How to communicate with unknown I2C device? — Parallax Forums
sccoupesccoupe Posts: 118
edited 2014-08-16 17:56 in Propeller 1
I am trying to figure out how to communicate via I2C with a video converter. This converter resets all of the screen position settings each time its powered down, seemingly by design. The datasheet shows that it has an I2C bus that isn't attached to anything in the box that I'm working on. The idea is to connect a prop to the bus to see if I can read all of the addresses. Then make one adjustment, say move the screen to the left one pixel using the menu buttons on the box, and then read all of the addresses again to see which one changed. This should allow me to then save just that value in the prop and write it back on power up. Pin 56 is pulled high so I guess 0x6A and 0x6B should be used for the slave address. What i'm not sure about is what should be started with as clock speed and what are the best assumptions for addresses? Just start at address 0x00 and go up from there? What is the best I2C object for this task? This would seem pretty easy i guess if it were just a known SD Card or something, but is perhaps tricky given an unknown device. Is any of this even possible without any more information on the protocol or a lost cause without the proper documentation? Thoughts? Ideas?
uP Serial Bus Interface
SCL 59 I IIC bus clocking.
SDA 60 IO IIC bus address/data bus.
ADDR_SEL_FREEZE 56 I Slave address selection.
ADDR_SEL=1: 0x6A for write, 0x6B for read.
ADDR_SEL=0: 0x4A for write, 0x4B for read.
Freeze when hardware mode (falling edge triggerand pull-up externally)
Regards.
  • SRLMSRLM Posts: 5,045
    edited 2014-08-13 06:35
    I2C doesn't have a set clock speed but is whatever SCL switches at. And based on the block that you posted you already know the bus address. I guess you're asking how to figure out the register addresses?
    It sounds like you want to listen in on the I2C bus while you induce commands on another bus. This won't do anything: you won't hear anything on the I2C bus.
    Why not look up the video converter datasheet?
  • sccoupesccoupe Posts: 118
    edited 2014-08-13 06:46
    SRLM wrote: »
    Yes, the slave address seems to be 6A and 6B which fits a standard 7 bit address. There is currently no I2C traffic because there is only the video converter at the moment with nothing hooked up the the I2C pins. I want to attach a master (prop) and start talking to the converter to figure out what the register addresses are. I have the data sheet, but it is limited. The only mention of I2C is what you see above. The company that manufactures the chip and the company that makes the device are in China and have been contacted multiple times via email with no response.
    edited 2014-08-13 07:26
    Do you have a link to this video converter?
    Often a register will have multiple bits assigned to some function with other bits assigned to a different function. So you not only need to figure out what the various registers do, you need to figure out what each bit within the register does. IMO, this video converter would have to be capable of some amazing things in order to make it worth your time to figure this out from scratch.
    edited 2014-08-13 07:38
    Duane Degn wrote: »
    Here is the link to the conveter box that is sold everywhere for as little as 10 bucks.
    http://www.lenkeng.net/YPbPrzhuanVGA/lenkeng67.html
    Here is the link to the datasheet for the converter chip used in this device.
    http://wenku.baidu.com/view/88627b87bceb19e8b8f6bab0.html
    Its not that it does anything spectacular. Its that it does everything that I need it to do EXCEPT save the screen adjustments on shutdown and does it real cheap. Its possible that I dont need to know what each bit does, just what registers change when I move the screen left or right for instance. Those are the registers that I need to poll and save for re-writing at boot up. This shouldnt bee too difficult unless these registers are changing constantly during normal operation. So in theory, take a snapshot of all of the registers that will answer a read call, move the screen to the left, take another snapshot to see which register changed. Now I would know that that register stores left to right screen position. Now do it again for up and down, then again for stretch vertical, and once again for stretch horizontal and I'm all done......In theory. Is this a good high level theory or are there wrenches waiting to be thrown into the gears?
    edited 2014-08-13 07:52
    sccoupe wrote: »
    I understand better what you want to do. Thanks.
    So do you make these screen adjustments with the buttons on the front of the device? What about simulating button presses by having the Propeller trip relays which are connected internally to the buttons. Have the Prop remember what settings you want and have it automatically "press the buttons" needed to get these settings.
    A better idea would be to snoop on the I2C traffic between the converter box and I2C device it uses as you adjust the screen. You could then have the Propeller send these same I2C commands to make the desired adjustments.
    edited 2014-08-13 08:13
    Yes, adjustments are made via button pressed. Each button has its own pin, directly to the controller. It would be slow I think to record and remember all of the button presses.
    Correct, the better idea would be to use I2C. However, there is no snooping to do, because the I2C pins are not connected to anything in this box. Its just a feature on the chip that isnt utilized by this particular product. So, I need to setup a master I2C device to connect to these unused I2C pins on the chip and read/write these unknown registers as needed.
  • ChrisGaddChrisGadd Posts: 311
    edited 2014-08-13 08:47
    Sounds like a reasonable plan of attack. Bundled inside this archive is a poller object that'll tell you the 7-bit device address of everything on the bus. I'd connect your converter to a couple unused pins so it's the only thing on the bus, put pullups on the SDA and SCL lines, and run the poller to see what's there. Then use the I2C object to read as many bytes as you want to examine. Something along the lines of:
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      SCL_pin = 0
      SDA_pin = 1
    VAR
      byte  buffer[512]
    OBJ
      I2C : "I2C Spin Driver v1.2"
      FDS : "FullDuplexSerial"
    PUB Main | index
      FDS.start(31,30,0,115200)
      I2C.start(SCL_pin,SDA_pin)
      if \I2C.read_page({device_ID},0,@buffer,512)  ' read 512 bytes from device into buffer, starting at register 0
        FDS.Tx($00)                                 ' display the register contents in an easier-to-read format
        index := 0
        repeat 512 / 16
          FDS.Hex(Index,4)
          FDS.Tx(" ")
          FDS.Tx(" ")
          repeat 16
            FDS.Hex(buffer[Index++],2)
            FDS.Tx(" ")
          FDS.Tx($0D)
      else
        FDS.Str(string("no response"))
    It's essentially the same routine I used for my EEPROM demo, you probably (hopefully) won't have too many registers to compare. And hopefully it follows all of the standard conventions for address lengths and auto-incrementing registers.
    edited 2014-08-13 08:52
    ChrisGadd wrote: »
    Great idea.
    If the register content is examined before the screen settings are changed, and after the changes have been made, then this information could be used to set the registers to the desired settings in the future.
    edited 2014-08-13 09:12
    Thanks once again Cris. I'll give this a go tonight and see what happens. Since the datasheet shows the address, I shouldnt need to poll, but will keep this handy if things dont work out. Using standard conventions is a big question I had in mind as well. Not knowing if everything works the same on all I2C devices as far as memory locations and such. It will be interesting to see what comes back if location 0x00 doesnt exist for instance. Does it just not respond or just send 0? Does auto incrementing work on a non-EEPROM type device and is it standard to do so? Will it respond to a full page request?
    Another thought I'm having is that there is an xreset pin that sets all register values to default according to the data sheet. This pin is connected to a transistor presumably for switching. Perhaps the chip is actually saving the changes but being reset on powerup by design to auto detect resolution or something. Cutting this trace should answer this and maybe save some this work, but at this point I2C investigation needs to be done just because. :)
    edited 2014-08-13 10:04
    Those device addresses in your top post are eight-bit IDs that the manufacturer specified as separate read and write addresses. I don't consider the read/write bit to be part of the device address--even if it is sent in the same byte--and therefore my drivers only expect 7 bits.
    ADDR_SEL=1: 0x6A for write, 0x6B for read. Becomes device ID $35
    ADDR_SEL=0: 0x4A for write, 0x4B for read. Becomes device ID $25
    edited 2014-08-13 15:49
    sccoupe wrote: »
    Regards.
    Obviously if you could interactively talk with the chip it would so very easy, you could examine contents, write contents, write one-liners etc. This is what I do all the time with Tachyon Forth and then I build named methods such as CHAN for instance so that if I can just type "3 CHAN" to switch the channel without having to worry any further. Tachyon already has all the utilities built in to the scan the bus and dump contents etc.
  • jmgjmg Posts: 15,198
    edited 2014-08-13 16:01
    sccoupe wrote: »
    Are you sure the i2c can reflect, and set, the operations, that the buttons control ?
    If you really want to use i2c, can you find a variant product that does connect the i2c, so you can at least get some working traffic to decode ?
    Not many ASICS have power off storage inbuilt, as that costs a lot more to fab.
    If you just want to emulate a config setup, it may be smarter to simply record/playback on the buttons.
    Experiment with the delay needed for first press after POR and at what rate you can 'press' on playback
  • abecedarianabecedarian Posts: 312
    edited 2014-08-13 18:57
    Another thing to consider is would it be simple enough to add I2C EEPROM to the chip?
    I mean, does it use the I2C bus to receive commands from an MCU, or simply to store configuration data off-chip, to be read back in on startup?
    Some of these devices don't truly power down, but rather enter a low-power standby mode- might be another consideration.
    edited 2014-08-14 06:06
    Ok, it was a real pain to get wires soldered to the pins of a TQFP-128 but its done. I've never has to solder a single wire strand from a 22 gauge wire before. Hopefully nothing got too hot and the connections are good. Now on to attempt communications with it EXCEPT naturally OBEX is down so I don't have an I2C object to test with.....:/
    edited 2014-08-14 06:15
    sccoupe wrote: »
    Just grab one of the Tachyon binaries which also has the word .I2CBUS in there which will list out devices and their basic contents. Connect serial terminal at 230400 baud.
    .I2CBUS
    Fast Device at 00A0 00 00 00 00 00 00 00 00
    Fast Device at 00A2 52 4D 82 C4 01 07 43 4F
    Fast Device at 00A6 00 3B 58 08 6F 4E 10 00 ok
    edited 2014-08-14 07:00
    .I2CBUS
    Thanks Peter. This was up and working pretty quickly and easily. It seems that the wiring connections may be good. Perhaps you can take a look at the results. The first .I2CBUS was run without anything hooked up. Presumably 0xA0 is the EEPROM on the Prop board. The second and third .I2CBUS runs were with the video chip hooked up. It seems like a lot of noise or something causing all of this or is this a normal thing? A0 is not in either of the other two calls...
      Propeller .:.:--TACHYON--:.:. Forth V23140619.0000
    [?25l
    NAMES:  $5C36...7442 for 6156 (3719 bytes added)
    CODE:   $0000...34F9 for 7405 (7289 bytes added)
    CALLS:  0455 vectors free
    RAM:    10045 bytes free
    MODULES LOADED:
    1880: EXTEND.fth          Primary extensions to TACHYON kernel - 140703-14OO
    BOOT: EXTEND.boot
    ..II22CCBBUUSS
    Fast Device at 00A0  36 10 00 B0 7E B8 7E 84  ok
    ..II22CCBBUUSS
    Slow Device at 000C  FF FF FF FF FF FF FF FF
    Fast Device at 00CE  FF FF FF FF FF FF FF FF  ok
    ..II22CCBBUUSS
    Fast Device at 0000  FF 00 06 00 00 00 00 00
    Fast Device at 0002  00 00 00 00 00 00 00 00
    Fast Device at 0004  00 00 00 00 00 00 00 00
    Fast Device at 0006  00 00 00 00 00 00 00 00
    Fast Device at 0008  00 00 00 00 00 00 00 00
    Fast Device at 000A  00 00 00 00 00 00 00 00
    Fast Device at 000C  FF 00 00 00 00 00 00 00
    Slow Device at 000E  00 00 00 00 00 00 00 00
    Fast Device at 0010  00 00 00 00 00 00 00 00
    Fast Device at 0012  00 00 00 00 00 00 00 00
    Fast Device at 0014  00 00 00 00 00 00 00 00
    Fast Device at 0016  00 00 00 00 00 00 00 00
    Fast Device at 0018  00 00 00 00 00 00 00 00
    Fast Device at 001A  00 00 00 00 00 00 00 00
    Fast Device at 001C  00 00 00 00 00 00 00 00
    Fast Device at 001E  00 00 00 00 00 00 00 FF
    Fast Device at 0020  00 00 00 00 00 00 00 00
    Fast Device at 0022  3F FF FF 00 00 00 00 00
    Slow Device at 0024  FF FF FF FF FF FF FF FF
    Fast Device at 0026  FF FF 00 00 00 00 00 00
    Fast Device at 002A  1F 00 00 00 00 00 00 00
    Fast Device at 002C  FF FF 00 00 00 00 00 00
    Fast Device at 002E  00 00 00 00 00 00 00 00
    Fast Device at 0030  00 00 00 00 00 00 00 00
    Fast Device at 0032  00 00 00 00 00 00 00 00
    Fast Device at 0034  00 00 00 00 00 00 00 00
    Fast Device at 0036  00 00 00 FF FF FF FF FF
    Fast Device at 003A  FF FF FF FF FF FF FF FF
    Fast Device at 0042  FF 1F FF FF FF FF FF FF
    Fast Device at 0044  FF FF FF FF FF FF FF FF
    Fast Device at 0046  00 FF FF FF FF 00 FF FF
    Fast Device at 004A  00 00 00 00 07 FF E0 FF
    Fast Device at 004C  00 00 00 00 00 00 00 00
    Fast Device at 004E  FF FF FF FF FF FF FF 7F
    Slow Device at 0050  00 00 00 00 00 00 00 00
    Fast Device at 0052  00 00 00 00 00 00 00 00
    Fast Device at 0054  00 00 00 00 00 00 00 00
    Fast Device at 0056  FF FF FF FF FF FF FF FF
    Slow Device at 00E4  FF FF FF FF FF FF FF FF
    Slow Device at 00E6  FF FF FF FF FF FF FF 7F
    Slow Device at 00EA  FF FF FF FF FF FF 00 FF
    Fast Device at 00FE  FF FF FF FF FF FF FF FF  ok
    edited 2014-08-14 07:44
    sccoupe wrote: »
    Probably be a bit easier to read if you turned off echo and extra line feed or if you can't then just use TeraTerm. Anyway, it looks like there is activity on those lines I guess. You could try pasting in this next line and then invoking it by name "MON" which will simply spit out a digit representing the I2C lines, 3 = idle, 2 = clock low data high, 1 = clock high data low, 0 = clock low data low.
    pub MON BEGIN CR #64 FOR P@ #28 SHR 3 AND . NEXT ESC? UNTIL ;
    You can terminate the monitoring by hitting the escape key.
    edited 2014-08-14 08:06
    OK, linefeed and echo off. MON spits out all 3's. Something else to note, I have to disconnect the video chip for the prop to boot, so the bus is not working correctly, i guess, when the video chip is hooked up. Even with just the clock pin (SCL 59 IIC bus clocking) hooked up to pin 28 on the prop, it will not boot. Tried swapping SDL and SCA as well.
    edited 2014-08-14 08:26
    Here is the output from Chis' poller. Way too much info to be valid. Pins 8 and 9 used on the prop with nothing else but the video chip attached. SCL (pin 8) pulled to 3.3v with a 22k resistor and SDA (pin 9) pulled to 3.3v with a 33k resistor.
    No pullup detected on SDA
    Polling I2C bus for devices
    7-bit ID        Device type - not all inclusive
    0000000         unknown
    0000001         unknown
    0000010         unknown
    0000011         unknown
    0000100         unknown
    0000101         unknown
    0000110         unknown
    0000111         unknown
    0001000         unknown
    0001001         unknown
    0001010         unknown
    0001011         unknown
    0001100         AK8975C magnetometer
    0001101         unknown
    0001110         unknown
    0001111         unknown
    0010000         unknown
    0010001         unknown
    0010010         unknown
    0010011         unknown
    0010100         unknown
    0010101         unknown
    0010110         unknown
    0010111         unknown
    0011000         unknown
    0011001         unknown
    0011010         unknown
    0011011         unknown
    0011100         unknown
    0011101         ADXL345, MMA7455L accelerometer
    0011110         HMC5843 / HMC5883 compass
    0011111         unknown
    0100000         IO expander - various types
    0100001         IO expander - various types
    0100010         IO expander - various types
    0100011         IO expander - various types
    0100100         IO expander - various types
    0100101         IO expander - various types
    0100110         IO expander - various types
    0100111         IO expander - various types
    0101000         unknown
    0101001         unknown
    0101010         unknown
    0101011         unknown
    0101100         unknown
    0101101         unknown
    0101110         unknown
    0101111         unknown
    0110000         unknown
    0110001         unknown
    0110010         unknown
    0110011         unknown
    0110100         unknown
    0110101         unknown
    0110110         unknown
    0110111         unknown
    0111000         BMA150 accelerometer
    0111001         unknown
    0111010         unknown
    0111011         unknown
    0111100         SSD1308 128x64 display driver
    0111101         SSD1308 128x64 display driver
    0111110         unknown
    0111111         unknown
    1000000         IQS156 touch sensor
    1000001         IQS156 touch sensor
    1000010         IQS156 touch sensor
    1000011         IQS156 touch sensor
    1000100         unknown
    1000101         unknown
    1000110         unknown
    1000111         unknown
    1001000         AD7745 / AD7746 capacitance to digital converter
                    ADS1113/4/5 16bit analog to digital converter
    1001001         ADS1113/4/5 16bit analog to digital converter
    1001010         ADS1113/4/5 16bit analog to digital converter
    1001011         ADS1113/4/5 16bit analog to digital converter
    1001100         unknown
    1001101         unknown
    1001110         unknown
    1001111         unknown
    1010000         24LCxxx EEPROM
    1010001         24LCxxx EEPROM
    1010010         24LCxxx EEPROM
    1010011         ADXL345 accelerometer alternate address
                    24LCxxx EEPROM at address 3
    1010100         24LCxxx EEPROM
    1010101         24LCxxx EEPROM
    1010110         24LCxxx EEPROM
    1010111         24LCxxx EEPROM
    1011000         unknown
    1011001         unknown
    1011010         MPR121 touch sensor
    1011011         MPR121 touch sensor
    1011100         MPR121 touch sensor
    1011101         MPR121 touch sensor
    1011110         unknown
    1011111         unknown
    1100000         MPL3115A2 altimeter
    1100001         unknown
    1100010         unknown
    1100011         unknown
    1100100         unknown
    1100101         unknown
    1100110         unknown
    1100111         unknown
    1101000         DS1307 real-time clock
                    L3G4200D gyroscope with SDO low
                    MPU9150 gyroscope and accelerometer with AD0 low
    1101001         L3G4200D gyroscope with SDO high
                    MPU9150 gyroscope and accelerometer with AD0 high
    1101010         unknown
    1101011         unknown
    1101100         unknown
    1101101         unknown
    1101110         unknown
    1101111         unknown
    1110000         unknown
    1110001         unknown
    1110010         unknown
    1110011         unknown
    1110100         unknown
    1110101         unknown
    1110110         MS5607 altimeter with CSB high
    1110111         BMP085 pressure sensor
                    MS5607 altimeter with CSB low
    1111000         unknown
    1111001         unknown
    1111010         unknown
    1111011         unknown
    1111100         unknown
    1111101         unknown
    1111110         unknown
    1111111         unknown
    Finished
    edited 2014-08-14 08:33
    Are you booting from EEPROM? If your mystery device is trying to stretch the clock (holding it low) while the Prop is trying to drive the clock high, that could certainly account for the Prop not booting. That's why I suggesed connecting it to unused pins on the Prop. I dunno how to go about selecting I2C lines in Forth.
    Your device is in the same address range as my I/O expander, which is where I first encountered that problem.
    That might also explain my poller finding something on every address. Those pullups are entirely too large; they should be somewhere in the 4.7K to 10K range. The poller even stated that it didn't detect a pullup on SDA, which means it was using a driven-output version. Again, the same issue as with the Prop bootloader trying to force a clock high that the slave is holding low.
    edited 2014-08-14 08:39
    ChrisGadd wrote: »
    Yes, right now booting from EEPROM using your I2C code. Attached to pins 8(SCL) and 9(SDA) with nothing else attached to those pins, save the pullup resistors.
    While using Forth, I had to use pins 28 and 29 because I didnt know how to change them. OBEX is back up now so i'm trying some of your stuff out.
    sccoupe wrote: »
    How do you know those lines are I2C? You must have some information on them and anyway if it's I2C there might already be another micro in there that's talking to it. Either way you should see some break in the listing. Just in case here's one that does a quick capture to a buffer then dumps it, a FF just means nothing is happening.
    #1024 BYTES i2cbuf
    pub MON BEGIN CR i2cbuf #1024 ADO P@ #24 SHR I C! LOOP i2cbuf #1024 DUMP ESC? UNTIL ;
    edited 2014-08-14 08:42
    #1024 BYTES i2cbuf
    You can use other port pins for I2C bus, if they are for instance P24 = SDA and P25 = SCL just type:
    #P24 #P25 I2CPINS
    Then try .I2CBUS
    edited 2014-08-14 08:43
    #1024 BYTES i2cbuf
    The datasheet (http://wenku.baidu.com/view/88627b87bceb19e8b8f6bab0.html) says they are IIC pins. There is no other micro on the converter board and these two pins are currently unused. I wish to make use of them.
    edited 2014-08-14 08:53
    sccoupe wrote: »
    You may need to add pullup resistors then as the datasheet seems to indicate that there are none on the chip and that may be the case with pin 56 (ADDR_SEL_FREEZE) too,
    edited 2014-08-14 08:58
    Thanks guys. I'll have to give this all a try again tonight. Upon closer inspection of the solder joints, there may be some bridging. I didnt realize how well a picture would turn out with a camera phone and magnifying glass. A smaller soldering needle and a better more stable magnifier will be needed so I can see what the heck i'm doing. Hopefully the hands will be steady enough.
    1024 x 757 - 131K
    edited 2014-08-14 13:40
    The schematics in that datasheet show SCL and SDA connected to ground! Were you able to cut that connection and verify it? Hard grounds on those lines would absolutely keep the Prop from booting from EEPROM, and would also cause my poller to see Acks from every address. It is odd, however, that my poller didn't mention not seeing a pullup on SCL, only SDA
    edited 2014-08-14 13:54
    The datasheet is only for the chip, not the product that i'm working on. Though the reference design shows these at ground, it doesn't seem that they are connect to ground in the product unless it is more than a 2 layer board where I cannot verify whether or not there are via's. There are no no via's under the chip that go all of the way though the board and there are no traces connected to the pads for pins 59 and 60.
    I'm going to try re-soldering the wires by gluing them down first and then hot air soldering with paste. At that point, i'll verify with an ohm meter whether or not they are connect to ground.
    edited 2014-08-14 14:08
    Ah, nevermind then. The clock-stretching is still a possibility. I connected my clock-stretching slave and ran the poller without pullups, and got the same results you did. The PASM driver and the regular Spin driver should both work in that case, just dial the pullups down to the 4.7K to 10K range.
    edited 2014-08-14 14:10
    Ok, I had an older converter that quit working, so I cut the chip off of it and have verified that 59 and 60 are not connected to anything. Before cutting, I verified that neither pin ohms to ground as well. Also verified that pin 56 is tied to ground with a 0 ohm resistor. So now I just need to get these wires soldered on in some way to give this a shot again. The pins are so tiny!
