Use Catalina-Compiler in Code::Blocks (Linux)
im trying to set up the Catalina Compiler with Code::Blocks and i got some Problems with it.
In the PDF-Documentation to use Catalina with CodeBlocks he talks about a Plugin in ../catalina/codeblocks/Linux/64_bit/libcompiler-0.99.cbplugin
But there is no Plugin (or Linux-Directory). I searched the whole catalina-directory for a .cbplugin-File, but nothing...
Can anyone explain me how i can use the Compiler with CodeBlocks or where i can get the Plugin?
Thanks & (and sorry for bad english)
gfcwfzkm
gfcwfzkm
But in Code::Blocks i get the error message:
One or more plugins were not loaded. This usually happens when a plugin is built for a different version of the Code::Blocks SDK. Check the application log for more info.
Is there a new Plugin for CodeBlocks or which Version of Codeblocks accepts the plugin?
