Question About Parallax 2 x 16 LCD — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2014-09-09 06:05 in General Discussion
I have this LCD. In the product description it states there is a built in Piezo speaker for combining sounds with the display. Does anyone have any Spin code that uses the Piezo speaker? I looked in the OBEX and did not see anything. I would like to add this to my WT and have it make sounds while displaying data.
  • dgatelydgately Posts: 1,646
    edited 2014-09-08 22:38
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      TX_PIN        = 1
      BAUD          = 19_200
      LCD_BKSPC     = $08                                   ' move cursor left
      LCD_RT        = $09                                   ' move cursor right
      LCD_LF        = $0A                                   ' move cursor down 1 line
      LCD_CLS       = $0C                                   ' clear LCD (follow with 5 ms delay)
      LCD_CR        = $0D                                   ' move pos 0 of next line
      LCD_BL_ON     = $11                                   ' backlight on
      LCD_BL_OFF    = $12                                   ' backlight off
      LCD_OFF       = $15                                   ' LCD off
      LCD_ON1       = $16                                   ' LCD on; cursor off, blink off
      LCD_ON2       = $17                                   ' LCD on; cursor off, blink on
      LCD_ON3       = $18                                   ' LCD on; cursor on, blink off
      LCD_ON4       = $19                                   ' LCD on; cursor on, blink on
      LCD_LINE0     = $80                                   ' move to line 1, column 0
      LCD_LINE1     = $94                                   ' move to line 2, column 0
      LCD_LINE2     = $A8                                   ' move to line 3, column 0
      LCD_LINE3     = $BC                                   ' move to line 4, column 0
      LCD_CC0       = $F8                                   ' define custom char 0
      LCD_CC1       = $F9                                   ' define custom char 1
      LCD_CC2       = $FA                                   ' define custom char 2
      LCD_CC3       = $FB                                   ' define custom char 3
      LCD_CC4       = $FC                                   ' define custom char 4
      LCD_CC5       = $FD                                   ' define custom char 5
      LCD_CC6       = $FE                                   ' define custom char 6
      LCD_CC7       = $FF                                   ' define custom char 7
      nl64th        = 208  'note length 1/64th
      nl32nd        = 209  '1/32nd
      nl16th        = 210  '1/16th
      nl8th         = 211  '1/8th
      nlqtr         = 212  'qtr
      nlhalf        = 213  'half
      nlwhole       = 214  'whole
      nscl3         = 215  '3rd scale (A=220Hz)
      nscl4         = 216  '4th scale (A=440Hz)
      nscl5         = 217  '5th scale (A=880Hz)
      nscl6         = 218  '6th scale (A=1760Hz)
      nscl7         = 219  '7th scale (A=3520Hz)
      ntA           = 220  'A
      ntAs          = 221  'A sharp
      ntB           = 222  'B
      ntC           = 223  'C
      ntCs          = 224  'C sharp
      ntD           = 225  'D
      ntDs          = 226  'D sharp
      ntE           = 227  'E
      ntF           = 228  'F
      ntFs          = 229  'F sharp
      ntG           = 230  'G
      ntGs          = 231  'G sharp
      ntPause       = 232  'pause for current note length
    OBJ
      LCD           : "FullDuplexSerial.spin"
    PUB Main | idx
      LCD.start(TX_PIN, TX_PIN, %1000, 19_200)
      waitcnt(clkfreq / 100 + cnt)                ' Pause for FullDuplexSerial.spin to initialize
      lcd.tx(LCD_CLS)
      lcd.tx(LCD_BL_ON)                                 ' backlight on
    ' messing with music
      repeat idx from 0 to 9
        lcd.tx(muzak[idx])
        lcd.tx(muzak2[idx])
      repeat 10          ' flash blacklight (again, more playing with code)
        lcd.tx(LCD_BL_OFF)
        waitcnt(clkfreq / 40 + cnt)
        lcd.tx(LCD_BL_ON)
        waitcnt(clkfreq / 5 + cnt)
    DAT
      Muzak       byte      215, 210, 216, 220, 226, 230, 217, 226, 230, 220
      '                    1/16, 4th, A   , D#,  G,  5th, D# , G ,  A
      Muzak2      byte      215, 210, 216, 220, 220, 220, 211, 220, 220, 220
      '                    1/16, 4th, A  , A  , A  , 1/8, A  , A  , A
