Additional counters per cog - any showstoppers? — Parallax Forums
pmrobertpmrobert Posts: 678
edited 2014-08-17 09:12 in Propeller 1
I'll be spending some quality time with the codebase tomorrow seeing if adding additional counters to a cog is feasible. Does anyone have any preliminary advice and/or pointers?
-Mike
  • roglohrogloh Posts: 6,312
    edited 2014-08-16 19:37
    Do you plan to sacrifice some COG memory below $1F0 for your new counter registers? If not, how else will you address them? If so, some existing objects needing all $1F0 registers may break, or start potentially driving new counter outputs. If you only run your own COG PASM code exclusively that may not be an issue.
    edited 2014-08-16 21:08
    You could map as many register banks to 1F0-1FF (or a subset thereof) as you want by writing a pointer to the shadow register of one of the read-only registers, such as cnt.
  • TubularTubular Posts: 4,771
    edited 2014-08-17 03:04
    Very good idea, Phil. That would really open things up.
  • pmrobertpmrobert Posts: 678
    edited 2014-08-17 06:12
    That sounds like a great approach and it sounds like it doesn't break the HLLs.
  • LawsonLawson Posts: 870
    edited 2014-08-17 06:26
    Uh, doesn't the Spin interpreter use the CNT shadow register as a loop counter? Sounds like this would break counter support in spin at least. (though the INA or INB shadow register may be free)
    Marty
  • abecedarianabecedarian Posts: 312
    Lawson wrote: »
    Marty
    I don't believe Spin is being used here so this shouldn't be a issue.
    pmrobert can clarify.
