Tired after lots of Quartus
ozpropdev
LOL
I just realized if you say that quickly with an Aussie accent it sounds like I'm talking about something else!
Riding the new roller-coaster called "Quartus" and felling terror, nausea and the thrills of FPGA/Verilog I share the following observations.
Many thanks to Parallax for allowing us to look under the "hood" of the Propeller. It has given me a whole new appreciation for the device.
Not that I fully understand it all yet but I understand it enough to get addicted to this whole FPGA experimentation universe.
With my new found (limited) knowledge of Verilog I feel quite "dizzy" thinking about the code Chip was working with in the "BIG" P2 with
it's pipelines,indirect registers,pointers,multi-tasking etc.etc. I know have a new appreaciation for the "battle" Chip has had with the
whole design process and dealing with large cycle times in between compile times and testing.
I now understand it when Chip uses the term "Virtually for free" in regard to some instructions and realize the complexity of others.
To sum up, WOW! what a ride we are all on.
Hats off to Chip for your great work. Thanks for sharing. Much appreaciated
Cheers
Brian
Cheers
Brian
It's easy to see how simple some things are, and how complex others are. I am still trying to get AUGDS working - well the basics working so I can verify it.
Many thanks to Chip and Parallax for the brave step in sharing this with the world. I am truly indebted to you.
Ray
We really appreciate it mate! Gudonya! You're a top sport.
Peter
I tried to execute directly from inb. The first try failed - the Propeller Tool can't detect the Propeller chip. What looked to be simple (stop the program counter if it reaches inb) is not as simple as it looked. I don't know why this one if added destroyed the ability to detect the Propeller. and it needs some investigation. But now I am tired too. I overdosed the Quartus with some propeller tool and BST added.
But what I wanted to say is that I just use the simulator, icarus verilog. It allows for fast development. Of course that it is not like compiling for a target because you can make many mistakes that result in non-synthesize-able code. `default_nettype none helps but does not solve the problems
Chip gave us something great but my attention went away as I heard about RISC-V
I just wanted to say, that there are other ways to develop the P1V beyond what Chip gave us and not necessarily using quartus.
Have fun,
Ale
Been there, had that. Having to wait for tools is horribly unproductive.
I've been through that too. I once hacked a project that worked perfectly using Icarus verilog, but wouldn't synthesize with any tool. At the time I had no idea why. Since the P1V thing came out, I sat down and read more about verilog. The reason my code wouldn't synthesize then became very clear (invalid verilog!). So obviously Icarus has limits, and they should be made clearer somehow.
Icarus is a great tool for learning what the verilog does without waiting forever for vendor tools.
I mean this is wrong but can be used in icarus with not very nice results...
you don't event get a warning for that
And the errors you get, I mean how the code behaves can be quite bluffing
Does that mean there is a small test run of the Pin-cells coming up on that process ?
