DTMF decoder IC in smaller than SOIC-8 package?
Hello.
Is there a smaller solution than SOIC-8 LM567, say in SOT-23 package for DTMF decoding?
http://www.ebay.com/itm/DTMF-Tone-Receiver-Decoder-DTMF-SM2-slim-Assembled-and-tested/291204881194?_trksid=p2050601.c100272.m3467&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140813112422%26meid%3D832a58e1f6904a9697002aa82e86f661%26pid%3D100272%26prg%3D20140813112422%26rk%3D1%26rkt%3D4%26sd%3D291204881194%26clkid%3D43051858766694834&_qi=RTM1562569
I want to build a device for my elder parents. Being incorporated into cordless handset, it will hang up the phone, after receiving busy signal for about 20 seconds. Since space is limited, this is why I need smaller chips. I know that prop can do DTMF natively, and there are some PICs with that function. But they need advanced programming, and I'm only BASIC enabled (Z80 ASM too), so....
This doesn't take a large microcontroller to deploy.
The PICAXE has DTMF ablities.
http://www.picaxeforum.co.uk/showthread.php?12417-Picaxe-Dtmf
http://pe1grl.khds.nl/dtmf/dtmf.htm
http://www.futurlec.com/Mini_MT8870.shtml
That's a different matter.
The 8870 only does The DTMF ("touch-tone") signals.
Two tones do not DTMF make.
The busy tone (or busy signal) isn't part of that scheme.
http://en.wikipedia.org/wiki/DTMF
http://en.wikipedia.org/wiki/Precise_Tone_Plan
You might just look for the 620 Hz component if the dial tone in your area conforms to PTP.
The old, familiar busy signal is just the dial tone. The two could be differentiated by detecting several reps.
I beg to differ on one point. Two tones do DTMF make, however I do agree there is more to phone signalling than that. Dial tone, busy signal, coin signals for payphones, and diagnostic signals were around before the advent of DTMF.
"my" busy tone is definetly DTMF, since consists of two tones, it is output by VOIP adapter, Cisco-Linksys PAP-20.
PICaxe might be good, but requires some investment, which is not good
There are extremely tiny microcontrollers by TI that would work well, but you need to program in assembly language to use them. Some 'sweat equity' is required in learning to code the cheapest and tiniest of devices.
It's not, but feel free to get your back up all you like. Neither of those ICs will find a busy signal.
Two tones, as such, simply do not mean that's part of DTMF signaling.
They have to be the specific tones for dialing, not simply two arbitrary simultaneous tones.
I wonder why the F so many people here are so GD sensitive.
Things here get real stupid, real fast.
Have fun!
Warmest Regards,
The Antichrist
http://en.wikipedia.org/wiki/Busy_signal
EDIT: Or maybe it is?:
http://en.wikipedia.org/wiki/Dual-tone_multi-frequency_signaling
In the back of my mind I have been pondering when the busy signal was added to DTMF. I guess it technically never was, but a somewhat similar process for creation and decoding is in play.
@PJ
Calling yourself "The Antichrist" isn't going make conversation any more intelligent. But thanks for catching the oversight.
@all
What I love is that problems like this just teach me more useful details. Live and learn.
Your BS ("participation") always precludes any such possibility.
Talk about "annoying".
Have fun!
Warmest Regards,
The Antichrist
