OpenSpin-V — Parallax Forums
OpenSpin-V
Willy EkerslykeWilly Ekerslyke Posts: 29
edited 2014-09-21 10:42 in Propeller 1
The attached is a bit of a hack to OpenSpin so that those wishing to try out Cluso's AUGDS/S, rogloh's PUSH/POP/LOAD/STORE and my MUL/S instructions can do so without having to deal with the instruction's binary.
I have to confess that due to lack of time I've not actually run any generated code on a P1V - relying instead on inspection of the output to validate the encoding.
There's a readme in the archive and a .spin file that simply lists the new PASM instructions. Obviously this is the full OpenSpin compiler so unless I've really messed up it will handle all existing spin/PASM code too.
Ultimately this will need to become a github fork of the official OpenSpin but there seems little point at the moment while we're just experimenting.
I'll try to keep this up to date with further additions/changes the P1V instruction set but the code is there for others to chip in as well.
UPDATE v2: Added support for rogloh's PUSH POP RETX JMPX CALLX. Also added a 'lst' directive to control printing of the instruction binary.
    edited 2014-09-19 17:52
    Tks willy. Won't get much time to test for 2 weeks as have daughter husband and twins visiting from s. Korea
  • roglohrogloh Posts: 6,211
    edited 2014-09-19 19:01
    Good stuff Willy. I just now took a brief look and see you've included my HUB based PUSH & POP and LOAD/STORE change so far. I didn't see the COGRAM PUSH/POP/CALLX/RETX as well in there. Those all use the ONES instruction opcode 000111. That would be nice to play with too if you were planning to include it at some point.
    Cheers,
    Roger.
  • Willy EkerslykeWilly Ekerslyke Posts: 29
    edited 2014-09-20 00:05
    Roger
    Not sure how I missed those :( I'll see what I can do over the next couple of days.
  • pik33pik33 Posts: 2,416
    edited 2014-09-20 00:35
    Is it possible to make a definition file like
    [ports]
    outc $1ed
    inc  $1ee
    dirc $1ef
    [instructions]
    div  011001 000i 1111 ddddddddd sssssssss
    atan 111111 1111 0011 ddddddddd sssssssss
    to make adding new opcodes easier at user level?
    edited 2014-09-20 01:21
    Pik33,
    Yes it's possible but not without rewriting the entire assembler part of OpenSpin. The current assembler is very much tied to the real P1 instruction set and also shares features with the Spin compiler.
    Perhaps adding a macro capability would go some way to giving user-level flexibility - I'll give it some thought but make no promises :)
  • ozpropdevozpropdev Posts: 2,793
    edited 2014-09-20 04:09
    pik33
    Using a CON block to define your port definitions solves part of your request.
    CON
        #$1ed,outc,inc,dirc
    I'm currently working on a custom assembler that allows for user defined instruction coding but it's very much a
    work in progress. My radical P1V experiment requires it for 10bit source & destination addressing. I need
    it to tweak the booter and allow the spin interpreter to take advantage of double cog ram.
    This will assist in moving the SPR's from $1F0 to $3E0 too. :)
    edited 2014-09-20 14:41
    I would recommend keeping the SPRs from $1F0..$1FF as there are a number of quirks that use these fixed locations. Even the verilog uses a quirk to clear down these registers at cog load time.
    edited 2014-09-20 19:34
    Cluso99 wrote: »
    Ray
    I believe I've already sorted the SPR zeroing issue with the following change to cog_alu.v
    		: run || ~&p[8:4]		? bus_q
    changes to
    		: run || ~&p[9:5]		? bus_q
    In order to increase the number of available SPR's for more ports,cpunters.etc I have to move them to $3E0 to $3FF (32 rges instead of 16)
    This was also necessary to allow the spin interpreter to be expanded without overlapping the SPR address space. Many more changes have been made to accommodate
    the 10 bit addressing. It's a bit of departure from the "standard P1". :);)
    Cheers
    Brian
    Updated first post with new version (v2).
