ViewPort Bugs?
Hi All,
First post so forgive me if I'm in the wrong spot, or commit so other faux-pa. I have been using / playing with the Propeller and ViewPort with general Success. But I keep running into strange bus with ViewPort. Here are two:
1) Sometimes when stepping though spin code it jumps down several lines of code with one "step into" press, not always in the same place and it doesn't happen every time
2) I have had instances when I run some code, it won't work properly with viewport, but when I compile/run the exact same code with the propeller tool it works. For example a command to turn on a LED via a port.
I am only use the vp : "Conduit" declaration, if I also use the Vp.share(@XXX,@YYY) the variable names don't show up, when I leave it out the names automatically appear...
I am using Version 4.8.4
many thanks
KB
many thanks
KB
Edit: When I had problems like you describe in #2 they were usually caused by me trying to use the Propeller's serial port in my program.
Welcome to the forums!
If you could post your code as a SPIN archive, that would help. I am also running Ver 4.8.4.
Also, If the Hanno, the author does not pick up on it here, he has a forum on his website.:
http://onerobot.org/forums/forum/viewport/
I'd set a break point at line 110, step into that section and it jumps from 189 to 199. I typically keep hitting "step into " when going through the code.
I have had this in other spin files too - it kinda shake my confidence in the debugger. I will see if I can recreate the other issue where the code runs differently when loaded from Viewport or the Propeller tool...
For some context I am still learning the Propeller and this code is for reading in data from some I2C sensors and storing them to an array for later usage.
thanks for the help
KB
Controller.spin
regards,
KB
For anyone to try your code out, it has to contain all the spin files. you need to archive the whole project using File>Archive with the top object in current view.
There may be problems with the other objects. The SPIN file that you posted can not be run correctly, because it relies on other objects.
BTW, did you try to get Hanno on his forums?
I mentioned the Propellers serial port because it is used exclusively by ViewPort and I have at times didn't remember using the serial terminal to debug with the regular Propeller tool. If you don't disable the
Parallax Serial Terminal when you are using ViewPort it will cause problems where the program works with the Prop tool but not with ViewPort which I don't think is your problem. The only other thing I can think
of is ViewPort requires a quality USB cable. Some of the retractable cables and other cheap cables can cause problems. You can ask on the OneRobot forums as Publison mentioned above.
You meant IDE, right?
And IED is rather harsh on delicate electronic equipment.
