Anybody Using HiTech Aurora Telemetry?
I have an Aurora 9 radio with a 7 channel receiver that I use with my Elev-8. This combo has telemetry capability to send sensor data from the receiver (transceiver might be more accurate) to the radio. Out of the box it will monitor the battery voltage if you connect the LiPo to the SPC (Supplementary Power Connection) port of the receiver. Additional capabilities can be had by using a 'sensor station' that reads various sensor data and communicates this to the radio.
The receiver unlocks screens on the radio if the sensor station is found where the info is displayed. Apparently you can also download logs of the various data after your flight.
So, I've found this sensor station project on the web and built a kit. http://www.d68.nl/sensorboard/using.html
It communicates fine with the receiver IF the receiver is powered by 5V thru the BAT port. However, I haven't been able to get it working with the receiver powered by the SPC port.
Anybody using this setup?
-Russ
-Russ
-Russ
