DE0-Nano at 100Mhz — Parallax Forums
DE0-Nano at 100Mhz
JkaneJkane Posts: 113
edited 2014-08-27 20:45 in General Discussion
Hello,
I was wondering if this fpga can run at 100-120 MHz, it seems to have a 50 Mhz clock, but is it like the propeller where you can change out the clock and use a faster clock, I need a 30 ns clock pulse, (a single pulse), I used the propeller with assembler to do the original project, but I would like to use a FPGA board to redo the code to make it handle very tiny pulses.
I also am not sure if this is the correct place for this question, I can move it elsewhere if you know where it belongs.
regards
Jeff Kane
  • jmgjmg Posts: 15,198
    Search in the Altera Data for PLL, and if you wanted some examples, you could look at the P1V verilog examples, in that forum area.
    Many have the P1V running at 100+ MHz, so the clock configure details will be useful.
