Access to cnt by mov vs. waitcnt
ksltd
I'm working on reducing jitter to zero in a fairly complex system. This requires some detailed understanding of the instruction pipeline with respect to the cnt register in both the mov instruction and the waitcnt instruction.
The waitcnt instruction has a minimum execution time of 6 clocks and a move from cnt has a fixed execution of 4 clocks. But there's no explanation of how the evaluation of cnt is done in either instruction, so its not possible to know how to get to-the-clock timing.
Said differently, consider the following three instructions:
mov A,cnt
add A,#x
waitcnt A,#0
What value of x is used so that the waitcnt instruction's execution takes the minimum 6 clocks? And, equally importantly, does that value cause the instruction to take exactly 6 clocks every time?
Thanks.
mov A,cnt
add A,#x
waitcnt A,#0
Thanks.
Did you make some typos in the code snippets, above? cnt is read-only, so I have a hard time believing they're correct. What's the scoop?
Also, did you derive the "9" by trial and measurement or do you have some empirical knowledge?
Pure blackbox observation. IOW the timing was the easy part, figuring out the sample points for live registers and wait* took a bit more but wasn't rocket science. It's outdated (as in incomplete) by now but most of the stuff is listed here.
