_in(CNT),
    	// debug
    	.debug_data_o(debug_data_cog_0),
    	.debug_data_valid_o(debug_data_valid_0),
    	// Ports access
    	.port_a_in(port_a_in),
    	.port_a_o(port_a_o_0),
    	.port_a_dir_o(port_a_dir_o_0)
    `ifdef WITH_PORTB
    	,.port_b_in(port_b_in),
    	.port_b_o(port_b_o_0),
    	.port_b_dir_o(port_b_dir_o_0)
    `endif
    	// HUB access
    	.hub_op_o(hub_op_0),
    	.hub_addr_o(hub_mem_addr_0),
    	.hub_data_in(hub_data_to_cog_0),
    	.hub_data_rdy_o(hub_data_rdy_0),
    	.hub_sz_o(hub_mem_size_0),
    	.hub_data_o(hub_data_to_hub_0),
    	.hub_ack_in(hub_mem_ack_0),
        .uart_tx_o(uart_tx)
    GblCounter gblcnt(
    	.CNT_o(CNT)
    `ifndef SIMULATOR
    ddr3_ctrl (
    		.pll_ref_clk(clk_50),                //        pll_ref_clk.clk
    		.global_reset_n(!cog_reset_0),             //       global_reset.reset_n
    		.soft_reset_n(!cog_reset_0),               //         soft_reset.reset_n
    		.afi_clk(),                    //            afi_clk.clk
    		.afi_half_clk(),               //       afi_half_clk.clk
    		.afi_reset_n(),                //          afi_reset.reset_n
    		.afi_reset_export_n(),         //   afi_reset_export.reset_n
    		.mem_a(mem_a),                      //             memory.mem_a
    		.mem_ba(mem_ba),                     //                   .mem_ba
    		.mem_ck(mem_ck),                     //                   .mem_ck
    		.mem_ck_n(mem_ck_n),                   //                   .mem_ck_n
    		.mem_cke(mem_cke),                    //                   .mem_cke
    		.mem_cs_n(mem_cs_n),                   //                   .mem_cs_n
    		.mem_dm(mem_dm),                     //                   .mem_dm
    		.mem_ras_n(mem_ras_n),                  //                   .mem_ras_n
    		.mem_cas_n(mem_cas_n),                  //                   .mem_cas_n
    		.mem_we_n(mem_we_n),                   //                   .mem_we_n
    		.mem_reset_n(mem_reset_n),                //                   .mem_reset_n
    		.mem_dq(mem_dq),                     //                   .mem_dq
    		.mem_dqs(mem_dqs),                    //                   .mem_dqs
    		.mem_dqs_n(mem_dqs_n),                  //                   .mem_dqs_n
    		.mem_odt(mem_odt),                    //                   .mem_odt
    		.avl_ready_0(avl_ready),                //              avl_0.waitrequest_n
    		.avl_burstbegin_0(1'b0),           //                   .beginbursttransfer
    		.avl_addr_0(hub_mem_addr_0),                 //                   .address
    		.avl_rdata_valid_0(avl_rdata_valid),          //                   .readdatavalid
    		.avl_rdata_0(hub_data_to_cog_0),                //                   .readdata
    		.avl_wdata_0(hub_data_to_hub_0),                //                   .writedata
    		.avl_be_0(4'hf),                   //                   .byteenable
    		.avl_read_req_0(hub_op_0[4:3] == 2'b11),             //                   .read
    		.avl_write_req_0(hub_op_0[4:3] == 2'b10),            //                   .write
    		.avl_size_0(3'h1),                 //                   .burstcount
    		.mp_cmd_clk_0_clk(clk_50),           //       mp_cmd_clk_0.clk
    		.mp_cmd_reset_n_0_reset_n(!cog_reset_0),   //   mp_cmd_reset_n_0.reset_n
    		.mp_rfifo_clk_0_clk(clk_50),         //     mp_rfifo_clk_0.clk
    		.mp_rfifo_reset_n_0_reset_n(!cog_reset_0), // mp_rfifo_reset_n_0.reset_n
    		.mp_wfifo_clk_0_clk(clk_50),         //     mp_wfifo_clk_0.clk
    		.mp_wfifo_reset_n_0_reset_n(!cog_reset_0), // mp_wfifo_reset_n_0.reset_n
    		.local_init_done(),            //             status.local_init_done
    		.local_cal_success(),          //                   .local_cal_success
    		.local_cal_fail(),             //                   .local_cal_fail
    		.oct_rzqin(oct_rzqin),                  //                oct.rzqin
    		.pll_mem_clk(),                //        pll_sharing.pll_mem_clk
    		.pll_write_clk(),              //                   .pll_write_clk
    		.pll_locked(pll_locked),                 //                   .pll_locked
    		.pll_write_clk_pre_phy_clk(),  //                   .pll_write_clk_pre_phy_clk
    		.pll_addr_cmd_clk(),           //                   .pll_addr_cmd_clk
    		.pll_avl_clk(),                //                   .pll_avl_clk
    		.pll_config_clk(),             //                   .pll_config_clk
    		.pll_dr_clk(),                 //                   .pll_dr_clk
    		.pll_dr_clk_pre_phy_clk(),     //                   .pll_dr_clk_pre_phy_clk
    		.pll_mem_phy_clk(),            //                   .pll_mem_phy_clk
    		.afi_phy_clk(),                //                   .afi_phy_clk
    		.pll_avl_phy_clk()             //                   .pll_avl_phy_clk
    `else
    assign avl_rdata_valid = hub_op_0[4:3] == 2'b11;
    `endif
    initial
        begin
            reset_cnt = 0;
    `ifdef HW_DEBUG
        baud_acc = 0;
        second_div = 0;
        debug_sr = 0;
        debug_cnt = 0;
    `endif
        end
    endmodule
    hier the cog's code. VSCL is used as UART interface
    equ1        = 500
    equ2        = 700
                mov     DIRA, #$3
                mov     $1ef, #0        ; end boot mode
                call    outcrlf
    testloop    mov     waddr, addr0
                mov     wvalue, startvalue0
                mov     scnt, CNT      ; start time
                rdlong  wvalue, waddr
                mov     ecnt, CNT
                mov     VSCL, #87 ; W
                call    outuart
                call    outaddr
                mov     waddr, addr1
                mov     wvalue, startvalue1
                mov     ecnt, CNT
                mov     VSCL, #87 ; W
                call    outuart
                call    outaddr
                mov     waddr, addr2
                mov     wvalue, startvalue2
                mov     ecnt, CNT
                mov     VSCL, #87 ; W
                call    outuart
                call    outaddr
                mov     waddr, addr0
                mov     ecnt, CNT
                mov     VSCL, #87 ; W
                call    outuart
                call    outaddr
                mov     waddr, addr1
                mov     ecnt, CNT
                mov     VSCL, #82 ; R
                call    outuart
                call    outaddr
                mov     waddr, addr2
                mov     ecnt, CNT
                mov     VSCL, #82 ; W
                call    outuart
                call    outaddr
    lbl1        mov     OUTA, #$2
                mov     OUTA  #$1
                jmp     #lbl1
    ; outs a string of 8 hex chars from hexvalue
    hex8        mov     temp, hexvalue
                mov     digitcnt, #8
    hexd        mov     dtemp, temp
                shl     temp, #4
                shr     dtemp, #28
                cmp     dtemp, #10 wc
                add     dtemp, #48
        if_nc   add     dtemp, #7       ; for values > 9
                mov     VSCL, dtemp
    hexdl       mov     VSCL,VSCL nr wz
        if_nz   jmp     #hexdl
                djnz    digitcnt, #hexd
    hex8_ret    ret
    ; outputs crlf
    outcrlf     mov     VSCL, #13
    outcrlf1    mov     VSCL, VSCL nr wz
        if_nz   jmp     #outcrlf1
                mov     VSCL, #10
    outcrlf2    mov     VSCL, VSCL nr wz
        if_nz   jmp     #outcrlf2
    outcrlf_ret ret
    ; outputs a space
    outsp       mov     VSCL, #32
    outsp1      mov     VSCL, VSCL nr wz
        if_nz   jmp     #outsp1
    outsp_ret   ret
    ; ouputs a formatted address/value : [01234567]=BABEFACE 01234567 89ABCDEF
    outaddr     call    outsp
                mov     VSCL, #91 ; [
                call    outuart
                mov     hexvalue, waddr
                call    hex8
                mov     VSCL, #93 ; ]
                call    outuart
                mov     VSCL, #61 ' =
                mov     hexvalue, wvalue
                call    hex8
                call    outsp
                mov     hexvalue, scnt
                call    hex8
                call    outsp
                mov     hexvalue, ecnt
                call    outcrlf
    outaddr_ret ret
    outuart     mov     VSCL, VSCL nr wz
        if_nz   jmp     #outuart
    outuart_ret ret
    waddr       long    0
    wvalue      long    0
    raddr       long    0
    rvalue      long    0
    startvalue0 long    $BABEFACE
    startvalue1 long    $DEADBEEF
    startvalue2 long    $01234567
    scnt        long    0
    ecnt        long    0
    addr0       long    $40
    addr1       long    $1120
    addr2       long    $2360
    digitcnt    long    0
    dtemp       long    0
    temp        long    0
    hexvalue    long    0
                long    0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
                long    0,0,0,0,0
    jj          jmp     #0
  • roglohrogloh Posts: 6,211
    edited 2014-09-25 19:33
    Sounds interesting Ale. I hope you can get it to work with the hub. I basically want to do this as well but actually I didn't end up buying the BeMicroCV because it had DDR3. Even though it is inherently faster it has quite a bit of latency and I had thought it would be trickier to share with a video buffer as well if you had to use the onboard memory controller instead of a simpler but more customized one I can optimize for that purpose.
    So instead of DDR3 I am starting with the DE-0 nano with regular SDRAM. Was looking at it last night and even there the memory timing is tight. To fit it in with standard hub read timing once locked to the hub, you need to be able to latch the result back into a COG register within 5 COG clocks of latching the first read S parameter of say RDLONG D,S which is holding the address. In the case of SDRAM that becomes 10 clocks as I plan to run the SDRAM at 2x the Prop clock (eg. 144MHz and 72Mhz). In theory it should just fit because the SDRAM on that board will return the last of the 32 bits on the 7th clock after the ACTIVE command is issued. There might be one or two registers in the pipeline that delay it further but I have 3 memory clocks left.
    In your case with DDR3 if you run your memory at say 3x the Prop clock (100MHz COGs, 300MHz memory) you'll have 15 DDR3 clocks to get the results back in time. I think that is beyond what the DDR3 on the BeMicroCV can do as according to the Micron device datasheet its CAS latency is 9 and its tRCD is 9 so your first 16 bit result won't be back until 18 clocks after you issue the read. I think you might want to look at running the device at 4x the Prop (75MHz COGs, 300MHz memory) to give yourself 20 memory clocks for returning the result in time. It's either that or add more M4 wait states to the external memory reads, which is possible but not as nice for performance/timing compatibility with existing code.
    Looking forward to hearing how it goes.
    edited 2014-09-25 20:36
    Doh! I think I am off by a factor of two. This is double clocked DDR so each memory clock happens in half the time. My numbers don't take that into consideration. Been looking at regular SDRAM timing for too long. Ignore my latency numbers above for DDR3.
    edited 2014-09-25 23:03
    For the time being quartus won the round... The differential pins dqs are wrongly declared in the pin planner...I haven't found yet how to solve that... grrr...
    Success ! I was able to re-enter the pins in the pin planner and it compiled !
    Now, I have to write a simple mem test and see what happens :), wish me luck !
    edited 2014-09-27 00:18
    it is not that easy... it hangs just after starting and the programmer says failed... I posted some code above.
    I think it is time I read the hard memory controller manual :), guesswork brought me so far ;-) hahaha
  • pik33pik33 Posts: 2,416
    edited 2014-09-27 01:08
    This Cyclone V thing... I am not sure now, but doesn't it have a hard DDR3 controller so you only have to infer a megafunction?
    edited 2014-09-27 01:19
    pik33 wrote: »
    Yes, and that is what I am using... or trying anyways... I think that the problem lays in the pll/reset part... I am reading some docs but haven't found what I need yet, this is not for beginners like me... there is only experiment.. :D
    edited 2014-10-21 23:37
    Hier my archived project, q 13.1.
    As I said above, it uses my version of a cog, not chip's one :)
    log file
    Quartus II Archive log --	C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_cog.qarlog
    Archive:	C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_cog.qar
    Date:		Wed Oct 22 08:33:02 2014
    Quartus II 64-Bit		13.1.0 Build 162 10/23/2013 SJ Web Edition
    	=========== Files Selected: ===========
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_alu.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_defs.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_id.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_if.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_mem.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_miniuart.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_seq.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/acog_wback.v
    C:/02_Elektronik/034_AProp/AProp/01_Verilog/cnt.v
    C:/02_Elektronik/034_AProp/AProp/06_Asm/test1.asm.altera.mif
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/acog_muls.cmp
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/acog_muls.qip
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/acog_muls.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/cog_mem_altera.qip
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/cog_mem_altera.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/cog_mem_altera_bb.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/ddr3_cog.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/src/debug.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/db/ddr3_cog.cmp.hdb
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/db/ddr3_cog.db_info
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_cog.qpf
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_cog.qsf
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl.cmp
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl.qip
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl.sip
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl.sopcinfo
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl.spd
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altdq_dqs2_acv_connect_to_hard_phy_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_mm_bridge.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_packets_to_master.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_sc_fifo.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_bytes_to_packets.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_clock_crosser.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_idle_inserter.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_idle_remover.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_jtag_interface.sdc
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_jtag_interface.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_packets_to_bytes.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_avalon_st_pipeline_base.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_jtag_dc_streaming.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_jtag_sld_node.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_jtag_streaming.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_dll_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_hard_memory_controller_top_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_oct_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_sequencer_cpu_cv_synth_cpu_inst.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_sequencer_cpu_cv_synth_cpu_inst_test_bench.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_sequencer_mem_no_ifdef_params.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_sequencer_rst.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_mem_if_simple_avalon_mm_bridge.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_arbitrator.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_burst_uncompressor.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_master_agent.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_master_translator.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_reorder_memory.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_slave_agent.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_slave_translator.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_merlin_traffic_limiter.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_pli_streaming.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_reset_controller.sdc
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_reset_controller.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/altera_reset_synchronizer.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_0002.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_dmaster.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_dmaster_b2p_adapter.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_dmaster_p2b_adapter.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_dmaster_timing_adt.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_mm_interconnect_1.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0.ppf
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0.sdc
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_acv_hard_addr_cmd_pads.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_acv_hard_io_pads.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_acv_hard_memphy.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_acv_ldc.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_altdqdqs.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_clock_pair_generator.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_generic_ddio.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_iss_probe.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_parameters.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_phy_csr.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_pin_assignments.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_pin_map.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_report_timing.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_report_timing_core.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_reset.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_reset_sync.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_p0_timing.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_pll0.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_AC_ROM.hex
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_inst_ROM.hex
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_irq_mapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_make_qsys_seq.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_addr_router.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_addr_router_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_addr_router_002.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_demux.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_demux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_demux_002.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_mux.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_mux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_mux_003.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_id_router.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_id_router_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_id_router_003.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_demux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_demux_003.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_mux.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_mux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_mux_002.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_sequencer_mem.hex
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_software/sequencer.c
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_software/sequencer.h
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/ddr3_ctrl_s0_software/sequencer_defines.h
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_reg_file.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_acv_phase_decode.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_acv_wrapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_mgr.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_reg_file.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_siii_phase_decode.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_siii_wrapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_sv_phase_decode.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl/sequencer_scc_sv_wrapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altdq_dqs2_acv_connect_to_hard_phy_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_mm_bridge.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_packets_to_master.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_sc_fifo.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_st_bytes_to_packets.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_st_clock_crosser.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_st_idle_inserter.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_st_idle_remover.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_st_jtag_interface.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_st_packets_to_bytes.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_avalon_st_pipeline_base.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_jtag_dc_streaming.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_jtag_sld_node.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_jtag_streaming.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_dll_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_hard_memory_controller_top_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_oct_cyclonev.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_sequencer_cpu_cv_sim_cpu_inst.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_sequencer_cpu_cv_sim_cpu_inst_test_bench.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_sequencer_mem_no_ifdef_params.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_sequencer_rst.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_mem_if_simple_avalon_mm_bridge.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_arbitrator.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_burst_uncompressor.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_master_agent.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_master_translator.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_reorder_memory.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_slave_agent.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_slave_translator.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_merlin_traffic_limiter.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_pli_streaming.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_reset_controller.sdc
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_reset_controller.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/altera_reset_synchronizer.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_0002.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_dmaster.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_dmaster_b2p_adapter.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_dmaster_p2b_adapter.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_dmaster_timing_adt.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_mm_interconnect_1.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_acv_hard_addr_cmd_pads.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_acv_hard_io_pads.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_acv_hard_memphy.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_acv_ldc.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_altdqdqs.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_clock_pair_generator.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_generic_ddio.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_iss_probe.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_phy_csr.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_reset.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_p0_reset_sync.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_pll0.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_AC_ROM.hex
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_inst_ROM.hex
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_irq_mapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_make_qsys_seq.tcl
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_addr_router.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_addr_router_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_addr_router_002.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_demux.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_demux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_demux_002.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_mux.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_mux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_cmd_xbar_mux_003.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_id_router.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_id_router_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_id_router_003.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_demux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_demux_003.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_mux.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_mux_001.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_mm_interconnect_0_rsp_xbar_mux_002.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_sequencer_mem.hex
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_software/sequencer.c
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_software/sequencer.h
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/ddr3_ctrl_s0_software/sequencer_defines.h
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_reg_file.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_acv_phase_decode.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_acv_wrapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_mgr.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_reg_file.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_siii_phase_decode.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_siii_wrapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_sv_phase_decode.v
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/ddr3_ctrl_sim/ddr3_ctrl/sequencer_scc_sv_wrapper.sv
    C:/02_Elektronik/034_AProp/AProp/07_DDR3/test1/incremental_db/compiled_partitions/ddr3_cog.db_info
    c:/altera/13.1/quartus/bin64/assignment_defaults.qdf
    	======= Total: 219 files to archive =======
    	================ Status: ===============
    All files archived successfully.
  • 65816581 Posts: 132
    edited 2014-10-27 05:13
    Ale wrote: »
    Is this one working?
    No. Because of what I explained above :(. But it compiles :)
    I'll post it here, there is another DDR3 example here: https://github.com/tommythorn/BeMicro-CV
    It is a NIOS-II with DDR3 example.
    This one, the one I posted before is quite nice because it is not only a working DDR3 example, it also has SignalTap, here : http://www.alterawiki.com/uploads/1/1c/QuartusII_projects.zip
    I hope I can make some progress...
    edited 2015-08-08 15:11
    The NIOS II example works too. It has a (very interesting) jtag uart. To be able to see something you have to fire the nios2-terminal. The best is to invoke the shell script
    in c:\altera\15.0\nios2eds\nios2_command_shell
    and from there the nios2-terminal.
    - Compile the example
    - Load it to the BeMicroCV A2
    - run nios2-terminal
    - Enjoy blinking LEDs
    This is a QSys example. It would be great if
    - we could build our own QSys components, a P1V would be great, the HUB would be DDR3 DRAM, no idea how much time from request to data you get, but if we have 8 80 MHz cycles (at least), that means 100 ns, we should be getting data in this time, I think.
    It would mean an avalon-enabled P1V, whatever that exactly means (I have a only rough idea that is improving while reading the document posted below).
    Happy coding !
    Link to a couple of useful pdfs: JTAG-UART
    Using Terminals
    I found it ! Making QSys components it wasn't that difficult to find...
    1584 x 655 - 95K
  • Hey Ale,
    Your efforts will pay off nicely if you can get it going.
    I've been working on similar concept but with regular SDRAM, not DDR3 in order to keep things simpler. On paper at least I found you can just about manage when running memory at 144MHz (eg. for SDRAM on DE0-Nano or BeMicro MAX10) and the P1V at 72MHz to get the data back in a single hub cycle for one or two COGs. The problem is you basically don't know the memory address to read/write until near the end of the second P1V CPU cycle, really just leaving you with 4 more CPU clocks before your data needs to be ready to latch if use the regular ALU path (or possibly 5 if you bypass it). So latency will likely become the major issue depending on propagation delay and DRAM/FPGA setup time etc. I also think there is a possibility of inserting an extra M4 cycle to give you one extra clock (ie. 8 clocks instead of 7 in the hub) and still fit in the existing overall hub cycle timing window which would be ideal for LMM and other deterministic applications.
    So far I've started planning some Verilog state machine stuff to try to do this but still have to figure out a few more things like SDRAM initialization and FPGA clock generation etc which will no doubt take me a while to nail it all.
    I'll have to keep an eye out if you get your Nios approach working with the P1V. It's likely there's a Nios driver for regular SDRAM lying about somewhere so it might still be an option for me on the DE0-Nano if it can access external memory in a single hub cycle otherwise I'm still gonna have to do my own thing. I'm reasonably confident what we want is doable in principle, it's just a matter of time and effort and also whether the board layout and FPGA timing allows the maximum memory speed to be attained.
    Cheers,
    rogloh
    edited 2015-08-10 09:55
    I am working with the "ddr3_example":
    I am trying to understand the trace given by signal tap... and I really seem to be missing something: The problem is I don't really know how this whole "bus traffic generator" works.
    I see that writes are issued and reads... but I do not see that the reads get the written data...
    It would be great if someone would also help a bit here :), anyone ?
    Here the avalon handbook
    edited 2015-08-15 19:32
    Hi all,
    I wish I could offer help, but I just came to the FPGA party. (Very recently, I bought a BeMicroCV, a BeMicroCVA9, and a LatticeXP Bravia2). I have loaded the Propeller 1V into the BeMicroCV and am interested in using it with the DDR3 Ram. I see that you have been working on this for quite some time.
    I do suspect that the DDR3 ram will demand quite a bit more power. Has that been taken care of?
    For now, I should just follow along and learn. At least I do understand most of what you are trying to do. I am not very clear on Ale's Cog image which included a hardware UART. So I will poke around and try to catch up.
    It does seem that your approach of clocking the DDR3 at 300mHz is conservative. I have read that some of the Cyclone V E devices might clock 400mHz and all do at least 333mHz. Maybe I missed something.
    I'll be quiet and just lurk.
    Hei Loopy,
    The 2 examples that I found also use 300 MHz, the BeMicro handbook says somewhere so. Maybe it can be pushed to 400 no idea, but for testing I'd go even lower if necessary. My first step is to replace the traffic generator with somethig i made myself my cog or p1v or something, and to measure turnaroud times, those times will tell what can we expect from this memory pool, I think.
    If it is too slow, what I expect, it means that we may have to make a dummy read, and then we get say 2 longs of data or four, and lock it to a specific cog. One can configure up to 6 bus masters so the arbitration is not in your hands but that will need a bit of work.
