32400B Xbee-USB-Adapter - Vdd pad as +5V output
Great little board, my XBee 900HPs are happy. I am powering them with battery packs that supply over USB cables (+5V only). Now I need to operate a relay that needs +5V on its coil. I was hoping to pull +5V off the Vdd pad of the adapter. This doesn't seem to have +5V on it however, but about +1V.
The schematic shows the Vdd pad directly connected to the +5V IN of the FAN chip, so I'm confused why I see only +1V.
Thanks.
Thanks.
Welcome to the forums!
Looks likes you should get a +5 volt off of the VIN or VDD. What measurement device are you using? When using a DVM I forget to switch between AC and DC measurement.
If you do get it sorted out, don't forget to put a diode across the relay. I hope the relay doesn't more current than the battery can handle. A link to the relay in use would be helpfull.
In the schematic there are also diodes designed to prevent voltage from one source or the other from bleeding across. Basically voltage at Vdd cannot be seen at Vusb and voltage at Vusb cannot be seen at Vdd. Since the Vdd is an input terminal you would only be able to get voltage from it if the voltage was being fed into that pin.
Confused.
Are we looking at the same schematic?
http://www.parallax.com/sites/default/files/downloads/32400-XBee-USB-Adapter-Documentation-v1.0.pdf
I do not see diodes except for LED's
I'm not sure what the OP means by 3400B.
Tip: Always check your board revision against the docs/schematic.
Duly noted. That's why people should like to the particular board. I didn't notice the Rev B.
You guys are always ahead of me.
Most definitely you both are ahead of me by miles! I also was using the rev A schematic. The diode explains it.
I will use a different +5V source for the relay. Problem solved. Thank you.
Most of my XBEEs are standalone. I configure them with via USB and a laptop, but once configured they need not be connected again. Only the hub needs the serial USB connection.
The XBEE remotes use a Digital out to a relay, and maybe a couple of analog inputs to report on batteries. Very simple (a 3.3 to 5V level shift was the only challenge). Not much interesting going on, really, but I'm very glad it is so straightforward. I can concentrate on the application on the laptop. If I have questions I'll be sure to ask you. Thanks for being so supportive to this technology. I plan on using it in the future for interesting sensors, and IoT in general.
k
