Air Hogs 4 channel IR controller
I wanted to find a new purpose for my old air hogs controller it was from the helix 360 it is a 4 channel IR remote with a light button.
now with the long IR code running servos directly is a bit choppy i would suggest using servo pals to drive servos since i currently dont have any i have not supplied a code for that what i have attached it the Stick desplay code. Each channel uses 5 bits and the light uses a single bit and the first 4 bits in the code i havent determined their function and i didnt dive past the light bit.
any suggestions or ideas for my code would be greatly welcomed
I used a portion of code from the IR Remote AppKit Project Code it helped get me started with the heli IR remote
' {$STAMP BS2}' {$PBASIC 2.5}
' Air Hogs Helix 360 4 channel remote
irPulse VAR Word ' Stores pulse widths
VLS VAR Byte ' Stores Vertical Left Stick
HRS VAR Byte ' Stores Horizontal Right Stick
HLS VAR Byte ' Stores Horizontal Left Stick
VRS VAR Byte ' Stores Vertical Right Stick
light VAR Bit ' Stores Light bit
RCU VAR Nib ' Stores unknown pulses
DO ' Main DO...LOOP
VLS = 0 '
HRS = 0 '
HLS = 0 '
VRS = 0 '
light = 0 '
RCU = 0 '
DO ' Wait for end of resting state.
RCTIME 9, 1, irPulse '
LOOP UNTIL irPulse > 1000 '
PULSIN 9, 0, irPulse '-----------|
IF irPulse > 400 THEN RCU.BIT0 = 1 ' unknown |
RCTIME 9, 0, irPulse ' |
IF irPulse > 400 THEN RCU.BIT1 = 1 ' |
IF irPulse > 400 THEN RCU.BIT2 = 1 ' |
IF irPulse > 400 THEN RCU.BIT3 = 1 ' |
RCTIME 9, 0, irPulse 'Throttle |
IF irPulse > 400 THEN VLS.BIT4 = 1 ' |
IF irPulse > 400 THEN VLS.BIT3 = 1 ' |
IF irPulse > 400 THEN VLS.BIT2 = 1 ' |
IF irPulse > 400 THEN VLS.BIT1 = 1 ' |
IF irPulse > 400 THEN VLS.BIT0 = 1 ' |
RCTIME 9, 0, irPulse 'horizontal right stick |
IF irPulse > 400 THEN HRS.BIT4 = 1 ' |
IF irPulse > 400 THEN HRS.BIT3 = 1 ' |
IF irPulse > 400 THEN HRS.BIT2 = 1 ' |
IF irPulse > 400 THEN HRS.BIT1 = 1 ' |
IF irPulse > 400 THEN HRS.BIT0 = 1 ' |
RCTIME 9, 0, irPulse 'horizontal left stick |
IF irPulse > 400 THEN HLS.BIT4 = 1 ' |
IF irPulse > 400 THEN HLS.BIT3 = 1 ' |
IF irPulse > 400 THEN HLS.BIT2 = 1 ' |
IF irPulse > 400 THEN HLS.BIT1 = 1 ' |
IF irPulse > 400 THEN HLS.BIT0 = 1 ' |
RCTIME 9, 0, irPulse '-----------------------|
IF irPulse > 400 THEN VRS.BIT4 = 1 ' right vertical stick |
IF irPulse > 400 THEN VRS.BIT3 = 1 ' |
IF irPulse > 400 THEN VRS.BIT2 = 1 ' |
IF irPulse > 400 THEN VRS.BIT1 = 1 ' |
IF irPulse > 400 THEN VRS.BIT0 = 1 ' |
RCTIME 9, 0, irPulse ' Light button |
IF irPulse > 400 THEN light = 1 ' |
DEBUG CLS,? VLS,
? HRS,
? HLS,
? VRS,
? light,
? RCU, HOME
LOOP
