my spinneret can not be reprogram
I have a problem and i need help.
the last time my server was program, i modify the code HTTPServer.spin leaving P24 P25 P26 P27 P31 P30 some as input and other as outputs , and since that time I could not reprogram the server.
why this happens?
or maybe I'm not connecting well the FTDI ?
Anyone know of any tutorial on how to program the server with a FTDI¿!?
why this happens?
I'll find a picture.
Hope this helps.
Here is a link to the pdf of the manual for the Spinneret.
http://www.parallax.com/sites/default/files/downloads/32203-Spinneret-Web-Server-Documentation-v1.1.pdf
TX ---> RX
RX --->TX
RES --->RESET
VSS -->GND
I think the "RES--->RESET" should be "DTR--->RESET".
At least that's how I see it with the labels used in post #12.
What program are you using to program the Spinneret?
