I need to mount my Board of Education USB (Basic Stamp 2) board into an electrical enclosure box. Does anyone have the hole drilling guide for the board?
It seems we don't print the mechanical details of these boards, however we're nothing if not consistent when it comes to using the same footprint. For this reason you can use the following document to get the board size and hole placement information. Please let us know if this helps.
Most of our boards have the same footprint and hole spacing. That is why it is so easy for me to make them portable and stack them on the Li-Ion Power Pack, which also has the same size and hole spacing.
Super Carrier Board, all versions of the Boards of Education, Propeller Proto Board, Propeller Project Board, Propeller Activity Board. :thumb:
There is one hole that is not accounted for on the Board of Education and that hole isn't used anymore. It was for the standoff on AppMod boards plugged into the AppMod socket.
Actually that hole was pretty handy as the 5.5 X 2.1mm barrel pin that I intend to use to connect the power supply to the board blocks one of the holes
A bit of a tangent here Chris. How many different AppMod boards were there? Just curious...
I have the Breadboard and LCD. Handy little items.
I linked what I could find for reference. I have owned most all of these and given them away through Savage///Circuits giveaways of through The Fellowship Of The Travelling Parts Box.
http://www.parallax.com/sites/default/files/downloads/32212-Propeller-ProtoBoard-Documentation-v1.3.pdf
Amanda
Just off the top of my head there were (more that I can't remember):
- Breadboard AppMod
- Proto Board AppMod
- LCD Terminal AppMod
- LED Terminal AppMod
- TCS230 Color Sensor AppMod (used for the M&M Sorter)
- RS232 AppMod
- Cermetek Modem AppMod
- XBee AppMod
- CMUCam for Boe-Bot AppMod
- Motor Driver AppMod (L293?)
- Audio Amplifier AppMod
- Sound Module AppMod
- Speech Recogition/Sound AppMod (I think this one was the size of the BoE)
There were also a couple of accessories designed to connect to the AppMod connect even though they weren't AppMod boards themselves:- EB500 Bluetooth Module
- Easy Bluetooth
- Digital I/O Board Kit (cable not included)
- Say-It Module?
