Next SimpleIDE Issue: PING and 2 Servos
So I know the Servos work and I know the PING works. However, in the following code only the Servo on Pin 14 will run but not the one on Pin 15. Helppppp!!!!
/*Test Ping Distance.c Measure and display Ping))) Ultrasonic Distance Sensor distance measurements. http://learn.parallax.com/propeller-c-simple-devices/sense-distance-ping */ #include "simpletools.h" // Include simpletools header #include "ping.h" // Include ping header #include "servo.h" int main() // main function { while(1) // Repeat indefinitely { int cmDist = ping_cm(13); // Get cm distance from Ping))) print("cmDist = %d\n", cmDist); // Display distance pause(200); // Wait 1/5 second if(cmDist <6) { servo_speed(14, 100); // P18 servo full speed CCW servo_speed(15, -100); // P19 servo full speed CW } else servo_speed(14,0); servo_speed(15,0); } }
