Discussion: Making Your Own Coiled And Retractable Cables
idbruce
Hello Everyone
One of my current projects requires a coiled cable. In the past, I have altered coiled cables, by heating them and bending them to my will. Additionally, I have heated straight cable, which I coiled, to make my own coiled cables, with minimal success.
For my current project, I would like to make my own customized coiled cable, to satisfy my strict requirements, and I am looking to gather specialized information pertaining to this subject, so that it may benefit me and any others that may be interested. As I see it, it should all be a matter of heat and starting with the correct cable, however to do it correctly, torsion may be required, although I am not sure.
As for the cable, I suppose the investigation of various coiled cable companies and the materials they use, would reveal the proper type of cable to begin this process. However, I am certain that not all coiled cables are created equal. I would imagine that the best coiled cables are constructed from continous flex cable, but I could be wrong.
Any input you may have on this subject will be greatly appreciated.
Bruce
Bruce
That might work for some peoples applications, however I must have (2) 18 ga. wires fitting through a 3/16 dia. hole., which is pretty tight. But let's say that diameter was not an issue, fishing the wires through coiled air hose might be quite difficult, although I am not sure. Conduit runs are limited to a maximum of 360 degrees from point to point, due to pulling and fishing issues. There are times when it can be quite difficult to get a nylon or steel fish tape through 360 degrees of bends.
@CuriousOne
I would have never guessed that it was coiled immediately during manufacturing, however I am fairly certain that is can be accomplished post manufacture, as long as the temperature of elasticity is reached, but I am also certain there are other issues at play, such as strand count.
By the Power of Google!
http://www.google.no/search?q=youtube+hows+it+made+coiled+cable&sourceid=ie7&rls=com.microsoft:no:IE-Address&ie=&oe=&gfe_rd=cr&ei=FNz6U4W6GY_K8ge08YHIBQ
The first video from those results was quite impressive and informative, and just along the lines I was thinking. However, the reverse wind.... Who would have thought of that?
From Gadgetman's list of links, this video was very informative (http://www.youtube.com/watch?v=wTmzg6WMnf0). Early this morning, I watched a portion of it again, only this time, I tracked down some vital information. As it pertains to the wire in that video, here is a link to the specifications : http://www.northwire.com/products/nwi-direct/retractile-power-cords/specifications
Northwire (linked to in previous post) lists some of the cables utilized for coil assemblies as SJEOW, with a TPE jacket. So in reality, not only is the jacket TPE, but the conductor insulation is TPE also, or at least it can be, according to SJEOW specification.
TPE is the abbreviation of thermoplastic elastomers.
The following is a quote from Wikipedia - Thermoplastic elastomer (http://en.wikipedia.org/wiki/Thermoplastic_elastomer)
I now believe that it would be easy to form a coil assembly from SJEOW cable which has TPE as insulation for the conductors.
The following is an excerpt taken from the McMaster-Carr catalog which shows the thermal properties and insulation type. They also have other material which might work, but I think this is what I might try. However the diameter is much larger than I can currently accomodate, so I may have to do some alterations or come up with a different cabling method.
The coils are now about 1-1/4" in diameter, but I must say that it works pretty well, and that it retracts back every time. It is not nearly as fine looking as one bought from a manufacturer, but it don't look bad. The main thing is that it works well and that it will do exactly what I want, while looking decent.
I was wondering that myself. I would guess yes.
