Plotting graph On vb net
Dear all,
I am new to vb net. I am collecting data from Arduino and dispalyed on VB net through serial communication. Now i wanted to plot graph for time vs serial data received. Can some one suggest me how can do this. How to choose chart. Is there any example code .I have written code up to receive data and display it.Now i wanted to plot graph time Vs current value
Imports System
Imports System.IO.Ports
Imports System.ComponentModel
Imports System.Threading
Imports System.Drawing
Public Class Form1
Dim myPort As Array
Dim Distance As Integer
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
myPort = IO.Ports.SerialPort.GetPortNames()
PortComboBox.Items.AddRange(myPort)
BaudComboBox.Items.Add(9600)
BaudComboBox.Items.Add(19200)
BaudComboBox.Items.Add(38400)
BaudComboBox.Items.Add(57600)
BaudComboBox.Items.Add(115200)
ConnectButton.Enabled = True
DisconnectButton.Enabled = False
End Sub
Private Sub ConnectButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ConnectButton.Click
SerialPort1.PortName = PortComboBox.Text
SerialPort1.BaudRate = BaudComboBox.Text
SerialPort1.Open()
Timer1.Start()
'lblMessage.Text = PortComboBox.Text & " Connected."
ConnectButton.Enabled = False
DisconnectButton.Enabled = True
End Sub
Private Sub DisconnectButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles DisconnectButton.Click
SerialPort1.Close()
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
Try
SerialPort1.Write("c")
System.Threading.Thread.Sleep(250)
Dim k As Double
Dim distance As String = SerialPort1.ReadLine()
k = CDbl(distance)
ListBoxSensor.Text = k
Catch ex As Exception
End Try
End Sub
Private Sub Relay_ON_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Relay_ON.Click
SerialPort1.Write("1")
End Sub
Private Sub Relay_Off_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Relay_Off.Click
SerialPort1.Write("0")
End Sub
End Class
