Run P1v under emulation?
David Betz
Is there a way to run the P1 Verilog code in an emulation mode that will give waveform traces? I have a sneaking suspician that if I start modifying the code I'll rapidly break something and it won't be easy to debug on the FPGA.
Quartus has a simulator and a logic analyzer built in but I don't know how it works (yet). I'm going to have to look into it though, because as you say, testing on the FPGA is not easy, especially if every compilation takes 10-15 minutes (reminds me of the "Good Ole Days" of my 80386 PC with a whopping 8MB of memory an 70MB of hard disk, which took 20 minutes to compile hello.cpp in Visual C++ 1.0 in 1993). I'm trying to reorganize the hub memory module a little bit to eliminate the copy-paste code and I feel as if I've been waiting for the compiler the entire weekend without hardly making any progress...
===Jac
My VGA is only compiled for cog 0.
Also, simply reducing the cogs to say 4 also reduces compile times. (just change the i++ statement)
My times are ~3.5 minutes with 4 cogs, vga on 0, 4KB cogs, 48KB hub, Quartus14 Windows8.1 i3-3217U (1.8GHz dual core) on Acer Aspire E1-570 laptop.
I too would be very interested to see how to get a timing diagram from QUartus. There is also a $display?? statement that should execute during compile but I haven't been able to get this to work.
Maybe a variant of this could be implemented on P1V that fills a chunk of the available external RAM on our boards.
With this type of data we can get at the nuts and bolts of our work/changes.
Even a single-step function would assist here too....
ModeSim also barfs on things like an extraneous trailing comma whereas Quartus will just suck it up.
Assuming we can get past these (and probably other) issues there is then the problem of creating a stimulus file that will mimic the incoming serial programming stream. Perhaps, instead, we'd need to preload the Cog RAM with a $readmemh and modify the boot code to suit.
I seem to recall Chip saying that he doesn't use simulation - relying on analysis of output instead. No wonder really
Ugh. I see what you mean. I'm getting "errors" left and right. And as soon as I fix one, three more pop up.
