Switch to synchronous enable? — Parallax Forums
SeairthSeairth Posts: 2,474
edited 2014-09-12 07:44 in Propeller 1
I notice that the cogs use an asynchronous enable. If these signals were switch to synchronous enables (remove all the "negedge ena"), what would be the repercussion, other than the cog enable/disable being delayed by one clock cycle. From an FPGA perspective, this change has little impact on Cyclone IV synthesis, but has a significant positive impact on Cyclone V synthesis. For the BEMicro CV, usage goes from 8522 ALMs (using async enable) to 8118 ALMs (using sync enable). Further, optimizing for size, you can get this down to 7097 ALMs!
Any thoughts?
  • jmgjmg Posts: 15,183
    edited 2014-09-11 16:06
    Seairth wrote: »
    Any thoughts?
    I'm not quite following - "negedge ena" still sounds synchronous to me, just on the other edge ?
    Sometimes that is done as a means of pipelining, without a full clock period cost.
    That said, it is rare to see both edges used in modern FPGA synth, where routing tends to dominate over register delays.
    If the tools seem to have a preference to one construct, then certainly explore that construct.
  • SeairthSeairth Posts: 2,474
    edited 2014-09-11 17:19
    jmg wrote: »
    In the following Verilog, ena is an "asynchronous" signal, as it causes the always block to execute as soon as ena goes low, regardless of the state of clk_cog.
    always @(posedge clk_cog or negedge ena)
    if (!ena)
        run <= 1'b0;
    else if (m[3] && (&px))
        run <= 1'b1;
    Now, compare that to the following code. In this case, ena is "synchronous" because the combinational code doesn't change the state of run (based on the value of ena) until the rising edge of clk_cog.
    always @(posedge clk_cog)
    if (!ena)
        run <= 1'b0;
        run <= 1'b1;
    The register that drives ena (hub:cog_ena) is updated by either clk_cog or the asynchronous chip reset (nres). By having the above block(s) use an asynchronous enable, cogs are enabled/disabled as soon as hub:cog_ena latches a new value (which can either be on a clock edge or the global chip reset. By having the above block(s) use a synchronous enable, cogs are enabled/disabled on the next clock after hub:cog_ena latches a new value.
    When targeting Cyclone IV, there is very little difference the the LE count. When targeting Cyclone V, the ALM savings is significant. I have not checked to see how this affects fMax. I also do not know how this affects ASIC design (in the off chance Parallax invests in a P1V variant, this is obviously an important concern).
    In the end, it might not be worth making the change just for improved Cyclone V utilization. Just thinking out loud...
    edited 2014-09-11 18:43
    Seairth wrote: »
    Looking that the netlist results, I notice that the above code inserts an additional mux to handle the synchronous enable. I don't know whether this is slower than the asynchronous enable driving the /clr pin on a flip-flop, though. I'm guessing it is. But I still don't know if it makes any difference overall.
    edited 2014-09-11 19:32
    Oops! Quartus/Verilog doesn't like this - seems it is illegal :(
    Might it be better to have a separate always to initialise the values like this (using cog.v as an example)...
    // initialise values
    always @(negedge ena && !ena)
    begin
        run <= 1'b0;
        m   <= 5'b0;
        p   <=1'b0;
        c   <= 1'b0;
        z   <= 1'b0;
        dira <= 32'b0;
        cancel <= 1'b0;
    This way, these statements..
    if (!ena)
    else
    can all be simplified to..
    always @(posedge clk_cog && ena)
    edited 2014-09-11 19:34
    Seairth wrote: »
    That sounds like it adds logic ? Is that for Cyclone IV or V - if it uses LESS resource in Cyclone V, that sounds like something in the Cyclone V fabric allows removal of extra logic ( eg a cell with a CE ? )
  • thoththoth Posts: 75
    edited 2014-09-11 21:44
    Seairth wrote: »
    Any thoughts?
    I can't see how adding an additional layer of gating logic can make the CV compile a design with fewer gates. As I understand it, synchronous gating is .AND.ing the clock with the reset signal and storing the result in a flop for the next posedge. How can this make for less circuitry? Not saying you're wrong but it doesn't make much sense to me.
    edited 2014-09-11 22:48
    thoth wrote: »
    I can't see how adding an additional layer of gating logic can make the CV compile a design with fewer gates. .
    I think that is a resource-mapping artifact, it is not actually compiling to gates.
    The Altera DOCs show a number of differences between Cyclone IV and Cyclone V granular building blocks.
    The IV does have a Clock Enable, but that is LAB (16 x LE) wide, so that could force more usage.
    The V does not show an explicit enable, but does have routing to create one, so maybe a MUX is closer to what the fabric actually implements, so it reports like that.
    It is still buried within the ALM, so it is not counted as another item consumed.
    Cyclone V : Adaptive Logic Modules Resources
    One ALM contains four programmable registers. Each register has the following ports:
    • Data
    • Clock
    • Synchronous and asynchronous clear
    • Synchronous load
    Cyclone IV Logic Elements Each LE has the following features:
    ■ A four-input look-up table (LUT), which can implement any function of four variables
    ■ A programmable register
    ■ A carry chain connection
    ■ A register chain connection
    jmg wrote: »
    Does that mean that the gate structures I see in the RTL view are not actually what's being done in the logic of the chip? Does the technology map view do a better job?
