What is the most suitable FPGA type... Cyclone V, Cyclone IV, Spartan 6, Spartan 3A ? — Parallax Forums
Cluso99Cluso99 Posts: 18,069
edited 2014-08-12 06:48 in Propeller 1
I was surprised that the Cyclone V on the BeMicro CV compiled so poorly.
So, I am wondering what usage/speed can be obtained from the various FPGA formats.
If you compile the original posted P1 code for any FPGA, could you please post your results here so we can compare them?
  • jazzedjazzed Posts: 11,803
    edited 2014-08-08 20:49
    I don't have any Cyclone V results yet, but should have the BeMicro CV board by Monday night, so any Cyclone V results definitely interest me.
    Here are the unmodified Cyclone IV E results.
    My compile results for Chip's Terasic DE0-Nano package:
    Flow Status    Successful - Fri Aug 08 17:04:30 2014
    Quartus II 64-Bit Version    14.0.0 Build 200 06/17/2014 SJ Web Edition
    Revision Name    top
    Top-level Entity Name    top
    Family    Cyclone IV E
    Device    EP4CE22F17C6
    Timing Models    Final
    Total logic elements    14,707 / 22,320 ( 66 % )
    Total combinational functions    13,363 / 22,320 ( 60 % )
    Dedicated logic registers    5,430 / 22,320 ( 24 % )
    Total registers    5430
    Total pins    42 / 154 ( 27 % )
    Total virtual pins    0
    Total memory bits    524,288 / 608,256 ( 86 % )
    Embedded Multiplier 9-bit elements    0 / 132 ( 0 % )
    Total PLLs    1 / 4 ( 25 % )
    My compile results for Chip's Terasic DE2-115 package:
    Flow Status    Successful - Fri Aug 08 20:34:13 2014
    Revision Name    top
    Family    Cyclone IV E
    Device    EP4CE115F29C7
    Timing Models    Final
    Total logic elements    14,572 / 114,480 ( 13 % )
    Total combinational functions    13,385 / 114,480 ( 12 % )
    Dedicated logic registers    5,431 / 114,480 ( 5 % )
    Total registers    5431
    Total pins    42 / 529 ( 8 % )
    Total memory bits    655,360 / 3,981,312 ( 16 % )
    Embedded Multiplier 9-bit elements    0 / 532 ( 0 % )
  • jmgjmg Posts: 15,190
    edited 2014-08-08 21:33
    Interesting memory figures. First says uses 65536 Bytes, the other 81920 Bytes, and I think the Nano chip said has the Character ROM removed.
    Reports a possible 76032 Bytes on the Nano, what is using the RAM ?
    edited 2014-08-08 21:47
    Here are Cyclone V compile results built according to Chip's instructions.
    Flow Status	Successful - Fri Aug 08 21:14:15 2014
    Revision Name	top
    Family	Cyclone V
    Device	5CEFA2F23C8
    Timing Models	Final
    Logic utilization (in ALMs)	8,522 / 9,430 ( 90 % )
    Total registers	5746
    Total pins	42 / 224 ( 19 % )
    Total block memory bits	655,360 / 1,802,240 ( 36 % )
    Total DSP Blocks	0 / 25 ( 0 % )
    Total HSSI RX PCSs	0
    Total HSSI PMA RX Deserializers	0
    Total HSSI TX PCSs	0
    Total HSSI PMA TX Serializers	0
    Total DLLs	0 / 4 ( 0 % )
    edited 2014-08-08 22:30
    Hmm.
    Maybe I can make a 384K Byte HUB RAM P1 on the DE2-115 board tomorrow (out of 440KB) ... in my dreams.
    Someone knows how though. jmg?
    edited 2014-08-09 04:00
    jazzed wrote: »
    Hmm.
    Allocation is quite easy. Addressing it is another problem. At least you can see what is usable (configurable).
    BTW Thanks for your compile results. Now we need someone to do the same for Spartan 3A and 6.
    edited 2014-08-09 04:40
    For memory usage on DE0
    8 * 2KB cogs + 32KB+16KB=48KB hub
    Total 64KB = 512Kb = 524,288 bits
    For memory usage on DE2
    8 * 2KB cogs + 64KB hub
    Total 80KB = 640Kb = 655,360 bits
    On the DE0 we have 608,256 bits avail
    608,256 b / 1024 = 594Kb = 74.25KB
    74.25KB - (8 * 2KB cogs) = 58.25KB
    So, 56KB hub might be available - so we should try 48KB hub ram and double map the last 2 * 8KB of ROM.
    But to try it without generating a new ROM file, keep the 32KB hub ram, and add 2 * 8KB double mapped ram next, then the last 16KB of ROM.
    This gives us 40KB hub ram with the 32-40KB also mapped as 40-48KB. The followed by the 16KB ROM.
    On the DE2 we have 3,981,312 bits avail
    3,981,312 b / 1024 = 3888Kb = 486KB
    486KB - (8 * 2KB cogs) = 470KB
    So we have ~470KB hub ram/rom available.
    edited 2014-08-09 07:07
    Good plan Ray.
    Re/ addressing - not much of an issue for RDxxxx / WRxxxx as they already theoretically can address a 32 bit address space.
    For an interesting variant, I suggest:
    512 long boot loader at byte address $0-$3FF (long addresses $0-$1FF)
    ram for the rest
    hubexec
    edited 2014-08-09 07:29
    Stupid question time:
    How can a bootloader be done that would keep all RAM free?
    edited 2014-08-09 07:49
    No, I think that is a good question.
    Basically, I was thinking of the first 512 longs in the hub being preset to be "ROM" (like on the P2) and hold just a cog image, loaded into cog0 and run at bootup.
    Then that cog would be responsible for loading from eeprom/flash.
    We would have a choice of keeping the boot rom mapped in, losing the first 512 longs from being used as ram, or the boot cog could flip a bit, and map ram back there.
    From P2 discussions, if the first 512 longs in the memory map were mapped as cog addresses, it does not matter if they are not ram.
    Or the bootloader could be in high memory, or not even present in the memory space - cog0 could be loaded from a "hidden" rom on startup.
    Many choices to explore!
    jazzed wrote: »
  • pik33pik33 Posts: 2,409
    edited 2014-08-09 10:12
    jazzed wrote: »
    Simply add a switchable (with mux, for example) rom block with bootloader which will connect to the Propeller after reset and then disconnect itself after doing its work.
    Or add a circuit which, after reset, will preload bootloader to RAM.
    edited 2014-08-09 12:19
    pik33 wrote: »
    Great! Sounds perfect. No memory pot-holes!
  • pedwardpedward Posts: 1,642
    edited 2014-08-09 14:04
    pik33 wrote: »
    Somebody spent too much time programming the MC68000 :lol:
    edited 2014-08-09 15:44
    Hey guys,
    Can we keep this thread on topic.
    Great discussions, but they would be better in their own thread. Thanks :)
  • roglohrogloh Posts: 5,900
    edited 2014-08-09 18:08
    Cluso99 wrote: »
    Cluso,
    It's been a while since I designed a few things with FPGAs (ok this will start to show my age, early '90s using XC3000 family Xilinx devices and with schematic capture only - not HDLs back then) but I am not sure that you can easily divide FPGA memory that finely. In general the available memory blocks are 9 bit wide so you only get 8/9ths of the capacity when storing byte wide quantities to the RAM. The extra bit in each byte, or bits when parallel widened > 8 bits, tends to become useful for other purposes such as fifo flags/frame delimiters, data validity/parity bits, etc but not to store the data itself. Perhaps you could but I suspect it would ugly real fast and start to involve multiple accesses per byte. So when considering this, I believe the DE-0 nano would effectively have about 66kB SRAM to play with when you lose the 9th bit.
    rogloh
    edited 2014-08-09 19:44
    ragloh,
    Yes, there will be some loss of use in there.
    I have just downloaded the latest Quartus so when I get home I can try a few things out.
    I too designed a few boards with Xilinx parts in the 90's. But I hand routed my designs for maximum speed. Lucky they were only small designs. One was a bus interface to a mini.
    edited 2014-08-09 22:12
    What's off topic Ray?
    I'm happy to remove any of my postings that you seriously deem off topic, and I assume that others may remove theirs also.
    edited 2014-08-09 22:52
    pedward wrote: »
    Connecting 68000 to the Propeller may give us an interesting results :)
    edited 2014-08-10 00:51
    jazzed wrote: »
    No, I'd rather just keep this for discussing the suitability and comparisons of the FPGAs and have a new topic for discussing memory layouts. That way I (and others) can find it easily. I normally wouldn't think to look in this thread for those sort of discussions.
    edited 2014-08-10 03:40
    Here is the results for Quartus 64bit v14.0.0.200 for the DE0-Nano (original files unchanged)...
    Flow Status    Successful - Sun Aug 10 20:07:15 2014
    Revision Name    top
    Family    Cyclone IV E
    Device    EP4CE22F17C6
    Timing Models    Final
    And here is the log. Note the warnings - unsure what some of them mean.
    [code]
    Info: *******************************************************************
    Info: Running Quartus II 64-Bit Analysis & Synthesis
    Info: Version 14.0.0 Build 200 06/17/2014 SJ Web Edition
    Info: Processing started: Sun Aug 10 19:57:22 2014
    Info: Command: quartus_map --read_settings_files=on --write_settings_files=off top -c top
    Warning (20028): Parallel compilation is not licensed and has been disabled
    Warning (12125): Using design file top.tdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project
    Info (12023): Found entity 1: top
    Info (12127): Elaborating entity "top" for the top level hierarchy
    Info (12128): Elaborating entity "altpll" for hierarchy "altpll:pll"
    Info (12130): Elaborated megafunction instantiation "altpll:pll"
    Info (12133): Instantiated megafunction "altpll:pll" with the following parameter:
    Info (12134): Parameter "clk0_divide_by" = "5"
    Info (12134): Parameter "clk0_multiply_by" = "16"
    Info (12134): Parameter "inclk0_input_frequency" = "20000"
    Info (12134): Parameter "operation_mode" = "normal"
    Info (12134): Parameter "pll_type" = "enhanced"
    Info (12134): Parameter "width_clock" = "6"
    Info (12134): Parameter "width_phasecounterselect" = "4"
    Info (12021): Found 1 design units, including 1 entities, in source file db/altpll_ejp.tdf
    Info (12023): Found entity 1: altpll_ejp
    Info (12128): Elaborating entity "altpll_ejp" for hierarchy "altpll:pll|altpll_ejp:auto_generated"
    Warning (12125): Using design file tim.tdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project
    Info (12023): Found entity 1: tim
    Info (12128): Elaborating entity "tim" for hierarchy "tim:clkgen"
    Warning (12125): Using design file dig.v, which is not specified as a design file for the current project, but contains definitions for 8 design units and 8 entities in project
    Info (12023): Found entity 1: cog_ram
    Info (12023): Found entity 2: cog_alu
    Info (12023): Found entity 3: cog_ctr
    Info (12023): Found entity 4: cog_vid
    Info (12023): Found entity 5: cog
    Info (12023): Found entity 6: hub_mem
    Info (12023): Found entity 7: hub
    Info (12023): Found entity 8: dig
    Info (12128): Elaborating entity "dig" for hierarchy "dig:core"
    Info (12128): Elaborating entity "cog" for hierarchy "dig:core|cog:coggen[0].cog_"
    Info (12128): Elaborating entity "cog_ram" for hierarchy "dig:core|cog:coggen[0].cog_|cog_ram:cog_ram_"
    Warning (276027): Inferred dual-clock RAM node "dig:core|cog:coggen[0].cog_|cog_ram:cog_ram_|altsyncram:r[0][31]__1" from synchronous design logic. The read-during-write behavior of a dual-clock RAM is undefined and may not match the behavior of the original design.
    Info (19000): Inferred 1 megafunctions from design logic
    Info (276029): Inferred altsyncram megafunction from the following design logic: "dig:core|cog:coggen[0].cog_|cog_ram:cog_ram_|altsyncram:r[0][31]__1"
    Info (286033): Parameter OPERATION_MODE set to DUAL_PORT
    Info (286033): Parameter WIDTH_A set to 32
    Info (286033): Parameter WIDTHAD_A set to 9
    Info (286033): Parameter NUMWORDS_A set to 512
    Info (286033): Parameter WIDTH_B set to 32
    Info (286033): Parameter WIDTHAD_B set to 9
    Info (286033): Parameter NUMWORDS_B set to 512
    Info (286033): Parameter ADDRESS_ACLR_A set to NONE
    Info (286033): Parameter OUTDATA_REG_B set to UNREGISTERED
    Info (286033): Parameter ADDRESS_ACLR_B set to NONE
    Info (286033): Parameter OUTDATA_ACLR_B set to NONE
    Info (286033): Parameter ADDRESS_REG_B set to CLOCK1
    Info (286033): Parameter INDATA_ACLR_A set to NONE
    Info (286033): Parameter WRCONTROL_ACLR_A set to NONE
    Info (12128): Elaborating entity "altsyncram" for hierarchy "dig:core|cog:coggen[0].cog_|cog_ram:cog_ram_|altsyncram:r[0][31]__1"
    Info (12130): Elaborated megafunction instantiation "dig:core|cog:coggen[0].cog_|cog_ram:cog_ram_|altsyncram:r[0][31]__1"
    Info (12133): Instantiated megafunction "dig:core|cog:coggen[0].cog_|cog_ram:cog_ram_|altsyncram:r[0][31]__1" with the following parameter:
    Info (12134): Parameter "OPERATION_MODE" = "DUAL_PORT"
    Info (12134): Parameter "WIDTH_A" = "32"
    Info (12134): Parameter "WIDTHAD_A" = "9"
    Info (12134): Parameter "NUMWORDS_A" = "512"
    Info (12134): Parameter "WIDTH_B" = "32"
    Info (12134): Parameter "WIDTHAD_B" = "9"
    Info (12134): Parameter "NUMWORDS_B" = "512"
    Info (12134): Parameter "ADDRESS_ACLR_A" = "NONE"
    Info (12134): Parameter "OUTDATA_REG_B" = "UNREGISTERED"
    Info (12134): Parameter "ADDRESS_ACLR_B" = "NONE"
    Info (12134): Parameter "OUTDATA_ACLR_B" = "NONE"
    Info (12134): Parameter "ADDRESS_REG_B" = "CLOCK1"
    Info (12134): Parameter "INDATA_ACLR_A" = "NONE"
    Info (12134): Parameter "WRCONTROL_ACLR_A" = "NONE"
    Info (12021): Found 1 design units, including 1 entities, in source file db/altsyncram_isd1.tdf
    Info (12023): Found entity 1: altsyncram_isd1
    Info (12128): Elaborating entity "altsyncram_isd1" for hierarchy "dig:core|cog:coggen[0].cog_|cog_ram:cog_ram_|altsyncram:r[0][31]__1|altsyncram_isd1:auto_generated"
    Info (12128): Elaborating entity "cog_ctr" for hierarchy "dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra"
    Info (12128): Elaborating entity "cog_vid" for hierarchy "dig:core|cog:coggen[0].cog_|cog_vid:cog_vid_"
    Info (12128): Elaborating entity "cog_alu" for hierarchy "dig:core|cog:coggen[0].cog_|cog_alu:cog_alu_"
    Info (12128): Elaborating entity "hub" for hierarchy "dig:core|hub:hub_"
    Info (12128): Elaborating entity "hub_mem" for hierarchy "dig:core|hub:hub_|hub_mem:hub_mem_"
    Warning (10858): Verilog HDL warning at hub_mem.v(85): object rom_low used but never assigned
    Warning (10036): Verilog HDL or VHDL warning at hub_mem.v(87): object "rom_low_q" assigned a value but never read
    Warning (10858): Verilog HDL warning at hub_mem.v(96): object rom_high used but never assigned
    Warning (19016): Clock multiplexers are found and protected
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|Mux6
    Warning (19017): Found clock multiplexer tim:clkgen|clk_pll~2
    Warning (276020): Inferred RAM node "dig:core|hub:hub_|hub_mem:hub_mem_|ram0_rtl_0" from synchronous design logic. Pass-through logic has been added to match the read-during-write behavior of the original design.
    Warning (276020): Inferred RAM node "dig:core|hub:hub_|hub_mem:hub_mem_|ram3_rtl_0" from synchronous design logic. Pass-through logic has been added to match the read-during-write behavior of the original design.
    Warning (276020): Inferred RAM node "dig:core|hub:hub_|hub_mem:hub_mem_|ram2_rtl_0" from synchronous design logic. Pass-through logic has been added to match the read-during-write behavior of the original design.
    Warning (276020): Inferred RAM node "dig:core|hub:hub_|hub_mem:hub_mem_|ram1_rtl_0" from synchronous design logic. Pass-through logic has been added to match the read-during-write behavior of the original design.
    Info (19000): Inferred 5 megafunctions from design logic
    Info (276029): Inferred altsyncram megafunction from the following design logic: "dig:core|hub:hub_|hub_mem:hub_mem_|rom_high_rtl_0"
    Info (286033): Parameter OPERATION_MODE set to ROM
    Info (286033): Parameter WIDTHAD_A set to 12
    Info (286033): Parameter NUMWORDS_A set to 4096
    Info (286033): Parameter OUTDATA_REG_A set to UNREGISTERED
    Info (286033): Parameter OUTDATA_ACLR_A set to NONE
    Info (286033): Parameter INIT_FILE set to hub_rom_high.hex
    Info (276029): Inferred altsyncram megafunction from the following design logic: "dig:core|hub:hub_|hub_mem:hub_mem_|ram0_rtl_0"
    Info (286033): Parameter WIDTH_A set to 8
    Info (286033): Parameter WIDTHAD_A set to 13
    Info (286033): Parameter NUMWORDS_A set to 8192
    Info (286033): Parameter WIDTH_B set to 8
    Info (286033): Parameter WIDTHAD_B set to 13
    Info (286033): Parameter NUMWORDS_B set to 8192
    Info (286033): Parameter ADDRESS_REG_B set to CLOCK0
    Info (286033): Parameter READ_DURING_WRITE_MODE_MIXED_PORTS set to OLD_DATA
    Info (276029): Inferred altsyncram megafunction from the following design logic: "dig:core|hub:hub_|hub_mem:hub_mem_|ram3_rtl_0"
    Info (276029): Inferred altsyncram megafunction from the following design logic: "dig:core|hub:hub_|hub_mem:hub_mem_|ram2_rtl_0"
    Info (276029): Inferred altsyncram megafunction from the following design logic: "dig:core|hub:hub_|hub_mem:hub_mem_|ram1_rtl_0"
    Info (12130): Elaborated megafunction instantiation "dig:core|hub:hub_|hub_mem:hub_mem_|altsyncram:rom_high_rtl_0"
    Info (12133): Instantiated megafunction "dig:core|hub:hub_|hub_mem:hub_mem_|altsyncram:rom_high_rtl_0" with the following parameter:
    Info (12134): Parameter "OPERATION_MODE" = "ROM"
    Info (12134): Parameter "WIDTHAD_A" = "12"
    Info (12134): Parameter "NUMWORDS_A" = "4096"
    Info (12134): Parameter "OUTDATA_REG_A" = "UNREGISTERED"
    Info (12134): Parameter "OUTDATA_ACLR_A" = "NONE"
    Info (12134): Parameter "INIT_FILE" = "hub_rom_high.hex"
    Info (12021): Found 1 design units, including 1 entities, in source file db/altsyncram_0u51.tdf
    Info (12023): Found entity 1: altsyncram_0u51
    Warning (113015): Width of data items in "hub_rom_high.hex" is greater than the memory width. Wrapping data items to subsequent addresses. Found 512 warnings, reporting 10
    Warning (113009): Data at line (1) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (2) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (3) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (4) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (5) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (6) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (7) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (8) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (9) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Warning (113009): Data at line (10) of memory initialization file "hub_rom_high.hex" is too wide to fit in one memory word. Wrapping data to subsequent addresses.
    Info (12130): Elaborated megafunction instantiation "dig:core|hub:hub_|hub_mem:hub_mem_|altsyncram:ram0_rtl_0"
    Info (12133): Instantiated megafunction "dig:core|hub:hub_|hub_mem:hub_mem_|altsyncram:ram0_rtl_0" with the following parameter:
    Info (12134): Parameter "WIDTH_A" = "8"
    Info (12134): Parameter "WIDTHAD_A" = "13"
    Info (12134): Parameter "NUMWORDS_A" = "8192"
    Info (12134): Parameter "WIDTH_B" = "8"
    Info (12134): Parameter "WIDTHAD_B" = "13"
    Info (12134): Parameter "NUMWORDS_B" = "8192"
    Info (12134): Parameter "ADDRESS_REG_B" = "CLOCK0"
    Info (12134): Parameter "READ_DURING_WRITE_MODE_MIXED_PORTS" = "OLD_DATA"
    Info (12021): Found 1 design units, including 1 entities, in source file db/altsyncram_nii1.tdf
    Info (12023): Found entity 1: altsyncram_nii1
    Info (13000): Registers with preset signals will power-up high
    Info (13003): DEV_CLRn pin will set, and not reset, register with preset signal due to NOT Gate Push-Back
    Info (286030): Timing-Driven Synthesis is running
    Info (16010): Generating hard_block partition "hard_block:auto_generated_inst"
    Info (16011): Adding 1 node(s), including 0 DDIO, 1 PLL, 0 transceiver and 0 LCELL
    Info (21057): Implemented 16903 device resources after synthesis - the final resource count might be different
    Info (21058): Implemented 2 input pins
    Info (21059): Implemented 8 output pins
    Info (21060): Implemented 32 bidirectional pins
    Info (21061): Implemented 16540 logic cells
    Info (21064): Implemented 320 RAM segments
    Info (21065): Implemented 1 PLLs
    Info: Quartus II 64-Bit Analysis & Synthesis was successful. 0 errors, 34 warnings
    Info: Peak virtual memory: 829 megabytes
    Info: Processing ended: Sun Aug 10 19:59:37 2014
    Info: Elapsed time: 00:02:15
    Info: Total CPU time (on all processors): 00:02:02
    Info: Running Quartus II 64-Bit Fitter
    Info: Processing started: Sun Aug 10 19:59:40 2014
    Info: Command: quartus_fit --read_settings_files=off --write_settings_files=off top -c top
    Info: qfit2_default_script.tcl version: #1
    Info: Project = top
    Info: Revision = top
    Info (119006): Selected device EP4CE22F17C6 for design "top"
    Info (21077): Low junction temperature is 0 degrees C
    Info (21077): High junction temperature is 85 degrees C
    Info (15535): Implemented PLL "altpll:pll|altpll_ejp:auto_generated|pll1" as Cyclone IV E PLL type
    Info (15099): Implementing clock multiplication of 16, clock division of 5, and phase shift of 0 degrees (0 ps) for altpll:pll|altpll_ejp:auto_generated|clk[0] port
    Info (171003): Fitter is performing an Auto Fit compilation, which may decrease Fitter effort to reduce compilation time
    Warning (292013): Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature.
    Info (176444): Device migration not selected. If you intend to use device migration later, you may need to change the pin assignments as they may be incompatible with other devices
    Info (176445): Device EP4CE10F17C6 is compatible
    Info (176445): Device EP4CE6F17C6 is compatible
    Info (176445): Device EP4CE15F17C6 is compatible
    Info (169124): Fitter converted 4 user pins into dedicated programming pins
    Info (169125): Pin ~ALTERA_ASDO_DATA1~ is reserved at location C1
    Info (169125): Pin ~ALTERA_FLASH_nCE_nCSO~ is reserved at location D2
    Info (169125): Pin ~ALTERA_DCLK~ is reserved at location H1
    Info (169125): Pin ~ALTERA_DATA0~ is reserved at location H2
    Warning (15714): Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details
    Info (176045): Design uses memory blocks. Violating setup or hold times of memory block address registers for either read or write operations could cause memory contents to be corrupted. Make sure that all memory block address registers meet the setup and hold time requirements.
    Critical Warning (332012): Synopsys Design Constraints File file not found: 'top.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
    Info (332144): No user constrained generated clocks found in the design
    Info (332144): No user constrained base clocks found in the design
    Info (332097): The following timing edges are non-unate. TimeQuest will assume pos-unate behavior for these edges in the clock network.
    Info (332098): Cell: core|coggen[0].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[0].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[0].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[0].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332098): Cell: core|coggen[1].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[1].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[1].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[1].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332098): Cell: core|coggen[2].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[2].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[2].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[2].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332098): Cell: core|coggen[4].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[4].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[4].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[4].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332098): Cell: core|coggen[5].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[5].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[5].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[5].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332098): Cell: core|coggen[6].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[6].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[6].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[6].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332098): Cell: core|coggen[7].cog_|cog_ctra|Mux6~0 from: datac to: combout
    Info (332098): Cell: core|coggen[7].cog_|cog_ctra|Mux6~1 from: datac to: combout
    Info (332098): Cell: core|coggen[7].cog_|cog_ctra|Mux6~3 from: datac to: combout
    Info (332098): Cell: core|coggen[7].cog_|cog_ctra|Mux6~4 from: datac to: combout
    Info (332143): No user constrained clock uncertainty found in the design. Calling "derive_clock_uncertainty"
    Info (332123): Deriving Clock Uncertainty. Please refer to report_sdc in TimeQuest to see clock uncertainties.
    Info (332130): Timing requirements not specified -- quality metrics such as performance may be sacrificed to reduce compilation time.
    Info (176353): Automatically promoted node altpll:pll|altpll_ejp:auto_generated|clk[0] (placed in counter C0 of PLL_4)
    Info (176355): Automatically promoted destinations to use location or clock signal Global Clock CLKCTRL_G18
    Info (176353): Automatically promoted node tim:clkgen|divide[12]
    Info (176356): Following destination nodes may be non-global or may not use global or regional clocks
    Info (176357): Destination node tim:clkgen|divide[12]~37
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_vid:cog_vid_|vid[30]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_vid:cog_vid_|vid[29]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[24]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[25]
    Info (176357): Destination node dig:core|cog:coggen[1].cog_|cog_vid:cog_vid_|vid[30]
    Info (176357): Destination node dig:core|cog:coggen[1].cog_|cog_vid:cog_vid_|vid[29]
    Info (176357): Destination node dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[24]
    Info (176357): Destination node dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[25]
    Info (176357): Destination node dig:core|cog:coggen[2].cog_|cog_vid:cog_vid_|vid[30]
    Info (176358): Non-global destination nodes limited to 10 nodes
    Info (176353): Automatically promoted node tim:clkgen|clk_pll
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[35]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[34]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[33]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[32]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[31]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[30]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[29]
    Info (176357): Destination node dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|pll_fake[28]
    Info (176357): Destination node dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|pll_fake[35]
    Info (176357): Destination node dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|pll_fake[34]
    Info (176353): Automatically promoted node dig:core|cog:coggen[0].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node dig:core|cog:coggen[1].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node dig:core|cog:coggen[2].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node dig:core|cog:coggen[3].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node dig:core|cog:coggen[4].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node dig:core|cog:coggen[5].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node dig:core|cog:coggen[6].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node dig:core|cog:coggen[7].cog_|cog_vid:cog_vid_|vclk
    Info (176353): Automatically promoted node nres
    Info (176357): Destination node dig:core|cnt[2]
    Info (176357): Destination node dig:core|cnt[1]
    Info (176357): Destination node dig:core|cnt[3]
    Info (176357): Destination node dig:core|cnt[4]
    Info (176357): Destination node dig:core|cnt[5]
    Info (176357): Destination node dig:core|cnt[6]
    Info (176357): Destination node dig:core|cnt[7]
    Info (176357): Destination node dig:core|cnt[8]
    Info (176357): Destination node dig:core|cnt[9]
    Info (176357): Destination node dig:core|cnt[10]
    Info (176233): Starting register packing
    Info (176235): Finished register packing
    Extra Info (176219): No registers were packed into other blocks
    Info (171121): Fitter preparation operations ending: elapsed time is 00:00:19
    Info (14896): Fitter has disabled Advanced Physical Optimization because it is not supported for the current family.
    Info (170189): Fitter placement preparation operations beginning
    Info (170190): Fitter placement preparation operations ending: elapsed time is 00:00:25
    Info (170191): Fitter placement operations beginning
    Info (170137): Fitter placement was successful
    Info (170192): Fitter placement operations ending: elapsed time is 00:03:16
    Info (170193): Fitter routing operations beginning
    Info (170089): 7e+02 ns of routing delay (approximately 1.5% of available device routing delay) has been added to meet hold timing. For more information, refer to the Estimated Delay Added for Hold Timing section in the Fitter report.
    Info (170195): Router estimated average interconnect usage is 31% of the available device resources
    Info (170196): Router estimated peak interconnect usage is 48% of the available device resources in the region that extends from location X21_Y11 to location X31_Y22
    Info (170194): Fitter routing operations ending: elapsed time is 00:02:26
    Info (170199): The Fitter performed an Auto Fit compilation. Optimizations were skipped to reduce compilation time.
    Info (170201): Optimizations that may affect the design's routability were skipped
    Info (11888): Total time spent on timing analysis during the Fitter is 51.84 seconds.
    Info (334003): Started post-fitting delay annotation
    Info (334004): Delay annotation completed successfully
    Info (11218): Fitter post-fit operations ending: elapsed time is 00:00:20
    Warning (169177): 34 pins must meet Altera requirements for 3.3-, 3.0-, and 2.5-V interfaces. For more information, refer to AN 447: Interfacing Cyclone IV E Devices with 3.3/3.0/2.5-V LVTTL/LVCMOS I/O Systems.
    Info (169178): Pin io[0] uses I/O standard 3.3-V LVCMOS at J14
    Info (169178): Pin io[1] uses I/O standard 3.3-V LVCMOS at J13
    Info (169178): Pin io[2] uses I/O standard 3.3-V LVCMOS at K15
    Info (169178): Pin io[3] uses I/O standard 3.3-V LVCMOS at J16
    Info (169178): Pin io[4] uses I/O standard 3.3-V LVCMOS at L13
    Info (169178): Pin io[5] uses I/O standard 3.3-V LVCMOS at M10
    Info (169178): Pin io[6] uses I/O standard 3.3-V LVCMOS at N14
    Info (169178): Pin io[7] uses I/O standard 3.3-V LVCMOS at L14
    Info (169178): Pin io[8] uses I/O standard 3.3-V LVCMOS at P14
    Info (169178): Pin io[9] uses I/O standard 3.3-V LVCMOS at N15
    Info (169178): Pin io[10] uses I/O standard 3.3-V LVCMOS at N16
    Info (169178): Pin io[11] uses I/O standard 3.3-V LVCMOS at R14
    Info (169178): Pin io[12] uses I/O standard 3.3-V LVCMOS at P16
    Info (169178): Pin io[13] uses I/O standard 3.3-V LVCMOS at P15
    Info (169178): Pin io[14] uses I/O standard 3.3-V LVCMOS at L15
    Info (169178): Pin io[15] uses I/O standard 3.3-V LVCMOS at R16
    Info (169178): Pin io[16] uses I/O standard 3.3-V LVCMOS at K16
    Info (169178): Pin io[17] uses I/O standard 3.3-V LVCMOS at L16
    Info (169178): Pin io[18] uses I/O standard 3.3-V LVCMOS at N11
    Info (169178): Pin io[19] uses I/O standard 3.3-V LVCMOS at N9
    Info (169178): Pin io[20] uses I/O standard 3.3-V LVCMOS at P9
    Info (169178): Pin io[21] uses I/O standard 3.3-V LVCMOS at N12
    Info (169178): Pin io[22] uses I/O standard 3.3-V LVCMOS at R10
    Info (169178): Pin io[23] uses I/O standard 3.3-V LVCMOS at P11
    Info (169178): Pin io[24] uses I/O standard 3.3-V LVCMOS at R11
    Info (169178): Pin io[25] uses I/O standard 3.3-V LVCMOS at T10
    Info (169178): Pin io[26] uses I/O standard 3.3-V LVCMOS at T11
    Info (169178): Pin io[27] uses I/O standard 3.3-V LVCMOS at R12
    Info (169178): Pin io[28] uses I/O standard 3.3-V LVCMOS at T12
    Info (169178): Pin io[29] uses I/O standard 3.3-V LVCMOS at R13
    Info (169178): Pin io[30] uses I/O standard 3.3-V LVCMOS at B11
    Info (169178): Pin io[31] uses I/O standard 3.3-V LVCMOS at E10
    Info (169178): Pin inp_resn uses I/O standard 3.3-V LVCMOS at D9
    Info (169178): Pin clock_50 uses I/O standard 3.3-V LVCMOS at R8
    Info (144001): Generated suppressed messages file C:/altera/14.0/P8X32A_DE0_Nano/top.fit.smsg
    Info: Quartus II 64-Bit Fitter was successful. 0 errors, 5 warnings
    Info: Peak virtual memory: 970 megabytes
    Info: Processing ended: Sun Aug 10 20:07:04 2014
    Info: Elapsed time: 00:07:24
    Info: Total CPU time (on all processors): 00:07:11
    Info: Running Quartus II 64-Bit Assembler
    Info: Processing started: Sun Aug 10 20:07:09 2014
    Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off top -c top
    Info (115031): Writing out detailed assembly data for power analysis
    Info (115030): Assembler is generating device programming files
    Info: Quartus II 64-Bit Assembler was successful. 0 errors, 0 warnings
    Info: Peak virtual memory: 546 megabytes
    Info: Processing ended: Sun Aug 10 20:07:15 2014
    Info: Elapsed time: 00:00:06
    Info: Total CPU time (on all processors): 00:00:05
    Info: Peak vir
    edited 2014-08-10 03:42
    ...continued from previous post...
    Info: Running Quartus II 64-Bit TimeQuest Timing Analyzer
        Info: Processing started: Sun Aug 10 20:07:18 2014
    Info: Command: quartus_sta top -c top
    Info: qsta_default_script.tcl version: #1
    Info (332142): No user constrained generated clocks found in the design. Calling "derive_pll_clocks -create_base_clocks"
    Info (332110): Deriving PLL clocks
        Info (332110): create_clock -period 20.000 -waveform {0.000 10.000} -name clock_50 clock_50
        Info (332110): create_generated_clock -source  {pll|auto_generated|pll1|inclk[0]} -divide_by 5 -multiply_by 16  -duty_cycle 50.00 -name {pll|auto_generated|pll1|clk[0]}  {pll|auto_generated|pll1|clk[0]}
    Info (332142): No user constrained base clocks found in the design. Calling "derive_clocks -period 1.0"
    Info (332105): Deriving Clocks
        Info (332105): create_clock -period 1.000 -name tim:clkgen|divide[12] tim:clkgen|divide[12]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332105): create_clock -period 1.000 -name  dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]  dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332098): Cell: core|coggen[1].cog_|cog_ctra|Mux6~4  from: datab  to: combout
        Info (332098): Cell: core|coggen[2].cog_|cog_ctra|Mux6~1  from: datad  to: combout
        Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~0  from: datab  to: combout
        Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~1  from: datad  to: combout
        Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~3  from: datad  to: combout
        Info (332098): Cell: core|coggen[3].cog_|cog_ctra|Mux6~4  from: datad  to: combout
        Info (332098): Cell: core|coggen[4].cog_|cog_ctra|Mux6~4  from: datad  to: combout
        Info (332098): Cell: core|coggen[7].cog_|cog_ctra|Mux6~0  from: dataa  to: combout
    Info: Found TIMEQUEST_REPORT_SCRIPT_INCLUDE_DEFAULT_ANALYSIS = ON
    Info: Analyzing Slow 1200mV 85C Model
    Critical Warning (332148): Timing requirements not met
        Info (11105): For recommendations on closing timing, run Report  Timing Closure Recommendations in the TimeQuest Timing Analyzer.
    Info (332146): Worst-case setup slack is -8.537
        Info (332119):     Slack       End Point TNS Clock
        Info (332119): ========= =================== =====================
        Info (332119):    -8.537          -23234.750 tim:clkgen|divide[12]
        Info (332119):    -4.667           -2083.642 pll|auto_generated|pll1|clk[0]
        Info (332119):    -3.330            -323.556 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.997            -259.837 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.911            -262.853 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.795            -253.199 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.793            -264.611 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.745            -256.572 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.636            -251.204 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.545            -239.920 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
    Info (332146): Worst-case hold slack is -1.468
        Info (332119):    -1.468             -44.627 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.416             -40.489 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.397             -10.477 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.096             -31.143 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.859             -74.247 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.815             -73.552 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.358             -23.961 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.084              -1.375 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.273               0.000 pll|auto_generated|pll1|clk[0]
        Info (332119):     0.311               0.000 tim:clkgen|divide[12]
    Info (332146): Worst-case recovery slack is -3.058
        Info (332119):    -3.058           -1405.020 tim:clkgen|divide[12]
        Info (332119):    -0.562              -0.562 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.255              -0.255 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.189               0.000 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.297               0.000 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.335               0.000 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.511               0.000 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.694               0.000 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.765               0.000 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
    Info (332146): Worst-case removal slack is -0.934
        Info (332119):    -0.934              -0.934 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.773              -0.773 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.659              -0.659 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.631              -0.631 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.371              -0.371 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.215              -0.215 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.192              -0.192 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.256               0.000 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     1.377               0.000 tim:clkgen|divide[12]
    Info (332146): Worst-case minimum pulse width slack is -2.174
        Info (332119):    -2.174           -4392.192 tim:clkgen|divide[12]
        Info (332119):    -1.000            -427.501 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -183.094 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -154.899 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -147.266 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -139.811 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -132.045 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -131.174 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -121.784 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     2.818               0.000 pll|auto_generated|pll1|clk[0]
        Info (332119):     9.747               0.000 clock_50
    Info: Analyzing Slow 1200mV 0C Model
    Info (332146): Worst-case setup slack is -7.664
        Info (332119):    -7.664          -20472.285 tim:clkgen|divide[12]
        Info (332119):    -4.024           -1834.901 pll|auto_generated|pll1|clk[0]
        Info (332119):    -2.921            -281.084 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.625            -223.620 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.554            -227.158 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.444            -216.626 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.440            -227.736 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.392            -221.505 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.312            -216.698 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -2.212            -205.061 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
    Info (332146): Worst-case hold slack is -1.248
        Info (332119):    -1.248             -29.995 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.223             -28.035 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.196              -3.585 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.915             -18.520 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.712             -58.548 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.664             -58.602 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.267             -16.414 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.016               0.000 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.182               0.000 pll|auto_generated|pll1|clk[0]
        Info (332119):     0.297               0.000 tim:clkgen|divide[12]
    Info (332146): Worst-case recovery slack is -2.618
        Info (332119):    -2.618           -1160.107 tim:clkgen|divide[12]
        Info (332119):    -0.442              -0.442 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.223              -0.223 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.262               0.000 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.318               0.000 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.350               0.000 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.503               0.000 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.666               0.000 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.747               0.000 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
    Info (332146): Worst-case removal slack is -0.786
        Info (332119):    -0.786              -0.786 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.615              -0.615 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.515              -0.515 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.494              -0.494 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.260              -0.260 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.121              -0.121 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.114              -0.114 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.319               0.000 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     1.258               0.000 tim:clkgen|divide[12]
        Info (332119):    -1.000            -386.702 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -169.308 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -142.621 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -135.000 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -134.955 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -128.746 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -126.650 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -124.271 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     2.839               0.000 pll|auto_generated|pll1|clk[0]
        Info (332119):     9.709               0.000 clock_50
    Info: Analyzing Fast 1200mV 0C Model
    Info (332146): Worst-case setup slack is -4.545
        Info (332119):    -4.545          -11614.439 tim:clkgen|divide[12]
        Info (332119):    -2.802           -1237.373 pll|auto_generated|pll1|clk[0]
        Info (332119):    -1.468            -136.289 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.237             -98.156 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.200             -99.567 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.146             -96.658 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.123            -100.517 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.073             -93.888 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.021             -90.654 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.994             -87.034 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
    Info (332146): Worst-case hold slack is -0.577
        Info (332119):    -0.577              -0.577 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.576              -2.171 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.570              -2.428 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.409              -0.648 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.251             -16.586 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.237             -17.581 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.039               0.000 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.149               0.000 tim:clkgen|divide[12]
        Info (332119):     0.186               0.000 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.196               0.000 pll|auto_generated|pll1|clk[0]
    Info (332146): Worst-case recovery slack is -1.428
        Info (332119):    -1.428            -511.565 tim:clkgen|divide[12]
        Info (332119):    -0.217              -0.217 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.011               0.000 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.197               0.000 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.274               0.000 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.304               0.000 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.456               0.000 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.530               0.000 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.573               0.000 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
    Info (332146): Worst-case removal slack is -0.295
        Info (332119):    -0.295              -0.295 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.194              -0.194 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.138              -0.138 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -0.106              -0.106 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.014               0.000 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.118               0.000 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.176               0.000 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.404               0.000 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     0.775               0.000 tim:clkgen|divide[12]
    Info (332146): Worst-case minimum pulse width slack is -1.000
        Info (332119):    -1.000           -4148.000 tim:clkgen|divide[12]
        Info (332119):    -1.000            -207.488 dig:core|cog:coggen[0].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -118.901 dig:core|cog:coggen[2].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -113.583 dig:core|cog:coggen[3].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -112.000 dig:core|cog:coggen[1].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -112.000 dig:core|cog:coggen[4].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -112.000 dig:core|cog:coggen[5].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -112.000 dig:core|cog:coggen[6].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):    -1.000            -112.000 dig:core|cog:coggen[7].cog_|cog_ctr:cog_ctra|ctr[23]
        Info (332119):     2.722               0.000 pll|auto_generated|pll1|clk[0]
        Info (332119):     9.416               0.000 clock_50
    Info (332102): Design is not fully constrained for setup requirements
    Info (332102): Design is not fully constrained for hold requirements
    Info: Quartus II 64-Bit TimeQuest Timing Analyzer was successful. 0 errors, 5 warnings
        Info: Peak virtual memory: 700 megabytes
        Info: Processing ended: Sun Aug 10 20:07:55 2014
        Info: Elapsed time: 00:00:37
        Info: Total CPU time (on all processors): 00:00:34
    Info (293000): Quartus II Full Compilation was successful. 0 errors, 44 warnings
    Compilation took 10 mins on an i3-3217U 1.8GHz laptop :frown:
    BTW Quartus is able to replace the tabs with spaces.
  • AleAle Posts: 2,363
    edited 2014-08-11 03:43
    I know it doesn't fit. I just wanted to know for how much ;-).
    It most probably removed a buch of logic, because I only see 16 RAM blocks being allocated... work in progress. Till that point, it was really fast complaining :)
    Design Information
    Command line:   map -a MachXO2 -p LCMXO2-7000HE -t TQFP144 -s 4 -oc Commercial
         PX8A32_XO2_PX8A32_XO2.ngd -o PX8A32_XO2_PX8A32_XO2_map.ncd -pr
         PX8A32_XO2_PX8A32_XO2.prf -mp PX8A32_XO2_PX8A32_XO2.mrp
         C:/02_Elektronik/043_P8X32A/Lattice/PX8A32_XO2.lpf -c 0 -gui
    Target Vendor:  LATTICE
    Target Device:  LCMXO2-7000HETQFP144
    Target Performance:   4
    Mapper:  xo2c00,  version:  Diamond (64-bit) 3.1.0.96
    Mapped on:  08/11/14  12:39:41
    Design Summary
       Number of registers:   4935 out of  7209 (68%)
          PFU registers:         4927 out of  6864 (72%)
          PIO registers:            8 out of   345 (2%)
       Number of SLICEs:      7209 out of  3432 (210%)
          SLICEs as Logic/ROM:   7209 out of  3432 (210%)
          SLICEs as RAM:            0 out of  2574 (0%)
          SLICEs as Carry:        969 out of  3432 (28%)
       Number of LUT4s:        14385 out of  6864 (210%)
          Number of logic LUTs:      12447
          Number of distributed RAM:   0 (0 LUT4s)
          Number of ripple logic:    969 (1938 LUT4s)
          Number of shift registers:   0
       Number of PIO sites used: 115 + 4(JTAG) out of 115 (103%)
       Number of block RAMs:  16 out of 26 (62%)
       Number of GSRs:  1 out of 1 (100%)
    edited 2014-08-11 15:39
    Ale wrote: »
    Interesting, was that for 8 COGs and Full ROM ?
    ( At least it still reports figures, some tools I've used just report 'failed to fit; when they overflow.. real annoying.)
    If those numbers are for 8 COGS, then maybe fewer COGS and less RAM can give a fit.
    Others are looking at removing most of the ROM, and doing a loader-time RAM based ROM.
    I could see applications where a CPLD is used with a real P1, (or P2) which means even 1-2-3 COGs would be OK in a small companion Logic device.
    Yeah, I used 8 cogs. I should probably go for only 2 or 3, more do not fit :/, and it only has 26 kbytes RAM... block RAM :). But, it is sort of what I also achieved with my design...
