Pass value in phsa?
lardom
How do you pass the value of phsa to another method so that the counter is not restarted every time you call for the phsa value?
I found a solution; Copy phsa to a global variable. I had been using return which always displayed '166' which appeared to be execution overhead.The result operator displayed what I was looking for.
PUB Main
'displays elapsed clocks when pin is high
ctra[30..26] := %11010 'ctrb module to APIN=1
ctra[8..0] := 5 ' declare pin
' dira[5]~ ' input to sense pulses
frqa := 1
ifnot ina[5]
phsa := 0
return phsa
I call Start then Main thereafter to get the value. Do I need a conditional statement in front of "ctra[30..26] := %11010". There must be a better way.I found a solution; Copy phsa to a global variable. I had been using return which always displayed '166' which appeared to be execution overhead.The result operator displayed what I was looking for.
PUB run : result result := X
