Logic Analyzer advice — Parallax Forums
TCTC Posts: 1,019
edited 2014-08-25 18:15 in Propeller 1
Hello all,
I have put my oven on hold for a little bit (getting overwhelmed). So for now I am going to see if can get my Data I/O 60 working.
All I have done with it so far, is fixed the fuse I blew, and tested the keypad matrix with a meter. All the buttons act like they should work. But the unit still does not notice the buttons being pressed. So now I am going to see if there is a chip (EPROM, logic gate, etc..) that is not working the way it should. I found code, and a program that turns a prop into a Logic Analyzer. I was thinking of using it to see if things are working the way they should.
My question is..... Does anyone have any advice that could make this process quick and easy? Anything I should do to protect both the prop and the Data I/O? And, What should I look (or look out) for?
Thank you for any advice you give.
TC
PS. I wrote this just before I have to leave to visit family, and I did not want to forget. I will try to respond when I can through out the day.
    edited 2014-08-23 07:29
    TC wrote: »
    There is another prop logic analyzer you might consider. WARNING: May contain FORTH!!! It is in the propforth download archive. You don't have to program in forth, just load it and use it. One three cogs are used depending on sample rate and sample size. The state of all the prop I/O pins is stored as a snapshot in memory. It is then dispalyed on the PC via the terminal program (tera term, etc). I usually use the standard sampling, this stores to unused hub memory.
    The module is in the extensions subdirectory of the archive. I think it "la.f". Load any of the included kernels (usually try the dev kernel first) and load "la.f" and you are good to go. Instructions are in the propforth.htm manual, included in the download.
    If you use the logic analyzer on a separate prop chip, the other chip can run spin etc. Just trigger off whatever pin. If you run the logic analyze on the same prop chip as the program being monitored (in another cog), its easiest if the other cog are running forth programs and not spin. Propforth is not designed to run in the same prop alongside spin code.
  • TCTC Posts: 1,019
    edited 2014-08-23 07:36
    That is a great idea, but I have no idea on how to even start with forth. I don't really want to have to learn something new right now, I just have a lot going on. But I do plan on learning forth later, as well as other languages. Thank you.
    edited 2014-08-23 07:55
    TC wrote: »
    As I said, you don't have to leaarn or use forth to use the logic analyzer. You just download, unzip, load the devkernel.spin like any other spin program, and load the la.f throught the terminal. Ok, you do have to learn how to click n the terminal program icon. The actual paste is the same old copy - paste you are familliar with.
    You should really give it a try, its too easy.
  • TCTC Posts: 1,019
    edited 2014-08-23 10:10
    I think I will. Thank you.
    edited 2014-08-23 10:31
    ViewPort is the premier debugging environment for the Propeller. The tool combines an integrated debugger with powerful graphics that show you what’s going on within the Propeller. Monitor variables over time with the built in oscilloscope or change their value while your Propeller is running. Solve hardware problems with the logic analyzer at sampling rates up to 80Msps. Add intelligence to your programs with the fuzzy logic module or perform simple vision processing.
    http://onerobot.org/products/viewport/
  • jazzedjazzed Posts: 11,803
    edited 2014-08-23 10:35
    TC wrote: »
    Anyone can try.
    It is up to each individual to decide whether or not it is a waste of one's time.
    Most certainly it is easier for forthers, cults, and criminals to take advantage of beginners.
    edited 2014-08-23 10:54
    Braino,
    Jazzed,
    Shame on you. Don't you know Forth is the solution to all problems? It slices, it dices, it shakes, it vacs, it takes you out for a good time on a Friday night, cures your hangover the next morning, it does all your worrying for the future and feeling guilty for your past, and makes every known problem in computer science and electronics trivially easy to solve.
    Sadly it is not for us mere mortals.
    Ah well. We just have to do stuff the hard way.
    edited 2014-08-23 12:08
    My apologies, I mistook the "thank you for any advice you may give" as a solicitation for options. I did not realize that valid replies to open requests would be considered cult or criminal.
    My suggestion is a very specific solution that exactly meets a specific request. While implemented in forth, it does not require the user to learn or program in forth. What the hell else do you want?
    I mean this in the best possible way, but sometimes you guys are just @$$4013$.
  • RickBRickB Posts: 395
    edited 2014-08-23 15:47
    heater
    "It is better to remain silent and be thought a fool, than to open your mouth and remove all doubt"
    Your petty tirades against forth are getting very tiresome.Put a cork in it.
    edited 2014-08-23 17:36
    Thanks prof for your input.
    These days, so often we no longer care what is under the hood. If it works the way we want, and the price is right, then its a good choice.
    How many really know how a PC works these days? We just use it as a black box.
    Until a couple of weeks ago, none of us really knew the P1 guts. It didn't stop us using it, did it? ANd now we can appreciate how it works, and we can even mod it.
    Same goes for profs solution. Use it as a black box. Later, if one wants to, you can delve into forth and modify it - but only if you want to.
    edited 2014-08-23 20:29
    I LOL-ed over this one.
  • DavidZemonDavidZemon Posts: 2,973
    edited 2014-08-24 08:54
    TC,
    If you can get the results you need from a prop, more power to you. At some point, you may find yourself wishing for a real logic analyzer though. I can't give enough praise to Saleae. I have a Logic 8 and it's already saved me countless weeks of debugging. It's infinitely more expensive than free... but if you've found yourself often wishing for a logic analyzer, go for it.
    https://www.saleae.com/
    edited 2014-08-24 09:49
    TC,
    Or buy it direct from Parallax:
    http://www.parallax.com/product/32314
  • tomcrawfordtomcrawford Posts: 1,129
    edited 2014-08-24 10:15
    TC,
    I've said it before.... I can remember when a logic analyzer with the capability of a Saleae would have cost a year's wages. Mine has made the difference between a successful project and abject failure.
    edited 2014-08-24 10:19
    Publison wrote: »
    Indeed.
    While it won't capture 32 channels of 100MHz samples like the software linked in the original post, it does have device protocol templates for I2C, SPI, UART, etc... that are very useful. It's also a neatly enclosed package that you can stuff in your pocket.
    It is very easy to use. Extra loading not required.
    edited 2014-08-24 10:37
    Didn't know parallax was selling saleae's! Cool :D
    jazzed wrote: »
    This doesn't sound plausible. I could see how up to 32 channels can be detected with 100 MHz precision for a single edge - but after each edge there would be a large delay before the next edge can be detected. Utilizing all 8 cogs, we can do a bit better but still not 32 channels @ 100 MHz. Am I missing something or are the specs a bit misleading?
    edited 2014-08-24 11:08
    Many impossible or implausible things have been done with propeller ;-)
    With a 6.25MHz crystal 5 cogs working together (1 to manage 4 others running PASM) can capture about 450 samples at 100MHz into HUB RAM, then transmit back to the user's application. It is not plausible without PASM.
    edited 2014-08-24 11:17
    Okay - that makes more sense. Read all 32 pins every four clock clock cycles on each of 4 cogs while buffering in COG RAM. You'd run out of COG RAM in about 450 samples. That results in fantastic bursts of 100 Msps but then a very long window with no reads while the buffers are emptied.
    edited 2014-08-24 11:38
    You seen to be leaning towards the dedicated hardware options, but for those following along:
    With software only, on a stock (5Mhz crystal) pop board 4 cogs can capture every transition on every clock, and can run until cog memory is filled. A fifth cog is consumed for the user interface. This method only captures events for a brief period until the meory is filled. But it you know when to trigger, it can usually get the job done. It can be handy (for those of us that can't justify a logic analyzer purchase) to turn any quickstart in to a logic analyzer with no additional wires (if on the same chip) or just a few wires (if on a separate chip).
    edited 2014-08-24 11:40
    Right. I never said anything about approximating an Oscope ;-)
    The delay could be minimized however by using another cog. That is, change the role of the current main program from serial IO + capture management. A new cog would simply interact with the PC program which would be responsible for accepting commands, controlling the capture manager, and sending back data. The capture manager cog could then be free to point to a queue of capture buffers and do capture as required when the buffer queues are available. With more cogs, the whole system could be duplicated for better capture with smaller gap ping-ponging the cog set being used. A fully continuous stream would be much harder of course if not impossible since the capture instructions have to be rewritten every time for each capture.
    The new scheme would require recoding some things, but the basic PASM would be the same and looks like this.
    DataLoggerX4_050_jsd2.spin
    Copyright (c) 2009 Steve Denson
    See end of file for terms of use.
    This program builds on work done in or by the following:
      Data Logger Demo v0.050
      Author: Ray Rodrick
      Copyright (c) 2008 Ray Rodrick
      Ray's Acknowledgement: to Paul Baker's Logic Analyzer (dscope.spin) for the
      inspiration and naming conventions.
    CON
      _CLKMODE = XTAL1 + PLL16X     'Set to ext low-speed xtal, 16x PLL
      _XINFREQ = 5_000_000          'Xtal 5MHz
      BUFSZ = 512*4
    VAR
    '                     '\\       THE FOLLOWING MUST BE KEPT TOGETHER & IN THIS ORDER
      long  trigmask      '||       trigger pin mask (trigger immediately if =0)
      long  trigarm       '||       trigger pin arm state
      long  trigstate     '||       trigger pin capture state
      long  speriod       '||       sample period
      long  delay         '||       delay from trigger event to snap
      long  slot          '||       number of cpu slots
      long  syn           '||       startup sync cogs word
      long  bufsize[BUFNO]'||       dataset buffer size (set by cog when done)
      long  buffer[BUFSZ] '||       dataset buffer (max 512*slot, but not all used)
    '                     '//       Note: This is not the same as dscope.spin !!!
    pub main
      repeat
        trigmask~ ' test only
        trigstate := trigstate & trigmask                   'enforce we don't look for masked pins (if error above 2 lines!)
        speriod   := 1
        slot := 1
        longfill(@buffer, 0, BUFSZ)                         'clear the buffer
        syn~~                                               'sync wait command
        start(@trigmask,0)
        syn~                                                'sync go ... get started
        repeat until bufsize
      repeat
    CON
      BUFNO = 4
    VAR
      long  cog[BUFNO]
    PUB Start(bufptr,num)
    '' Start DataLogger - starts a cog
    '' returns 0 if no Cog available or cog "id"
    ''  bufptr = pointer to DL parameters
    ''  num is cog number
      result := cog[num] := cognew(@entry, bufptr) + 1
    PUB stop(num)
    '' Stop DataLogger - frees a cog
    '' normally stops after sample completed and copied to buffer
      if cog[num]
        cogstop(cog[num]~ - 1)
    DAT
    '_______________________________________________________________________________
    entry          org 0
                   jmp       #init                          'go and setup the variables
    bufferfull
       buffer slots
       0, 0, 0, 0   1 cog           add hptr, #4
       0, 0, 0, 0   2 cogs          add hptr, #8
       0, 0, 0, 0   3 cogs          add hptr, #12
       0, 0, 0, 0   4 cogs          add hptr, #16
      mov          i,CogBufSz               'get actual buffer size
    writeloop
      wrlong       bufstart,hptr            'write long to main memory (buffer)
      add          writeloop,d_inc          'increment buffer pointer
      add          hptr,#16                 'increment hub pointer by 4 long ... always use 4 cogs
      djnz         i,#writeloop             'repeat for entire buffer
      wrlong       CogBufSz,bsize           'store size of dataset in bufsize (signals buffer written)
      cogid        i                        'get this Cog ID
      cogstop      i                        'stop this Cog
    prototype1   mov  bufstart-0,ina        'prototype "read all 32 pins" ... change to cnt for clkfreq sample proof
    setuploop
      mov          bufstart-0,prototype1    'save the modified prototype instr
      add          setuploop,d_inc          'increment destination in instruction above
      add          prototype1,d_inc         'increment destination in prototype instruction
      djnz         i,#setuploop
      cmp          del, #0 wz
      if_nz mov    jmpNoDelay, #0           'set nop ... no jump if delay
      if_nz mov    trig, #0                 'set nop ... no 2nd wait trigger if no delay
      tjz          tmask,#nowait            'don't wait if =0
      cmp          tarm,  tmask  wz
      if_nz        waitpeq tarm,tmask       'wait for arm if arm != mask
    jmpNoDelay
      jmp          #noDelay                 'will be nop if delay is used
      waitpeq      tstate,tmask             'wait for start condition
      add          del, #$4
      add          del, cnt
      waitcnt      del, del                 'wait for delay*12.5ns to pass
    noDelay
    trig   waitpeq tstate,tmask    'wait for start condition
    nowait
    bufstart    'long 0 '\\ instr overwritten by the data
    init
      mov          hptr,par     'save hub memory pointer (initially set to trigmask)
      rdlong       tmask,hptr   'get triggermask parameter
      add          hptr,#4      'increment hub memory pointer     to trigarm
      rdlong       tarm,hptr    'get triggerarm parameter
      add          hptr,#4      'increment hub memory pointer     to trigstate
      rdlong       tstate,hptr  'get triggerstate parameter
      add          hptr,#4      'increment hub memory pointer     to period
      rdlong       sper,hptr    'get period parameter
      add          hptr,#4      'increment hub memory pointer     to delay
      rdlong       del,hptr     'get delay parameter
      add          hptr,#4      'increment hub memory pointer     to slt
      rdlong       slt,hptr     'get slt parameter
      add          hptr,#4      'increment hub memory pointer     to sync
      mov          sync,hptr    'save pointer to bufsize
      add          hptr,#4      'increment hub memory pointer     to buffer size
      mov          bsize,hptr   'save pointer to bufsize
      mov          i,#BUFNO
    incbsz
      add          hptr,#4      'increment hub memory pointer     to buffer and stay until hub update
      djnz         i, #incbsz
      cogid        i
      sub          i, slt
      mov          slt, i                   'get our slot number
      shl          i, #2
      add          hptr,i                   'get my hub write slot
      add          bsize,i                  'assign update slots
      add          bsize,slt
    syncup         ' wait for user to say go
      rdlong       i,sync wz
      if_nz jmp    #syncup
      mov          i, cnt                   'assign sample position
      add          i, #$1ff                 'add waitcnt margin
      andn         i, #$7f                  'start with 0 every time
      add          i, slt                   'add our sample position slot number
      waitcnt      i, #0 nr                 'wait for our count for sample
      movd         d_inc,#1                 'set d_inc to $0000_0200 (nop = $0)
      jmp          #setuploop               'do setup
    bufpad         long 0 [418]
    bufend         jmp  #bufferfull         'prototype "jump to bufferfull"
    hptr           nop 'save hub memory pointer (initially set to trigmask)
    tmask          nop 'get triggermask parameter
    tarm           nop 'get triggerarm parameter
    tstate         nop 'get triggerstate parameter
    sper           nop 'get period parameter
    del            nop 'get delay parameter
    slt            nop 'get slot parameter
    sync           nop 'startup sync word
    bsize          nop 'save pointer to bufsize
    d_inc          nop 'must be nop   'value to increment destination reg by 1 (will be $0000_0200)
    i              nop
    CogBufSz       long     (@bufend-@bufstart)>>2
                   fit $1f0
     TERMS OF USE MIT License
     Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation
     files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,
     modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software
     is furnished to do so, subject to the following conditions
     The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE
     WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
     COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
     ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    This is just one of several Spin files in the Propalyzer package.
    edited 2014-08-24 13:13
    Very cool stuff :)
    edited 2014-08-24 13:19
    jazzed wrote: »
    Indeed.
    I'll add my second. It's one of the more indispensable devices on my bench. My scope can do 2ch decodes too but is far more cumbersome to setup. Saleae has made a great product at a very affordable price. Bonus for me is that it works on Mac natively.
  • TCTC Posts: 1,019
    edited 2014-08-25 04:57
    Thank you everyone for the input, and the bashing on forth:blank: (that was not the intent of the posting).
    I knew there was something out there for the prop. But I could not remember what it was. I did a google search on "Propeller Logic Analyzer" and I could not find ViewPort.
    Cluso99 wrote: »
    I agree Cluso, Thank you for your input braino. I have been intrigued about forth, but could not spent the time to understand it.
    I want to know what is going on under the hood of a lot of things. That is why I like the prop as a Logic Analyzer. With having up to 32 channels (28 usable), I can hook up all the address, control, and data pins to see what is going on.
    TC,
    At this point, this is the first time I have needed a logic analyzer. If I need better options, stability, etc.. then I will get a mass produced device like the Saleae. But for know, I don't think I need something that powerful.
    Everyone has been giving great advice on what I could use to monitor the prop. But no one has provided any hardware advice. I know the prop can tolerate 5V inputs. But should I add a resistor to each pin? Maybe a 150 ohm resistor? I do not want to take the chance of frying my QuickStart board, or my rare Data I/O 60.
    Thank you
    TC
    edited 2014-08-25 05:57
    The propeller can not tolerate 5V inputs without resistors. I believe 3.3K is the recommendation to keep the current inside what the protection diodes can handle continuous (appox 500uA).
  • TCTC Posts: 1,019
    edited 2014-08-25 10:50
    photomankc wrote: »
    I apologize, it was early and my coffee did not kick in. I was thinking the prop was outputting, not inputting when I wrote that.
    Thank you for setting me straight.
    TC wrote: »
    Ahh, I see. Yeah, I like to add maybe 160 ohms or so between GPIO connections on differing controllers connected together. Cheap protection from a programming boo-boo and a dead short when two outputs meet and disagree.
