Find Hansen's miniature engines — Parallax Forums
Martin HodgeMartin Hodge Posts: 1,246
edited 2014-09-13 17:04 in General Discussion
These are amazing works of art to me.
[video=youtube_share;UGksYSwFucI]
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-09-12 20:47
    That is quite amazing.
    edited 2014-09-13 08:16
    Appears to be a model of a Sterling engine.
    http://en.wikipedia.org/wiki/Stirling_engine
    They got me into researching them for a few weeks as I thought they might be useful for a solar air conditioning power source. One at least needs fans to move the air. It is something that might be possible, but when you rate a/c in the equivalent of tons of ice, the question comes down to where are you going to store 2 tons of water/ice in your home in order to get daily cooling needs met.
    I suppose one could build a cellar just to store the ice and duct it up through the house. But you still need quite a bit of refrigerant if you aren't having a compressor drive the fluid. Add another big tank for that into your cellar. Pretty soon the whole device takes up a lot of space. The sterling engine would likely go on the roof, and it is hard to get them in more than a few horsepower.
    edited 2014-09-13 09:17
    Check out this miniature Nitro V8
    edited 2014-09-13 15:16
    No Loopy, this is an internal combustion Diesel style engine. It's a style that hasn't ben built regularly for a long time but you see variants especially for ship propulsion around the turn of the 20th century. Some were created by converting steam engines, and it is a feature of the design that the cylinder pressures are low, in the 300 PSI range, so that the parts are subjected to minimal strain. The hot bulb is necessary to preheat the fuel so that it will self ignite at relatively low pressure, and the pre-heater seen inthe demo is normally turned off after the engine has been running because the engine's heat of operation takes its place.
  • Mark_TMark_T Posts: 1,981
    Lovely.
    Had a hunch, so Googled "miniature Merlin engine":
    Scaled down Rolls-Royce Merlin, complete with supercharger:
    http://www.enginehistory.org/ModelEngines/merlin_xx.shtml
    https://www.youtube.com/watch?v=0xe1LL1IC7Y
