AUGDS instruction for P1V — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2014-09-04 14:53 in Propeller 1
I am going to implement this instruction in the P1V. It will be a bit different to the P2.
AUGDS #/D,#S WC,WZ
D & S will both be either immediate 9 bit values or both register addresses. A mix will not be permitted.
This will preset bits [17:9] for D & S in the following instruction only. Of course its usage depends on the insttruction.
WC & WZ are potential later instruction options and do not change Z or C flags.
More info to come later. gtg
    edited 2014-08-23 18:14
    Working within the constraints of the existing P1 code...
    The AUGDS instruction would set two internal registers...
    for immediate mode...
    augd[31:0] <= 14'b0, i[17:9], 9'b0 // set to #D
    augs[31:0] <= 14'b0, I[8:0], 9'b0 // set to #S
    else...
    augd[31:0] <= d[31:0] // set to value in register D
    augs[31:0] <= s[31:0] // set to value in register S
    The following instruction will...
    ADD augd[31:0] and d[31:0] to give a new resulting d[31:0] value
    ADD augs[31:0] and s[31:0] to give a new resulting s[31:0] value
    The instruction will then use these resultant d & s values in the execution of the instruction.
    edited 2014-09-03 17:12
    Finally getting somewhere with this...
    I had a lot of problems finding a way to verify this was working. Many bugs just getting to see that what I had done was indeed functioning, and where I had a problem when it didn't work as I expected.
    Looking forward to posting progress shortly ;)
  • ozpropdevozpropdev Posts: 2,793
    edited 2014-09-03 18:38
    Good one Ray. :)
    Looking forward to seeing your work.
    I'm currently working on a variant that supports full 10 bit addressing of D & S (1024 longs of cogram).
    Half way there, so far so good. have to rewrite booter and spin interpreter to suit changes. Yikes!
    Interesting challenge but learning as I go....
    Cheers
    Brian
    edited 2014-09-03 20:38
    Brian, sounds interesting!
    AUGSD info...
    iiiiii zcri cccc dest..... source
    000110_0001_1111_ddddddddd_sssssssss
    Currently, when executed...
    1. The values of "ddddddddd" and "sssssssss" are saved in registers for the next instruction only.
    2. If only D or S is required, then the other should be 0.
    3. When the next instruction is fetched, the "sssssssss" value is extended by the aug S<<9 to make an 18 bit S value.
    4. And "ddddddddd" is extended by the aug D<<9 to make an 18 bit D value.
    5. This means that the S value of the instruction following the AUGDS instruction can now have an 18 bit immediate S value.
    6. If Cog RAM is >2KB, then the extended S & D addresses will be truncated to the address bits required for the cog. This means all usual instructions such as MOV, ADD, etc can access the additional cog RAM although MOVS/MOVD/MOVI (and perhaps others) may have side effects.
    7. This will permit the JMPRET (JMP/CALL/RET) instruction to be preceeded by an AUGDS instruction to extend its range within the cog RAM.
    8. AUGDS only works for immediate mode (ie the D and S values are effectively both immediate values and are not used to fetch values in registers)
    9. Currently AUGDS does not work conditionally (ie cccc=1111=always and is not tested).
    I intend to add a JMPRETX (JMPX/CALLX/RETX) instruction to support hubexec.
    For now, I need to expand the pc and cog ram to verify the correct working of AUGDS and other instructions.I have verified its basic functionality
    I am going to test a cog with 8KB RAM :)
    edited 2014-09-04 08:18
    I am adding a variant AUGS #23bits which will extend the following instructions s value to 32 bits.
  • pik33pik33 Posts: 2,417
    edited 2014-09-04 10:57
    This can enable more address space... but I am still dreaming of direct execution from inb. The first attempts to do this failed, but I will try again :) I want to stop the program counter if it is equal inb. Then all instructions will be fetched and executed from it. Additional program counter will output its data to dirb and address external RAM (this is possible with my extended port B configuration - look my VGA project).
    If this will work we will have a (near) full backward compatible Propeller cog. To enter extended mode, jmp #inb. To exit extended mode, jmp outside inb.
    The first try caused the Propeller non programmable, don't know why. So, in the next try I will modify only Cog 7 and check what is wrong.
    pik33,
    Interesting concept. I will keep watch to see how your version goes.
