AHDL help needed — Parallax Forums
AHDL help needed
nutsonnutson Posts: 242
edited 2014-08-25 04:26 in Propeller 1
I am stuck with AHDL. I want to add three pins to the top level module, and use those in the dig.v module but I keep getting compile errors.
The three pins / signals have been added to the top.tdf file as follows
subdesign top
(	clock_50			: input;		-- clock input
	inp_resn			: input;		-- reset pin
	io		[31..0]	: bidir;		-- i/o pins
	ledg	[7..0]	: output;	-- cog leds
	dbgdata			: output;
	dbgclock		   : input;
	dbgstart		   : input;
and in the dig.v as follows
module				dig
input					nres,			// reset input (active low)
output	 [7:0]	cfg,			// configuration output (set by clkset instruction)
input					clk_cog,		// cog clock input
input		 			clk_pll,		// pll simulator clock input (2x cog clock)
input		[31:0]	pin_in,		// pin state inputs
output	[31:0]	pin_out,		// pin state outputs
output	[31:0]	pin_dir,		// pin direction outputs
input 				dbstart,
input					dbclock,
output				dbdata,
output	 [7:0]	cog_led	);	// led outputs to show which cogs are active
and connected in the top.tdf file with
-- debug pins
	dbgdata			= core.dbdata;
	core.dbclock	= dbgclock;
	core.dbstart	= dbgstart;
Quartus keeps complaining
Error (287071): Symbolic name "dbdata" must be port of megafunction, macrofunction, primitive, or state machine "core"
Error (287071): Symbolic name "dbclock" must be port of megafunction, macrofunction, primitive, or state machine "core"
Error (287071): Symbolic name "dbstart" must be port of megafunction, macrofunction, primitive, or state machine "core"
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 3 errors, 0 warnings
What I am doing wrong??
  • pik33pik33 Posts: 2,416
    edited 2014-08-24 21:42
    .inc files need update too
  • jac_goudsmitjac_goudsmit Posts: 418
    edited 2014-08-24 21:45
    Also you probably need to update the top.qsf file to specify where the new pins are assigned (I think it's possible to do this from inside Quartus too but I forgot how).
    ===Jac
    edited 2014-08-24 22:57
    nutson
    I'm no expert in AHDL, but from my readings about syntax, the problem seems to be at your version of dig.v
    It's a little subtle, but it appears to be about the position of the ");" in between "output [7:0] cog_led" and "// led outputs to show which cogs are active".
    IMHO it should read:
    module                dig
    input                 dbstart,
    input                    dbclock,
    output                dbdata,
    output     [7:0]    cog_led       // led outputs to show which cogs are active
    I've checked at the original 60050,60056-Propeller-1-Design-2014-08-11 and it's written this way there.
    Since I've no means of testing it, I'm letting to you to verify it works.
    Fingers crossed here!
    Yanomani
    nutson wrote: »
    subdesign top
        dbgdata            : output;
        dbgclock           : input;
        dbgstart           : input;
    module                dig
    input                 dbstart,
    input                    dbclock,
    output                dbdata,
    -- debug pins
  • nutsonnutson Posts: 242
    edited 2014-08-25 01:23
    Thanks all for your time and attention. The winner is: pik33. After editing the dig.inc file, and adding the new nets to the dig.v input / output definition, the project compiles fine. An of course in the pinplanner I needed to setup which pins of the FPGA are to be used. Will inform you later what the project is.
  • ozpropdevozpropdev Posts: 2,793
    Use File - Create/Update - Create AHDL Include file for the current file :)
