Using the Propeller as a VGA switching unit
hi all!
I'm currently testing out my fpga emulation of the Lynx computer on my home-built box.
I don't have direct access to any of the pins on the fpga - 10 connections link the fpga and propeller.
Two pins are used for PS2 keyboard - again copied over from the prop - but in a spin cog.
vsync/ hsync come in on P0 and P1
RGB on P2 - 7
So these 8 pins need copying upward to the VGA output pins on the prop.
I'm currently using the attached code to copy the output (VGA) of my resurrection over to the VGA output pins
on the propeller.
Needless to say as you'll see it's a bit of a trial and error approach - this version was just the 'best' in
terms of least artifacts.
I've also been trying to stop and restart the fpga_vga driver but when I restart the output is more corrupted -
something not right with my understanding of start/stop on cogs probably.
CREATE_FPGA_wUpload - Archive [Date 2014.09.19 Time 12.36].zip
the most relevant section being this one - 3 cogs used with unrolled loops
NOTE: the mask is used to allow me to re-use the pins again as inputs to the fpga to transfer over ROMs etc.
in the attached code zip the mask has been set to 00000111 and hence I have a blue display of anything the
fpga creates whilst having 5 lines to do comms with.
Change the mask to $ff to get full VGA copy.
Any great ideas welcome on how to improve the output - given the lack of clock synch between the two osc.
On a related point - can the INPB register be used as an internal 'video bus' like the P0-7 trick?
Warm regards from still sunny Mid Wales!
Pete
RGB on P2 - 7
on the propeller.
PUB Open(lower8vidmask,ptrToParams) : i| j
Close
i := lower8vidmask << 16
'j := 16 & %100000 == 0
reg_dira := i ' & j
'reg_dirb := i & !j ' unused by prop at present? maybe was being used as a spare register - ah
' actually is this another internal 'bus' like the pins can be used?
result := cog1 := cognew(@fpga_read,ptrToParams) + 1
result := cog2 := cognew(@fpga_read,ptrToParams) + 1
result := cog3 := cognew(@fpga_read,ptrToParams) + 1
PUB Close
if cog1
cogstop(cog1)
if cog2
cogstop(cog2)
if cog3
cogstop(cog3)
if cog
cogstop(cog~ - 1)
DAT
org 0
' * Get Parameters and Initialise Driver *
fpga_read
' mov paramPtr, PAR ' Point to parameter block
mov dira,reg_dira 'set pin directions
:read_byte
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
mov r0, ina
shl r0, #16
mov outa, r0
jmp #:read_byte
Pete
movs outa, ina shl outa, #16That said, how do you deal with outputs being OR'd? You're starting three cogs with the same loop ...with only 1 cog running the copy I get no display - I'm assuming that the sync signals are not accurate enough - the more cogs I add the better it gets (at the expense of ghosting due to the diff cogs OR effects)
the combination of unrolled loop length vs number of cogs gave me the best result using the code shown.
I feel it shoudl be possible to imporve things by using only two cogs or so - and synching them so that they sample the input VGA on a ping-pong basis.
I will try out your suggestion thank you!
Two cogs of the following code and the display is fairly useable, a single cogs gives more definition at the expense
of slight flicker.
:read_byte movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 ' not bad movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 movs outa, ina shl outa, #16 jmp #:read_bytewell worth a go
I've been pumping SRAM data from the fpga into the propeller and creating the VGA/TV in the prop until the present time. However the Lynx
will require 256x248x8 bits (fulll 3 plane system) which isnt possible at present on the prop so hence i generate in the fpga and pass it through.
here are some videos of the previous system I was using.
https://www.youtube.com/channel/UCCa2b8ThIwUCbyQDOewNu2A
my thanks once again for your help.
